| Ремонт: Ноутбуков, Компьютеров https://vlab.su/ |
| Tip for repair, PS4 BLOD UART https://vlab.su/viewtopic.php?f=202&t=126254 |
| WaySheGoes [ 01 июн 2022, 06:20 ] | |
| Заголовок сообщения: | Tip for repair, PS4 BLOD UART |
If you receive no data from UART on PS4 BLOD, especially a character or two of junk data, this is definitely a problem with APU as many know. However, in each case I have found it also relates to a disconnected or bad RAM on bank 0-1. I hope this helps people out there! |
| ДмитрийMula1 [ 01 июн 2022, 10:36 ] | |
| Заголовок сообщения: | Re: Tip for repair, PS4 BLOD UART |
Thank you very much for the information) |
| nerirififi [ 29 авг 2022, 16:35 ] | |
WaySheGoes писал(а): two of junk data What do you mean by "two of junk data" Maybe you have a screen capture, that will be interessant to see. And common problem seems to be on BANK 0 _ 1, that probably a conception default. |
| Delfin- [ 29 авг 2022, 19:52 ] | |
nerirififi писал(а): What do you mean by "two of junk data" Maybe you have a screen capture, that will be interessant to see. And common problem seems to be on BANK 0 _ 1, that probably a conception default. reball CPU first |
| Страница 1 из 1 | Часовой пояс: UTC + 4 часа |
| Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
