Наконец то дошли руки перекинуть банки, к сожалению не помогло( На родных дампах так же loadBios8 (версия по:(r9213:release_branches/release_05.070)), после переключения слота версия по меняется на (r8311:release_branches/release_04.550), но вываливаются те же ошибки: secure loader build: Mar 22 2017 05:18:07 (r8311:release_branches/release_04.550) [711MHz] AGESA: KG&GL.BDK W7217 2559 msec [BOOT TIME] SAMU: 645 msec: enter [BOOT TIME] SAMU: 3211 msec: leave AGESA: ClaytonBDK_20.0.7.61027 SAMU: W7217 SIE CONFIDENTIAL Copyright (C) 2017 Sony Interactive Entertainment Inc. All Rights Reserved. Copyright (c) 1992-2012 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. r82019/release_branches/release_04.550 Mar 22 2017 05:25:45 amd64 mDBG: Kernel Build ID = e36591aaf2c8cb44 CPU: DG1401SNF87ID (1594.00-MHz K8-class CPU) Origin = "AuthenticAMD" Id = 0x710fa0 Family = 16 Model = 1a Stepping = 0 Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT> Features2=0x36d8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,AVX,F16C> AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM> AMD Features2=0x154837ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId,Topology,PerfCtrExtNB,<b26>,<b28>> TSC: P-state invariant, performance statistics Event timer "LAPIC" quality 400 ACPI APIC Table: <SIE ORBIS > FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs FreeBSD/SMP: 1 package(s) x 8 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 cpu4 (AP): APIC ID: 4 cpu5 (AP): APIC ID: 5 cpu6 (AP): APIC ID: 6 cpu7 (AP): APIC ID: 7 MADT: Could not find APIC for SCI IRQ 9 [REGMGR] C00002 @255@@255@ ... [REGMGR] 000001 ... Memory mode: 5: BC8 CS BigApp memory: 0x0000000124000000 bytes (4672MiB) FMEM (max): 0x0000000004000000 bytes (64MiB) MiniApp DMEM: 0x0000000058800000 bytes (1416MiB) VSH DMEM: 0x0000000028200000 bytes (642MiB) Trace memory & Trace DMEM: 0x0000000000000000 bytes (0MiB) Vision memory: 0x0000000001000000 bytes (16MiB) Reserved memory: 0x0000000000000000 bytes (0MiB) Flexible memory #0: 0x0000000050840000 bytes (1289MiB) BIOS memory size: 0x00000000011b8000 bytes (18MiB) Kernel static size: 0x0000000008408000 bytes (133MiB) acpi0: <SIE ORBIS> on motherboard cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 pcib0: <ACPI Host-PCI bridge> on acpi0 pci0: <ACPI PCI bus> on pcib0 pci0: found pcie_glue iommu0: <AMD IOMMU> on pci0 gc0: <Starsha> on pci0 LVP2C A0 # use 0x00000000 as mmGB_ADDR_CONFIG value GC SE0 Redundant CU: 0x10 GC SE1 Redundant CU: 0x10 GC SE2 Redundant CU: 0x0 GC SE3 Redundant CU: 0x0 SClkVid:0x5e SClkDpmVid:3 Dpm:3 Vid:0x5e hdac0: <GPU/DEHT Audio Controller> on pci0 apcie0: <Belize PCI Express glue> on pci0 apcie0: Chip revision: 02000100 apcie0: Chip ID0: 463f3110 apcie0: Chip ID1: 108280e0 icc0: <Belize ICC> on pci0 hpet_pci0: <Belize High Precision Event Timer> on pci0 Timecounter "HPET" frequency 10000000 Hz quality 950 Event timer "HPET" frequency 10000000 Hz quality 450 Event timer "HPET1" frequency 10000000 Hz quality 450 Event timer "HPET2" frequency 10000000 Hz quality 450 Event timer "HPET3" frequency 10000000 Hz quality 450 sflash0: <Belize Serial Flash I/F> on pci0 sflash0: Winbond(ef) rtc0: <Belize RTC> on pci0 