<0>GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 1721722
BL2 Built : 19:41:49, Jun 20 2016.
gxl ge299011 - xiaobo.gu@droid05
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 1
CPU clk: 1200MHz
DDR3 chl: Rank0+1 @ 720MHz - PASS
DQS-corr enabled
DDR scramble enabled
Rank0: 1024MB(auto)-2T-11
Rank1: 1024MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x10100000, size: 0x00014400
Load bl33 from SD, src: 0x00038200, des: 0x01000000, size: 0x000a8000
NOTICE: BL3-1: v1.0(debug):c813a61
NOTICE: BL3-1: Built : 14:39:44, Jun 16 2016
aml log : bl31 normal boot !
[Image: gxl_v1.1.3137-2517a7a 2016-06-24 11:31:11 xing.xu@droid05]
OPS=0x82
8f c4 54 95 9c af 46 47 63 bf 77 f6 [2.109221 Inits done]
secure task start!
high task start!
low task start!
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01 (Aug 05 2016 - 17:09:26)
DRAM: 2 GiB
Relocation Offset is: 76ecb000
register usb cfg[0][1] = 0000000077f5faf0
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000073ecb6b0
aml_priv->desc_buf = 0x0000000073ecd9d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
MMC init failed
Using default environment
In: serial
Out: serial
Err: serial
reboot_mode=cold_boot
hpd_state=0
cvbs performance type = 6, table = 0
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
mmc init failed
Amlogic multi-dtb tool
Cannot find legal dtb!
[store]Err:do_store_dtb_ops,L231:Fail in fdt check header
board_late_init(): [store dtb read $dtb_mem_addr] fail
load dtb to 1000000
[store]To run cmd[emmc dtb_read 1000000 0x40000]
read emmc dtb
mmc init failed
board_late_init(): store dtb read 1000000 fail
card in
[mmc_init] mmc init success
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.2 GiB
mmc clock: 40000000
Bus Width: 4-bit
[MSG]ini sz 0x25aB
[fat]Filesize is 0x25aB[0M]
[fat]0x:leftSz 25a < BPS 4000, gotSz 25a
=========sdc_burn_paras=====>>>
[common]
erase_bootloader = 1
erase_flash = 1
reboot = 0x1
key_overwrite = 0x0
[burn_ex]
package = aml_upgrade_package.img
media =
[burn_parts]
burn_num = 0
<<<<=====sdc_burn_paras======
[fat]Filesize is 0x3ae151a8B[942M]
[fat]0x:leftSz 2c40 < BPS 4000, gotSz 6c40
[MSG]image version [0x00000002]
[fat]Seek 0xbaeeec from 0x6c40
[MSG]itemSizeNotAligned 0x1114
[MSG]align 4 mmc read... [fat]0x:leftSz 26ec < BPS 4000, gotSz 13800
[MSG]Down(mem) part(dtb) sz(0x13800) fmt(normal)
[MSG]Burn Start...
[MSG]load dt.img to 0x0000000001000000, sz=0x13800
[MSG]Burn complete
Err imgread(L472):Logo header err.
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store store init flag
store read name addr off|partition size
read 'size' bytes starting at offset 'off'
to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
write 'size' bytes starting at offset 'off'
store rom_write add off size.
write uboot to the boot device
store erase boot/data:
erase the area which is uboot or data
store erase dtb
store erase key
store rom_protect on/off
store scrub off|partition size
scrub the area from offset and size
store dtb iread/read/write addr <size>
read/write dtb, size is optional
store key read/write addr <size>
read/write key, size is optional
cmd store failed
Err imgread(L248):Fail to read 0x100000B from part[logo] at offset 0
[MSG]Use upgrade res in pkg
[WRN]Can't find item [logo, aml_sdc_burn]
[MSG]logo for sdc UPGRADE[PARTITION]
[MSG]itemSizeNotAligned 0x704
[MSG]align 4 mmc read... [fat]0x:leftSz 2ebc < BPS 4000, gotSz 11b5c0
[MSG]echo video prepare for upgrade
hpd_state=0
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]addr=0x3d800000 width=3840, height=2160
[MSG]dw,dh[1920, 1080]
[MSG]w,h[4,14]
[MSG]Exit before re-init
command: store exit
Multi dtb detected
Multi dtb tool version: v2 .
