sony KDL-50W829 motherboard T500HVN08.0 CTRL-BD https://vlab.su/viewtopic.php?f=247&t=62389 |
notemaster [ 10 июн 2017, 12:16 ] | |
Заголовок сообщения: | sony KDL-50W829 motherboard T500HVN08.0 CTRL-BD |
hi, I need bios to TV Sony KDL-50W829. |
gserg [ 10 июн 2017, 12:55 ] | |
Заголовок сообщения: | Re: sony KDL-50W829 motherboard T500HVN08.0 CTRL-BD |
это не материнка, это T-CON, прёмная часть порта LVDS, прошивка ищется по модели матрицы. ---------- Добавлено спустя 3 минуты 17 секунд: ---------- и если у вас искажены цвета, то шить ничего не надо , поменяйте гаммакоректор. |
notemaster [ 22 июн 2017, 10:31 ] | |
hi, I have problem with TV on. After conect AC, I see on my power supply that TV start to 0.50A and after few secend is off.Only red light is pulsar on stay by. I have 3.3V on power button. I had damaged power supply after storm. I need program bios. |
Avenger_kz [ 27 июл 2017, 22:34 ] | |
notemaster писал(а): Only red light is pulsar on stay by Hi If blinks 5 times - no panel response. If LVDS cable without damage and all voltages level is normal, you can try downloading update files from official site to recovery your TV. Download update files from this link: Aktualizacja oprogramowania układowego do wersji v3.004 Copy files to USB drive (FAT32/NTFS). Install USB drive on TV and power on. If yellow led begin blinking - system update started. Please wait some time. May be its help you. ![]() |
