Заголовок сообщения: Need help for my Asus P8H61-M LE
Добавлено: 17 ноя 2016, 16:38
Зарегистрирован: 18 окт 2016, 20:05 Наличности на руках: -37.98 Сообщения: 31 Откуда: Serbia Заблокирован
Hi guys is just got this mobo , had a problem with short to ground on cpu mosfet, so i change it. The problem is i got this G530 and the guy who give it me is not sure that is working! Now am having a problem, cause my mobo is starting but now give any image, or posts, beeps! And am not sure is it mobo or cpu.
And the thing is i want it to ask, am getting 1.9v on reset button or O_RSTCON#_PR. Should this voltage be 3.3v and not 1.9v ????
If anyone is having this board can you take a quick look and measure it!
Thanks in advanced!
LidiaArkadievna
Заголовок сообщения: Re: Need help for my Asus P8H61-M LE
~1 V on pin O_RSTCON#_PR
De La Ghetto
