max BGA chip temprate https://vlab.su/viewtopic.php?f=178&t=19073 |
nasser_pczone [ 11 фев 2014, 17:27 ] | |
Заголовок сообщения: | max BGA chip temprate |
hi any one can help me to know a guide to know what the max BGA chip temperature for replace such as under heat and top heat ..if is a list for this is very fine |
Sergej [ 11 фев 2014, 21:36 ] | |
Заголовок сообщения: | Re: max BGA chip temprate |
nasser_pczone , check PM |
nasser_pczone [ 11 фев 2014, 22:53 ] | |
thanks but not helpful because no model or no explanation for chip under and top but very tanks |
Sergej [ 11 фев 2014, 23:59 ] | |
http://notebook1.ru/forma1/viewtopic.ph ... 20#p181020 |
nasser_pczone [ 20 фев 2014, 11:35 ] | |
thanks but not helpful i want list a bout chip max temperate to reall |
Sergej [ 20 фев 2014, 12:58 ] | |
The maximum chip temperature of 240 degrees for 10 seconds. But every motherboard heats up in different ways and at different speeds. Each solderstation heats differently - no ready solutions for all occasions |
nasser_pczone [ 20 фев 2014, 13:26 ] | |
thanks but 240 for 10 sec i sure chip can not lift up with this temperate i test with 350 top and under 200 for about 3 min |
MSF113 [ 21 фев 2014, 11:12 ] | |
350 top is too high. 200 lower heater is too low. |
nasser_pczone [ 21 фев 2014, 18:25 ] | |
Ooooommmmm so tell me what is a correct temptation ? For example HM67 or g86-631-a2 |
nasser_pczone [ 22 фев 2014, 11:57 ] | |
no any idea ? please ? |
MSF113 [ 24 фев 2014, 07:48 ] | |
I don't know what BGA rework station are you used. Read instruction or forum about your station. |
345shrus345 [ 24 фев 2014, 10:34 ] | |
max BGA temperature 270-350 |
MSF113 [ 24 фев 2014, 10:51 ] | |
345shrus345 What temp do you mean? Upper heater? Max exactly BGA chip is 245 for pb-free |