Support 2 dtbs.
aml_dt soc: gxl platform: p212 variant: 2g
dtb 0 soc: gxl plat: p212 vari: 1g
dtb 1 soc: gxl plat: p212 vari: 2g
Find match dtb: 1
start dts,buffer=0000000001000000,dt_addr=000000000100a000
parts: 11
00: logo 0000000002000000 1
01: recovery 0000000002000000 1
02: rsv 0000000000800000 1
03: tee 0000000000800000 1
04: crypt 0000000002000000 1
05: misc 0000000002000000 1
06: instaboot 0000000020000000 1
07: boot 0000000002000000 1
08: system 0000000040000000 1
09: cache 0000000020000000 2
10: data ffffffffffffffff 4
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.2 GiB
mmc clock: 40000000
Bus Width: 4-bit
[store]amlmmc erase 1emmc/sd response timeout, cmd8, status=0x1ff2800
emmckey_is_protected : protect
cmd [store] init failed
ERR(../drivers/usb/gadget/v2_burning/v2_sdc_burn/optimus_sdc_burn.c)L648:Fail to init stoarge for sdc burn
Net: dwmac.c9410000
wipe_data=successful
wipe_cache=successful
upgrade_step=0
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
Err imgread(L333):Fail to read 0x2000B from part[logo] at offset 0
[KM]Error:f[keymanage_dts_parse]L255:not a fdt at 0x0000000001000000
gpio: pin GPIOAO_2 (gpio 102) value is 1
get_cpu_id flag_12bit=1
detect sadckey ....
saradc - saradc sub-system
Usage:
saradc saradc open <channel> - open a SARADC channel
saradc close - close the SARADC
saradc getval - get the value in current channel
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
Hit Enter or space or Ctrl+C key to stop autoboot -- : 0
Booting...
Unknown command 'unifykey' - try 'help'
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
Err imgread(L132):Fail to read 0x100000B from part[boot] at offset 0
InUsbBurn
noSof
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.2 GiB
mmc clock: 40000000
Bus Width: 4-bit
[MSG]ini sz 0x25aB
[common]
erase_flash = 1
reboot = 0x1
key_overwrite = 0x0
[burn_ex]
media =
[burn_parts]
burn_num = 0
[MSG]Burn Start...
[MSG]Burn complete
hpd_state=0
[MSG]w,h[4,14]
command: store exit
Multi dtb detected
Support 2 dtbs.
Find match dtb: 1
parts: 11
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.2 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.2 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading aml_autoscript
** Unable to read file aml_autoscript **
reading recovery.img
11255808 bytes read in 629 ms (17.1 MiB/s)
reading dtb.img
** Unable to read file dtb.img **
get partition info failed !!
amlmmc - AMLMMC sub system
Usage:
amlmmc read <partition_name> ram_addr addr_byte# cnt_byte
amlmmc write <partition_name> ram_addr addr_byte# cnt_byte
amlmmc erase <partition_name> addr_byte# cnt_byte
amlmmc erase <partition_name>/<device num>
amlmmc rescan <device_num>
amlmmc part <device_num> - show partition infomation of mmc
amlmmc list - lists available devices
amlmmc switch <device_num> <part name> - part name : boot0, boot1, user
amlmmc status <device_num> - read sd/emmc device status
amlmmc response <device_num> - read sd/emmc last command response
amlmmc controller <device_num> - read sd/emmc controller register
Usage:
store erase dtb
store erase key
cmd store size failed
can not get instaboot part size
wipeisb - wipeisb
Usage:
wipeisb wipe the insaboot image header
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =73ef0270
copy done
Multi dtb detected
Support 2 dtbs.
Find match dtb: 1
load dtb from 0x100a000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x020c0770
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[rsvmem] fdt addr error.
Loading Ramdisk to 73b0d000, end 73eb8494 ... OK
Loading Device Tree to 000000001fff3000, end 000000001ffff245 ... OK
Usage:
Usage:
store erase dtb
store erase key
fdt_instaboot: no instaboot image
Starting kernel ...
