Текущее время: 04 ноя 2026, 21:19
 Заголовок сообщения: Xbox One S has all the voltages, but still won't start.
СообщениеДобавлено: 26 сен 2024, 16:37
Hello everyone. I have an Xbox One S that, when plugged in, seemingly does nothing, but within the first 20 seconds, it starts and stops the power three times. During this time, if I press the power button, I only hear the power-on sound. After the third power shutdown, if I press the power button, the LED lights up as it should, but after about 5 seconds, it turns off with a shutdown sound. All voltages are present. The only previous issue was that the Ethernet IC (RTL8111) was shorted, so the V_3P3 was missing, but after desoldering it, all voltages returned to normal.
When first powered on, the fan doesn't move as it should. However, if I try to start it without cooling, the fan starts when the processor reaches around 60-79°C.
Does anyone have any ideas?
 Заголовок сообщения: Re: Xbox One S has all the voltages, but still won't start.
СообщениеДобавлено: 27 сен 2024, 19:36
What I also noticed is that during a power-up period, the SOC_PWR_OK goes low twice
 Заголовок сообщения: Re: Xbox One S has all the voltages, but still won't start.  [РЕШЕНО]
СообщениеДобавлено: 28 сен 2024, 00:35
is there no short circuit anywhere?
СообщениеДобавлено: 30 сен 2024, 21:47
There was no short circuit anywhere. After reballing, V_GFXCORE went into a short circuit, I thought I made a mistake, so I removed the APU again, but unfortunately, it became shorted. It's no longer worth dealing with it any further.
Thank you.
В этой теме нет новых непрочитанных сообщений. RTX2080TI strange issue - all VRMs works fine but GPU still in reset state
Assassin
3259
04 сен 2021, 20:50
Joe24 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTx 980 all voltages are normal, PWM signal too, but black screen
netcrusher
14 фев 2020, 18:50
Naik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASRock Vega56 - no Video but all voltages and BIOS OK
Assassin
04 июл 2020, 16:53
men2k1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 970 MSI GAMING X MS-V316 REV1.3 / ALL VOLTAGES PRESENT, BUT NO VIDEO
azzed
27 окт 2022, 10:46
huehu3gg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Power source dell Model H275P-01 P / N: HP-L2767F3P won't start
eletmoraes
3267
05 янв 2020, 21:35
Witewut Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 38
