Текущее время: 23 май 2024, 17:57
MSF113
Заголовок сообщения: Re: Using an infrared bga machine, what temperature should you choose to remove the chip? Добавлено: 31 май 2017, 09:04 |
See document: Вложение: JEDEC-STD-020C
MSF113
Заголовок сообщения: Re: Using an infrared bga machine, what temperature should you choose to remove the chip? Добавлено: 05 июн 2017, 09:24 |
You must have: - good BGA Rework station - all necessary materials. Flux, etc. - enough experience
Haswell processor is the most difficult case.