uboot time: 26278542 us
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.14.29 (it01@ubuntu) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #2 SMP PREEMPT Wed Aug 31 22:23:05 CST 2016
[ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000@0] no prop version_code
[ 0.000000@0] bootconsole [earlycon0] enabled
[ 0.000000@0] fdt Reserved memory table:
[ 0.000000@0] linux,meson-fb: 0x000000007e000000 - 0x0000000080000000 (32 MiB)
[ 0.000000@0] linux,di: 0x000000007c200000 - 0x000000007e000000 (30 MiB)
[ 0.000000@0] DI: DI reserved memory: created CMA memory pool at 0x000000007c200000, size 30 MiB
[ 0.000000@0] linux,ion-dev: 0x000000007a200000 - 0x000000007c200000 (32 MiB)
[ 0.000000@0] linux,ppmgr: 0x0000000078200000 - 0x000000007a200000 (32 MiB)
[ 0.000000@0] linux,codec_mm_cma: 0x0000000066800000 - 0x0000000073800000 (208 MiB)
[ 0.000000@0] linux,picdec: 0x0000000078200000 - 0x0000000078200000 (0 MiB)
[ 0.000000@0] Reserved memory: incorrect alignment of CMA region
[ 0.000000@0] linux,codec_mm_reserved: 0x0000000074100000 - 0x0000000078200000 (65 MiB)
[ 0.000000@0] fdt Reserved memory total: 402 MiB
[ 0.000000@0] cma: Reserved 8 MiB at 66000000
[ 0.000000@0] psci: probing function IDs from device-tree
[ 0.000000@0] PERCPU: Embedded 12 pages/cpu @ffffffc0740a1000 s19328 r8192 d21632 u49152
[ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 502232
[ 0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive androidboot.selinux=enforcing logo=osd1,loaded,0x3d800000,576cvbs maxcpus=4 vout=576cvbs,enable hdmimode=1080p60hz cvbsmode=576cvbs hdmitx= cvbsdrv=0 androidboot.firstboot=1 jtag=apee androidboot.hardware=amlogic aml_dt=gxl_p212_2g recovery_part={recovery_part} recovery_offset={recovery_offset}
[ 0.000000@0] logo: osd1
[ 0.000000@0] logo: loaded
[ 0.000000@0] logo: 0x3d800000
[ 0.000000@0] logo: 576cvbs
[ 0.000000@0] vout_serve: 576cvbs: 7
[ 0.000000@0] vout_serve: enable: 1
[ 0.000000@0] logo: get hdmimode: 1080p60hz
[ 0.000000@0] logo: get cvbsmode: 576cvbs
[ 0.000000@0] tv_vout: cvbs performance line = 0
[ 0.000000@0] jtag: jtag select 3
[ 0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000@0] Memory: 1592184K/2044928K available (10492K kernel code, 1141K rwdata, 3836K rodata, 1162K init, 5877K bss, 452744K reserved)
[ 0.000000@0] Virtual kernel memory layout:
[ 0.000000@0] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB)
[ 0.000000@0] vmemmap : 0xffffff8040010000 - 0xffffff8042380000 ( 35 MB)
[ 0.000000@0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000@0] memory : 0xffffffc000000000 - 0xffffffc07e000000 ( 2016 MB)
[ 0.000000@0] .init : 0xffffffc001e80000 - 0xffffffc001fa2b80 ( 1163 kB)
[ 0.000000@0] .text : 0xffffffc001080000 - 0xffffffc001e7f214 ( 14333 kB)
[ 0.000000@0] .data : 0xffffffc001fa3000 - 0xffffffc0020c0770 ( 1142 kB)
[ 0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01e7efff]
[ 0.000000@0] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000@0] arch_multi_cluster:0
[ 0.000000@0] Preemptible hierarchical RCU implementation.
[ 0.000000@0] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000@0] NR_IRQS:64 nr_irqs:64 0
[ 0.000000@0] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000004@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[ 0.008511@0] Console: colour dummy device 80x25
[ 0.012870@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.023448@0] pid_max: default: 32768 minimum: 301
[ 0.028338@0] Security Framework initialized
[ 0.032560@0] SELinux: Initializing.
