RealRepair1 писал(а):
Any time those voltage regulators fail, I would confirm that their output voltage is not shorted after removing the regulator / inductor, sometimes the output damages the components downstream.
Снял регулятор, кз ушло, заказал RT6256BGQUF, после замены отпишусь.
