Текущее время: 09 июн 2026, 16:15
rem.team nbzip nbzip stencil
 Заголовок сообщения: Using an infrared bga machine, what temperature should you choose to remove the chip?
СообщениеДобавлено: 31 май 2017, 03:20
I have an Acer E1-572 4200u motherboard with built-in video and processor, I know I can not set a very high temperature because I can damage the processor and I can not set a very low temperature because I can not remove the chip there. I ask: what is the ideal temperature and the time too?
Many colleagues have reported that the BGA T862 machine is of inferior quality because they have already been able to burn the chip at the time of removal.
The most important thing for me would be to know the specifications that the machine must have in order not to buy the wrong machine.
I'm thinking of setting up a machine for myself. Does an 110V and 350w ceramic resistor with 70mm by 70mm measures already help?
 Заголовок сообщения: Re: Using an infrared bga machine, what temperature should you choose to remove the chip?
СообщениеДобавлено: 31 май 2017, 08:25
With BGA T862 will you hard,if you have friend,he have Achi or Jovy eco with it easy
СообщениеДобавлено: 31 май 2017, 09:04
See document:
JEDEC-STD-020C
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 04 июн 2017, 21:00
Is it true that after you make an attempt to reballing and do not get 100% correct you can not reballing again?
Are you wondering, what is the most efficient and effective way to do reballing, using infrared or hot air?
With the I5 processor and video attached, such as Acer's I5 4200U notebook, which is the most appropriate technique for reballing, is there any tecnic and correct procedure to perform?
СообщениеДобавлено: 05 июн 2017, 09:24
You must have:
- good BGA Rework station
- all necessary materials. Flux, etc.
- enough experience
Haswell processor is the most difficult case.
СообщениеДобавлено: 30 июн 2017, 10:32
without a decent BGA rework machine and a lot of experience please do not even think of it.
В этой теме нет новых непрочитанных сообщений. Продам Инфракрасная паяльная станция Best-007 Pro Infrared BGA
Optimal_plus
05 июн 2020, 23:03
ShEiTaN Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. What procedures, equipment, and materials do you need to remove and glue the flat of the LCD TV screen?
в форуме LCD
eletmoraes
20 май 2019, 08:05
mia Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. BGA REBALLING STATION: IR(ceramic heater plate) OR HOT AIR, WHICH TO CHOOSE AND WHY?
в форуме Оборудование для ремонта | Repair Equipment
azzed
17 сен 2022, 08:22
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. What is the best method to remove the chip from the RTL8111F network?
eletmoraes
06 окт 2018, 10:14
Сейчас этот форум просматривают: Olgert, serg016 и гости: 9