[ 0.036315@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.043144@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.052786@0] device-tree: Duplicate name in /efusekey, renamed to "key0#1"
[ 0.057525@0] device-tree: Duplicate name in /efusekey, renamed to "key1#1"
[ 0.064488@0] device-tree: Duplicate name in /efusekey, renamed to "key2#1"
[ 0.071495@0] device-tree: Duplicate name in /efusekey, renamed to "key3#1"
[ 0.081642@0] Initializing cgroup subsys debug
[ 0.082950@0] Initializing cgroup subsys freezer
[ 0.087617@0] ftrace: allocating 36230 entries in 142 pages
[ 0.133263@0] /cpus/cpu@0: Missing clock-frequency property
[ 0.133305@0] /cpus/cpu@1: Missing clock-frequency property
[ 0.138889@0] /cpus/cpu@2: Missing clock-frequency property
[ 0.144515@0] /cpus/cpu@3: Missing clock-frequency property
[ 0.150089@0] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.198474@0] ftrace: Allocated trace_printk buffers
[ 0.200713@0] Meson chip version = RevA (21:A - 82:0)
[ 0.219078@1] CPU1: Booted secondary processor
[ 0.239071@2] CPU2: Booted secondary processor
[ 0.259090@3] CPU3: Booted secondary processor
[ 0.259177@0] Brought up 4 CPUs
[ 0.270149@0] SMP: Total of 4 processors activated.
[ 0.283188@0] sched: registering cpufreq notifiers for scale-invariant loads
[ 0.284716@0] instabooting: 0
[ 0.297728@0] pinctrl core: initialized pinctrl subsystem
[ 0.298446@0] regulator-dummy: no parameters
[ 0.302690@0] NET: Registered protocol family 16
[ 0.308501@0] ramoops: using module parameters
[ 0.311573@0] console [pstore-1] enabled
[ 0.314927@0] pstore: Registered ramoops as persistent store backend
[ 0.321290@0] ramoops: attached 0x100000@0x7300000, ecc: 0/0
[ 0.328222@0] aml_vdac_init: module init
[ 0.331127@0] register canvas platform driver
[ 0.335383@0] register rdma platform driver
[ 0.341283@0] vdso: 2 pages (1 code, 1 data) at base ffffffc001fac000
[ 0.345999@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.353640@0] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.360245@0] software IO TLB [mem 0x61c00000-0x62000000] (4MB) mapped at [ffffffc061c00000-ffffffc061ffffff]
[ 0.369261@0] Serial: AMBA PL011 UART driver
[ 0.374036@0] aml_i2c version: 20140813
[ 0.377633@0] i2c-core: driver [pmu4] using legacy resume method
[ 0.383625@0] codec_mm:codec_mm_module_init
[ 0.387866@0] aml_watch_point_probe, in
[ 0.391844@0] gxbb_mpll_clk: register mpll_clk_out0 success done
[ 0.397534@0] gxbb_mpll_clk: register mpll_clk_out1 success done
[ 0.403542@0] gxbb_mpll_clk: register mpll_clk_out2 success done
[ 0.409765@0] clk_sys: register PLL sys_pll success done
[ 0.414922@0] gxl_clk: [ xtal ] ->clockrate: 24000000Hz
[ 0.420259@0] gxl_clk: [ 32Khz ] ->clockrate: 32000Hz
[ 0.425415@0] gxl_clk: [ clk81 ] ->clockrate: 166666666Hz
[ 0.430933@0] gxl_clk: [ fixed_pll ] ->clockrate: 2000000000Hz
[ 0.436876@0] gxl_clk: [ fclk_div2 ] ->clockrate: 1000000000Hz
[ 0.442833@0] gxl_clk: [ fclk_div3 ] ->clockrate: 666666666Hz
[ 0.448689@0] gxl_clk: [ fclk_div4 ] ->clockrate: 500000000Hz
[ 0.454557@0] gxl_clk: [ fclk_div5 ] ->clockrate: 400000000Hz
[ 0.460414@0] gxl_clk: [ fclk_div7 ] ->clockrate: 285714285Hz
[ 0.466305@0] gxl_clk: clock initialization complete
[ 0.471468@0] clkmsr: Gxl msr_clk_reg0=ffffff800003a75c,msr_clk_reg2=ffffff800003c764
[ 0.481514@0] aml_iomap: amlogic iomap probe done
[ 0.484582@0] pinmux-gxl c1109880.pinmux: Init pinux probe!