timer_mvl0: <Belize Timer/WDT> on pci0 uart0: <Non-standard ns8250 class UART with FIFOs> on pci0 uart0: uart_bus_attach uart0: console (115200,n,8,1) ahci0: <Orbis Belize sata0 AHCI SATA controller> on pci0 ahci0: Belize SATA PHY init ahci0: Belize SATA PHY Trace length : 9 ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 iommu_add_device_table_entry: device_id:00a2 dev:64 func:64 ahcich xhci0: <Belize XHCI USB 3.0 controller> on pci0 ahci1: <Orbis Belize sata1 AHCI SATA controller> on pci0 ahci1: Belize SATA PHY init ahci1: Belize SATA PHY Trace length : 6 ahci1: HWConfig Speed:Gen2 ahci1: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS ahcich1: <AHCI channel> at channel 0 on ahci1 iommu_add_device_table_entry: device_id:00a7 dev:64 func:64 ahcich Initial IO PTB alloc. device:0xa7 io:0xa000000 xhci2: <Belize XHCI USB 3.0 controller> on pci0 acpi_ssb0: <Belize acpi> on pci0 mskc0: <Belize GBE controller> on pci0 iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mskc msk0: <Belize GBE Id:0xbd Rev:0x01> on mskc0 eth0: Ethernet address: c8:63:f1:62:96:fd sdhci0: <Belize SDHCI> on pci0 iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci sdhci0: 1 slot(s) allocated dmac0: <Belize DMA1 controller> on pci0 iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac dmac1: <Belize DMA2 controller> on pci0 spm0: <Belize Scratch Pad Memory> on pci0 sbram0: <Belize DDR3 memory> on pci0 dct0: <SCE DCT driver> on hostb4 sbi0: <SCE SBI driver> on hostb5 gbase_register_interrupt_handler(52) gbase_register_interrupt_handler(53) dce: 23 hwpstate0: <Cool`n'Quiet 2.0> on cpu0 MANU mode, ready to make_dev() _sdma_hw_init(0): microcode loaded _sdma_hw_init(1): microcode loaded acpUtlSrc: <Codec UtlSrc built on Mar 22 2017 05:24:13> acpDecFlac: <Codec DecFlac built on Mar 22 2017 05:24:13> ajm: <Audio CoProcessor Job Manager built on Mar 22 2017 05:24:11> acpDecMp3: <Codec DecMp3 built on Mar 22 2017 05:24:07> acpDecAt9: <Codec DecAt9 built on Mar 22 2017 05:24:08> acpDecM4aac: <Codec DecM4aac built on Mar 22 2017 05:24:08> acpEncM4Aac: <Codec EncM4Aac built on Mar 22 2017 05:24:08> acpDecCelp8: <Codec DecCelp8 built on Mar 22 2017 05:24:08> acpEncCelp8: <Codec EncCelp8 built on Mar 22 2017 05:24:08> acpDecAc3: <Codec DecAc3 built on Mar 22 2017 05:24:08> acpEncAc3: <Codec EncAc3 built on Mar 22 2017 05:24:12> acpDecTrhd: <Codec DecTrhd built on Mar 22 2017 05:24:12> acpDecM2bc: <Codec DecM2bc built on Mar 22 2017 05:24:12> acpEncDts: <Codec EncDts built on Mar 22 2017 05:24:12> acpDecM4aacfng: <Codec DecM4aacfng built on Mar 22 2017 05:24:12> acpDecCelp: <Codec DecCelp built on Mar 22 2017 05:24:12> acpEncCelp: <Codec EncCelp built on Mar 22 2017 05:24:12> acpDecVorbis: <Codec DecVorbis built on Mar 22 2017 05:24:12> acpEncOpusCelt: <Codec EncOpusCelt built on Mar 22 2017 05:24:12> acpDecOpusCelt: <Codec DecOpusCelt built on Mar 22 2017 05:24:12> acpEncOpusSilk: <Codec EncOpusSilk built on Mar 22 2017 05:24:12> acpDecOpusSilk: <Codec DecOpusSilk built on Mar 22 2017 05:24:13> UVFAT_Initialize: exit Timecounters tick every 1.000 msec Session ID: 17cfdcb2a171da3ecc3f2f66f068cd04 ipsecure kernel build: Mar 22 2017 05:15:56 (r8311:release_brancfhes/release_04.550) wxtsQ 