Текущее время: 28 ноя 2026, 00:55
 Заголовок сообщения: load bios ps4 slim sae-002
СообщениеДобавлено: 03 июл 2025, 09:52
Здравствуйте.Подскажите пожалуйста,была ошибка load bios-8 слот переключил приставка запустилась но с ошибкой.secure loader build: Mar 22 2017 05:18:07 (r8311:release_branches/release_04.550
) [711MHz]
AGESA: KG&GL.BDK W7217
standby 05070000
2786 msec
[BOOT TIME
] SAMU: 696 msec: enter
[BOOT TIME] SAMU: 3489 msec: leave
AGESA:
ClaytonBDK_20.0.7.61027 SAMU: W7217
SIE CONFIDENTIAL
Copyright (C) 2017 Sony Interactive Entertainment Inc.
All Rights Reserved.
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
r82019/release_branches/release_04.550 Mar 22 2017 05:25:45 amd64
mDBG: Kernel Build ID = e36591aaf2c8cb44
CPU: DG1401SNF87ID (1594.00-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x710fa0 Family = 16 Model = 1a Stepping = 0
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C
MOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x36d8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,
AESNI,XSAVE,AVX,F16C>
AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
AMD Features2=0x154837ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,
IBS,SKINIT,WDT,NodeId,Topology,PerfCtrExtNB,<b26>,<b28>>
TSC: P-state invariant, performance statistics
Event timer "LAPIC" quality 400
ACPI APIC Table: <SIE ORBIS >
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 8 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
MADT: Could not find APIC for SCI IRQ 9
[REGMGR] C00002 @255@@255@ ...
[REGMGR] 000001 ...
Memory mode: 5: BC8 CS
BigApp memory: 0x0000000124000000 bytes (4672MiB)
FMEM (max): 0x0000000004000000 bytes (64MiB)
MiniApp DMEM: 0x0000000058800000 bytes (1416MiB)
VSH DMEM: 0x0000000028200000 bytes (642MiB)
Trace memory & Trace DMEM: 0x0000000000000000 bytes (0MiB)
Vision memory: 0x0000000001000000 bytes (16MiB)
Reserved memory: 0x0000000000000000 bytes (0MiB)
Flexible memory #0: 0x0000000050828000 bytes (1289MiB)
BIOS memory size: 0x00000000011b8000 bytes (18MiB)
Kernel static size: 0x0000000008420000 bytes (133MiB)
acpi0: <SIE ORBIS> on motherboard
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: found pcie_glue
iommu0: <AMD IOMMU> on pci0
gc0: <Starsha> on pci0
LVP2C A0
# use 0x00000000 as mmGB_ADDR_CONFIG value
GC SE0 Redundant CU: 0x4
GC SE1 Redundant CU: 0x8
GC SE2 Redundant CU: 0x0
GC SE3 Redundant CU: 0x0
SClkVid:0x5c SClkDpmVid:3 Dpm:3 Vid:0x5c
hdac0: <GPU/DEHT Audio Controller> on pci0
bpcie0: <Baikal PCI Express glue> on pci0
bpcie0: Chip revision: 0000b100
bpcie0: Chip ID0: 52ac2021
bpcie0: Chip ID1: 14f75fe3
icc0: <Baikal ICC> on pci0
hpet_pci0: <Baikal High Precision Event Timer> on pci0
Timecounter "HPET" frequency 10000000 Hz quality 950
Event timer "HPET" frequency 10000000 Hz quality 450
Event timer "HPET1" frequency 10000000 Hz quality 450
Event timer "HPET2" frequency 10000000 Hz quality 450
Event timer "HPET3" frequency 10000000 Hz quality 450
sflash0: <Baikal Serial Flash I/F> on pci0
sflash0: Winbond(ef)
rtc0: <Baikal RTC> on pci0
timer_mtk0: <Baikal Timer/WDT> on pci0
uart0: <Non-standard ns8250 class UART with FIFOs> on pci0
uart0: uart_bus_attach
uart0: console (115200,n,8,1)
ahci0: <Orbis Baikal sata0 AHCI SATA controller> on pci0
ahci0: Baikal SATA PHY init
ahci0: Baikal SATA EFUSE VALUE: 0x27:0x27:0x0f:0x0f:0x0e:0x0e
ahci0: Baikal SATA PHY Trace length : 8
ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
iommu_add_device_table_entry: device_id:00a2 dev:64 func:64 ahcich
xhci0: <Baikal XHCI USB 3.0 controller> on pci0
