Текущее время: 21 ноя 2024, 13:20
 Заголовок сообщения: Asrock z97 Pro3 .... ethernet damage kill the board
СообщениеДобавлено: 09 июн 2024, 19:21
I have this z97 board, part of a lot I bought .... the seller said a lightening kill the board through ethernet. I do not trust what people says, but this time it seems that something kills the ethernet controller (dead short).
Anyway, I remove the controller but the board is still completely dead. So, I am throubleshooting PCH and EC chip .... from what I saw, 3,3v was present on both ...
Does anyone remember the correct sequence wiht a z97 chipset?
What about pch voltage? Is it required any other voltage but 3,3v?
TIA
 Заголовок сообщения: Re: Asrock z97 Pro3 .... ethernet damage kill the board
СообщениеДобавлено: 10 июн 2024, 21:32
Could someone explain to me why I find differences between power sequence in various documentations?
They are from different board with difference SIO e PCH, but, I tought the sequence was time same ...
Here ... ASUS
you press the power button ... then you have S_SLPS3# and S_SLPS4# from pch to SIO.
Gigabyte ...
SLP3# and SLP4# come before you press the power button !!?!?
Wistron ... same as ASUS
Asus training material .... consistent with pwrbtn before SLP_S3# and 4
My guess is gigabyte is wrong.
СообщениеДобавлено: 26 июл 2024, 11:05
saronno Well, I have say Asus boards with embedded TPU always rise up SLP_S3#, S4# before PWRBTN# if u run 'em the 1st time after u replace or remove 2032 battery. Like, Z77, Z170, Z270, Z370. I checked it out on Z77-V, -V-Pro, Z87 SaberTooth, Z170-A, rog strix Z270E, -F, -G, Z370F, -G boards. If bios/uefi 'd run correctly and the board got initialized, SLP_S3#, SLP_S4# would rised up after PWRBTN#. Why Gigabyte painted it like that I dunno).
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G510 (LA-9641P REV 1.0) After liquid damage
dominik555
17 мар 2015, 15:18
dominik555 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. satellite (p750) Nescafe damage
в форуме Toshiba
genxsoft
20 июл 2015, 23:32
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Apple Macbook Pro A1278 (K90i, 820-2936) another motherboard with water damage issue
в форуме Apple
andromedax
22 окт 2015, 20:12
В этой теме нет новых непрочитанных сообщений. U46SV (Asus) Water damage
NoLuck
11 фев 2017, 22:05
Гектор Перейти к последнему сообщению
Сейчас этот форум просматривают: Sivixman1337 и гости: 9
