Dct0 and 1 cold https://vlab.su/viewtopic.php?f=202&t=128312 |
ilie321 [ 28 авг 2022, 22:52 ] | |
Заголовок сообщения: | Dct0 and 1 cold |
Hello i bought an ps4 with blod. On uart it says dct0 and 1 problems and they remain cold comparatively with the other ones any ideas? I changed them and same problem. I'm not a technician just hobby so i don't know too much about ps4 repairs. Thanks. Edit: this chips are on back not on the apu side. Board is saa001 |
ДмитрийMula1 [ 28 авг 2022, 23:07 ] | |
Заголовок сообщения: | Re: Dct0 and 1 cold |
Good evening. Most likely the problem is in the processor, its balls moved under it. You need to scrap the processor. You most likely have a processor failure along the lines of this memory. |