ahci1: <Orbis Baikal sata1 AHCI SATA controller> on pci0
ahci1: Baikal SATA PHY init
ahci1: Baikal SATA EFUSE VALUE: 0x27:0x27:0x0f:0x0f:0x0e:0x0e
ahci1: Baikal SATA PHY Trace length : 6
ahci1: HWConfig Speed:Gen2
ahci1: AHCI v1.30 with 1 6Gbps ports, Port Multiplier supported
ahcich1: <AHCI channel> at channel 0 on ahci1
iommu_add_device_table_entry: device_id:00a7 dev:64 func:64 ahcich
Initial IO PTB alloc. device:0xa7 io:0xa000000
xhci2: <Baikal XHCI USB 3.0 controller> on pci0
acpi_ssb0: <Baikal acpi> on pci0
mtsc0: <Baikal GBE controller> on pci0
iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mtsc
mts0: <Baikal GBE> on mtsc0
eth0: Ethernet address: c8:63:f1:61:bd:4a
sdhci0: <Baikal SDHCI> on pci0
iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci
sdhci0-slot0: DriveStrength:0x2 HOST_CONTROL2:0x20
sdhci0: 1 slot(s) allocated
dmac0: <Baikal DMA1 controller> on pci0
iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac
dmac1: <Baikal DMA2 controller> on pci0
spm0: <Baikal Scratch Pad Memory> on pci0
sbram0: <Baikal DDR3 memory> on pci0
dct0: <SCE DCT driver> on hostb4
sbi0: <SCE SBI driver> on hostb5
gbase_register_interrupt_handler(52)
gbase_register_interrupt_handler(53)
dce: 23
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
MANU mode, ready to make_dev()
_sdma_hw_init(0): microcode loaded
_sdma_hw_init(1): microcode loaded
acpUtlSrc: <Codec UtlSrc built on Mar 22 2017 05:24:13>
acpDecFlac: <Codec DecFlac built on Mar 22 2017 05:24:13>
ajm: <Audio CoProcessor Job Manager built on Mar 22 2017 05:24:11>
acpDecMp3: <Codec DecMp3 built on Mar 22 2017 05:24:07>
acpDecAt9: <Codec DecAt9 built on Mar 22 2017 05:24:08>
acpDecM4aac: <Codec DecM4aac built on Mar 22 2017 05:24:08>
acpEncM4Aac: <Codec EncM4Aac built on Mar 22 2017 05:24:08>
acpDecCelp8: <Codec DecCelp8 built on Mar 22 2017 05:24:08>
acpEncCelp8: <Codec EncCelp8 built on Mar 22 2017 05:24:08>
acpDecAc3: <Codec DecAc3 built on Mar 22 2017 05:24:08>
acpEncAc3: <Codec EncAc3 built on Mar 22 2017 05:24:12>
acpDecTrhd: <Codec DecTrhd built on Mar 22 2017 05:24:12>
acpDecM2bc: <Codec DecM2bc built on Mar 22 2017 05:24:12>
acpEncDts: <Codec EncDts built on Mar 22 2017 05:24:12>
acpDecM4aacfng: <Codec DecM4aacfng built on Mar 22 2017 05:24:12>
acpDecCelp: <Codec DecCelp built on Mar 22 2017 05:24:12>
acpEncCelp: <Codec EncCelp built on Mar 22 2017 05:24:12>
acpDecVorbis: <Codec DecVorbis built on Mar 22 2017 05:24:12>
acpEncOpusCelt: <Codec EncOpusCelt built on Mar 22 2017 05:24:12>
acpDecOpusCelt: <Codec DecOpusCelt built on Mar 22 2017 05:24:12>
acpEncOpusSilk: <Codec EncOpusSilk built on Mar 22 2017 05:24:12>
acpDecOpusSilk: <Codec DecOpusSilk built on Mar 22 2017 05:24:13>
UVFAT_Initialize: exit
Timecounters tick every 1.000 msec
Session ID: ae45f1628ad5f2ccb138cdec3aeaff0c
ipfw2 (+ipsecure kernel build: Mar 22 2017 05:15:56 (r8311:release_brancvhes/rel
ease_04.550)
6xtsQ 4, inflateQ 4, hmacshaQ 4, commonQ 4
) initialized, divert loadable, nat enabled, rule-based forwarding disabled, def
ault to accept, logging disabled
g_lvd_init 348 : Layered vnode device is initialized.
g_lvd_init 350 : lvd is built at 05:24:20 Mar 22 2017
GEOM_CRYPT: eap key setup
iommu_add_device_table_entry: device_id:00a4 dev:20 func:4 sflash
pass0 at ahcich0 bus 0 scbus1 target 0 lun 0
pass0: <SONY PS-SYSTEM 412R 5008> Removable CD-ROM SCSI-0 device
pass0: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
icc08-4001 0802
icc:failed to enabled reset button notification: 0005
icc:enabled thermal notification
[REGMGR] 000003 ...
