asrock b550 taichi any boardview available? https://vlab.su/viewtopic.php?f=244&t=144421 |
ilie321 [ 19 сен 2024, 11:28 ] | |
Заголовок сообщения: | asrock b550 taichi any boardview available? |
Hello i need the boardview for b550 taichi thank you it is starting boot sequence then stop at F3 for few seconds then pass trough 4-5 codes very fast and shoutdown; anyone has ideea what is wrong (i think last code is 21 before power off) ; i use 1 single good ram 8gb cpu 3200g with no gpu or separate gpu same problem; i updated bios to last stable version from asrock by flashback; i clereared cmos no image nothing all voltages seams fine |
ilie321 [ 20 сен 2024, 08:05 ] | |
Заголовок сообщения: | Re: asrock b550 taichi any boardview available? |
solved seams i had some problems with graphics card even if on other pc is working here didn't want to work ; strange behavior ; the board shutdown if not detecting it or something |
