Текущее время: 22 ноя 2024, 05:39
 Заголовок сообщения: Z170-HD3P NO +VCORE
СообщениеДобавлено: 02 янв 2023, 03:34
I bought the card 2 weeks ago with vcore issue. I left it aside because of my customer boards. Yesterday card just worked fine, did some tests and i can say it was working flawlessly but tried just now and vcore is missing again. VDDQ,VCCSA and VCCIO is present. PWM Controller is ISL95856HRZ, checked with the thermal camera nothing is getting hot or missing components around. Bios twicthes when i start the board. The weird thing is when i left a drop of alcohol on controller, 1 V appears on VCORE but reset did not release. Changed the resistors and capacitors around the controller but nothing have changed. Have you guys any idea ?
 Заголовок сообщения: Re: Z170-HD3P NO +VCORE
СообщениеДобавлено: 04 янв 2023, 02:58
there are many options, one of them: CPU socket could fall off
The Best Data Recovery Expert in EU
СообщениеДобавлено: 04 янв 2023, 17:46
sergun
I dont think cpu socket could not be problem of no vcore issue.
СообщениеДобавлено: 04 янв 2023, 18:48
The oscilloscope see 8,11.4 PIN, a logical analyzer (if any), check the SMB tire 43.42 PIN.
СообщениеДобавлено: 05 янв 2023, 02:54
alex68q
pin 8 is 1.05 V
pin 11 is 3 V
pin 4 is 3.3 V
СообщениеДобавлено: 05 янв 2023, 11:03
yusuf4511 писал(а):
idea ?
For pin 42 isl9586 , are clock impulses, and on pin 43 isl9586 , pulses of these tires SMB (I2C Protocol).
For pin 5 impulses for SVID for CPU.
On 6 PIN, brief impulses of logical zero.
All this must be watched when the board is turned on or after starting the board, when you press the Reset button.
СообщениеДобавлено: 05 янв 2023, 15:08
alex68q
i could not see impulses on each pin you said, only straight dc voltage. I also checked with ac on oscilloscope nothing impulses.
СообщениеДобавлено: 05 янв 2023, 15:43
Which reset do you mean? CPU_RST?
There could be a short transfer, one of the way to take a look on impulses is to set oscilloscope trigger at the falling adge of svid clock or data or use logic analyzer
Have you checked CPUPWRGD signal from pch to cpu?
Ааааааааааа!
СообщениеДобавлено: 05 янв 2023, 19:17
Тимур Кан
The reset of pcie is 0 v. CPUPWRGD reaches to IO when pwm present but cpu reset is 0 not released. When i set the triger mode, all signals pulse once and goes back to straight DC line. Also #Alert pin is active, shows 0 volts when pwm present. I can get pwm 1 v with a droplet of alcohol on pwm controller.
СообщениеДобавлено: 05 май 2023, 19:23
hello my friend, i have ga-z170x-gaming 3, same issue, and i did what you said "with a droplet of alcohol on pwm controller" and it gives 1 volt but still goes off, did find the problem?
привет мой друг, у меня ga-z170x-gaming 3, такая же проблема, и я сделал то, что вы сказали, "с капелькой спирта на pwm-контроллере", и он дает 1 вольт, но все еще гаснет, нашел проблему?
СообщениеДобавлено: 07 май 2023, 02:38
prospa
no i could not find the fix yet.
В этой теме нет новых непрочитанных сообщений. Gigabyte ga-z170-hd3p нет запуска
в форуме Gigabyte
sokolov_yuri
12
2469
03 мар 2021, 12:25
sokolov_yuri Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ga-f2a88xm-hd3p не запускается
в форуме Gigabyte
dobry
07 июн 2022, 11:55
dobry Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Опознать м/сх на Z370 HD3P
в форуме Gigabyte
HeXakep
16 окт 2022, 08:20
HeXakep Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASRock Z170 Extreme 4 нет VCORE
в форуме ASRock
the.inspector
13
2725
17 фев 2021, 10:25
the.inspector Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asrock Z170 Extreme6+ не запускается
в форуме ASRock
corvoron
07 июл 2017, 19:15
deymon Перейти к последнему сообщению