[REGMGR] ( 0.180 sec) 010002 ...
[REGMGR] 000401 ...
[REGMGR] C00027 @0@@0@@0@@64@@0@@0@ ...
[REGMGR] 001001 $11225923$@2@$13978948$# #$137771694779716$@388@############ ...
[REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ...
[REGMGR] C00004 @461@@1024@ ...
[REGMGR] C00005 @65@@1280@ ...
[REGMGR] C00006 @110663@@204800@ ...
[REGMGR] C00007 @0@ ...
[REGMGR] C00008 @0@ ...
[REGMGR] C00009 @343@@6848@ ...
[REGMGR] 000101 @0@@4522112@ ...
[REGMGR] 000102 ...
[REGMGR] ( 0.041720 sec) 010001 ...
[REGMGR] ( 0.231 sec) 010001 ...
[REGMGR] ( 0.001251 sec) 010301 @0@ ...
[REGMGR] ( 0.000005 sec) 010302 @0@ ...
[REGMGR] 000103 @0@@4522112@ ...
[REGMGR] 000104 ...
[REGMGR] C00018 @1@ ...
[REGMGR] C00023 @4522112@@1@@0@@3301@@0@@0@ ...
[REGMGR] ( 0.038429 sec) 010003 ...
[REGMGR] ( 0.277 sec) 010003 ...
[HDMI] Set CEC FeatureTable [Normal]
[HDMI ERROR] : readEdid:2748 - Extended block num is illegal
[HDMI] HDMI kernel module has been available
mmc0: <MMC/SD bus> on sdhci0
trsw0 on sdio0
bt0 on sdio0
trs0 on sdio0
sdio0: <SDIO Device> at mmc0
ERROR: sceSblSkLoadElfReadHeader(47) sceSblCfVeriReadHeaderWithRootKeyCb -34
ERROR: spawn(490) sceSblSkElfGetHeader -34
ERROR: sceSblServiceSpawn(207) stat -8
ERROR: preLoad(83) sceSblServiceSpawn error ret=0xfffffff8
ERROR: sceSblServiceGetUtid(136) sceSblServiceMailbox -3
ERROR: _sceSblAuthMgrSmStart(226) spawn failed fffffffd
ERROR: sceSblSysVeriInitialize(216) failure sceSblKeymgrSmCallfuncWithID(Init) -
2146499565
panic: generating veri thread failed.(0x800f0413)
cpuid = 0
ICC 07-01 polling
ICC 07-00 polling
ICC 02-0b polling
mDBG: System error. Performing systemdump.
mDBG: Mute audio.
mDBG: Mute audio done.
Attempt to write outside dump device boundaries.
offset(16384), mediaoffset(0), length(16384), mediasize(0).
mDBG: Power down...
mDBG: ...
ICC 04-01 nowait
) [711MHz]
и так по кругу
 Заголовок сообщения: Re: load bios ps4 slim sae-002
СообщениеДобавлено: 03 июл 2025, 21:43
think i have one for doner, ill check
СообщениеДобавлено: 04 июл 2025, 10:45
viewtopic.php?f=202&t=119215&start=210
СообщениеДобавлено: 06 июл 2025, 09:20
нет не мой случай не помогло.
СообщениеДобавлено: 08 июл 2025, 18:30
не кто не сталкивался? ERROR: sceSblSkLoadElfReadHeader(47) sceSblCfVeriReadHeaderWithRootKeyCb -34
2146499565
cpuid = 0
В этой теме нет новых непрочитанных сообщений. PS4 slim плата SAE-002 не реагирует на кнопку включения
dry125
621
17 мар 2026, 23:42
crow84 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Ps4 Slim Sae-003 Нужен совет спеца
Pavel_68
5455
06 май 2021, 21:27
Pavel_68 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. PS4 slim SAE-003 включается и сразу выключается
silverblades
25 июл 2021, 09:24
silverblades Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PS4 Slim SAE-004 нет изображения выключается
fred24
06 авг 2021, 22:29
ДмитрийMula1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PS4 Slim SAE-004 Выключается сразу после нажатия кнопки
flydjv
21 окт 2022, 14:33
zaurista Перейти к последнему сообщению