4, inflateQ 4, hmacshaQ 4,2 commonQ 4 (+ipv6) initialized, divert loadable, nat enabled, rule-based forwarding disabled, default to accept, logging disabled ahci0: Belize SATA PHY init ahci0: Belize SATA PHY Trace length : 9 ahci1: Belize SATA PHY init ahci1: Belize SATA PHY Trace length : 6 ahci1: Belize SATA PHY init ahci1: Belize SATA PHY Trace length : 6 ahci1: Belize SATA PHY init ahci1: Belize SATA PHY Trace length : 6 g_lvd_init 348 : Layered vnode device is initialized. g_lvd_init 350 : lvd is built at 05:24:20 Mar 22 2017 GEOM_CRYPT: eap key setup iommu_add_device_table_entry: device_id:00a4 dev:20 func:4 sflash icc08-4001 0802 icc:failed to enabled reset button notification: 0005 icc:enabled thermal notification [REGMGR] 000003 ... [REGMGR] ( 0.261 sec) 010002 ... [REGMGR] 000401 ... [REGMGR] C00027 @0@@0@@0@@64@@0@@0@ ... [REGMGR] 001001 $11164996$@9@$13978948$# #$137771694779716$@396@############ ... [REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ... [REGMGR] C00004 @461@@1024@ ... [REGMGR] C00005 @65@@1280@ ... [REGMGR] C00006 @110663@@204800@ ... [REGMGR] C00007 @0@ ... [REGMGR] C00008 @0@ ... [REGMGR] C00009 @343@@6848@ ... [REGMGR] 000101 @0@@4522112@ ... [REGMGR] 000102 ... [REGMGR] ( 0.039856 sec) 010001 ... [REGMGR] ( 0.310 sec) 010001 ... [REGMGR] ( 0.001249 sec) 010301 @0@ ... [REGMGR] ( 0.000005 sec) 010302 @0@ ... [REGMGR] 000103 @0@@4522112@ ... [REGMGR] 001001 $11164996$@9@$13978948$# #$137771694779716$@396@############ ... [REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ... [REGMGR] 000104 ... [REGMGR] C00018 @1@ ... [REGMGR] C00023 @4522112@@1@@0@@3301@@0@@0@ ... [REGMGR] ( 0.036854 sec) 010003 ... [REGMGR] ( 0.353 sec) 010003 ... pass0 at ahcich0 bus 0 scbus1 target 0 lun 0 pass0: <SONY PS-SYSTEM 420R 6074> Removable CD-ROM SCSI-0 device pass0: 150.000MB/s transfers (SATA 1.x, UDMA6, ATAPI 12bytes, PIO 8192bytes) [HDMI] Set CEC FeatureTable [Normal] mmc0: <MMC/SD bus> on sdhci0 [HDMI ERROR] : readEdid:2748 - Extended block num is illegal [HDMI] HDMI kernel module has been available sdhci0-slot0: Error detected!! sdhci0-slot0: request: CMD3 arg 0 flags 0x65 buf 0 dlen 0 bs 0 dflags 0 sdhci0-slot0: result : 1 sdhci0-slot0: intmask: 0x00010000 sdhci0-slot0: Change sdio host ip clock. (50MHz->200MHz) trsw0 on sdio0 bt0 on sdio0 trs0 on sdio0 sdio0: <SDIO Device> at mmc0 ERROR: sceSblSkLoadElfReadHeader(47) sceSblCfVeriReadHeaderWithRootKeyCb -34 ERROR: spawn(490) sceSblSkElfGetHeader -34 ERROR: sceSblServiceSpawn(207) stat -8 ERROR: preLoad(83) sceSblServiceSpawn error ret=0xfffffff8 ERROR: sceSblServiceGetUtid(136) sceSblServiceMailbox -3 ERROR: _sceSblAuthMgrSmStart(226) spawn failed fffffffd ERROR: sceSblServiceGetUtid(136) sceSblServiceMailbox -3 ERROR: sceSblSysVeriInitialize(216) failure sceSblKeymgrSmCallfuncWithID(Init) -2146499565 panic: generating veri thread failed.(0x800f0413) cpuid = 0 ICC 07-01 polling ICC 07-00 polling ICC 02-0b polling mDBG: System error. Performing systemdump. mDBG: Mute audio. mDBG: Mute audio done. Attempt to write outside dump device boundaries. offset(16384), mediaoffset(0), length(16384), mediasize(0). mDBG: Power down... mDBG: ... ICC 04-01 nowait