[ 0.490448@0] pinmux-gxl c1109880.pinmux: Probed amlogic pinctrl driver
[ 0.496689@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc)
[ 0.504206@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc)
[ 0.512417@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc)
[ 0.520288@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc)
[ 0.530963@0] codec_mm has 2 memory regions
[ 0.532543@0] codec_mm codec_mm.19: assigned reserved memory node linux,codec_mm_cma ok
[ 0.540589@0] codec_mm codec_mm.19: assigned reserved memory node linux,codec_mm_reserved ok
[ 0.549186@0] codec_mm has 2 memory regions
[ 0.553285@0] codec_mm codec_mm.19: assigned reserved memory node linux,codec_mm_cma ok
[ 0.561306@0] codec_mm codec_mm.19: assigned reserved memory node linux,codec_mm_reserved ok
[ 0.571815@0] vpu: driver version: v02
[ 0.573576@0] vpu: load vpu_clk: 666667000Hz(7)
[ 0.578211@0] vpu: vpu_probe OK
[ 0.583135@0] tv_vout: tvout_probe
[ 0.584674@0] tv_vout: major number 254 for disp
[ 0.589301@0] vout_notify: vout_register_server
[ 0.593870@0] tv_vout: register tv module server ok
[ 0.598873@0] tv_vout: tvout_probe [ 0.909114@0] bio: create slab <bio-0> at 0
[ 0.910296@0] SCSI subsystem initialized
[ 0.912265@0] usbcore: registered new interface driver usbfs
[ 0.917469@0] usbcore: registered new interface driver hub
[ 0.923080@0] usbcore: registered new device driver usb
[ 0.929070@0] i2c-gpio i2c_gpio.38: using pins 172 (SDA) and 173 (SCL)
[ 0.934856@0] Linux video capture interface: v2.00
[ 0.939742@0] pps_core: LinuxPPS API ver. 1 registered
[ 0.944657@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.954229@0] PTP clock support registered
[ 0.958851@0] hdmitx: system: amhdmitx_init
[ 0.962334@0] hdmitx: system: Ver: 2014May6
[ 0.966719@0] hdmitx: system: amhdmitx_probe
[ 0.971159@0] hdmitx: system: not find match init-data
[ 0.975982@0] hdmitx: system: not find match pwr-ctl
[ 0.980989@0] hdmitx hpd irq = 89
[ 0.984813@0] hdmitx20: Mapped PHY: 0xc0800000
[ 0.988765@0] hdmitx20: Mapped PHY: 0xc1104400
[ 0.993265@0] hdmitx20: Mapped PHY: 0xc8100000
[ 0.997683@0] hdmitx20: Mapped PHY: 0xc8834000
[ 1.002145@0] hdmitx20: Mapped PHY: 0xc883a000
[ 1.006616@0] hdmitx20: Mapped PHY: 0xc883c000
[ 1.011074@0] hdmitx20: Mapped PHY: 0xd0100000
[ 1.015534@0] hdmitx20: Mapped PHY: 0xda83a000
[ 1.020237@0] avmute set to 1
[ 1.023387@0] vout_serve: vout_init_module
[ 1.027196@0] tv_vout: tv_set_current_vmode[756]fps_target_mode=7
[ 1.033235@0] tv_vout: mode is 7,sync_duration_den=1,sync_duration_num=50
[ 1.040034@0] tv_vout: already display in uboot
[ 1.044588@0] vout_serve: vinfo mode is: 576cvbs
[ 1.049218@0] vout_serve: init mode 576cvbs
[ 1.053543@0] vout_serve: create vout attribute OK
[ 1.058243@0] vout_serve: meson_vout_probe OK
[ 1.062820@0] logo: logo_init
[ 1.065863@0] osd_rdma: osd_rdma_init: rmda_table p=0x66041000,op=0x66041000 , v=0xffffff80000a9000
[ 1.075192@0] Advanced Linux Sound Architecture Driver Initialized.
[ 1.081646@0] Bluetooth: Core ver 2.18
[ 1.084899@0] NET: Registered protocol family 31
[ 1.089537@0] Bluetooth: HCI device and connection manager initialized
[ 1.095966@0] Bluetooth: HCI socket layer initialized
[ 1.101022@0] Bluetooth: L2CAP socket layer initialized
[ 1.106304@0] Bluetooth: SCO socket layer initialized
[ 1.111943@0] cfg80211: Calling CRDA to update world regulatory domain
[ 1.118056@0] NetLabel: Initializing
[ 1.121495@0] NetLabel: domain hash size = 128
[ 1.126043@0] NetLabel: protocols = UNLABELED CIPSOv4
[ 1.131427@0] NetLabel: unlabeled traffic allowed by default
[ 1.139092@0] Switched to clocksource arch_sys_counter
[ 1.189983@0] [amlatvdemod..]aml_atvdemod_init.
[ 1.190112@0] NET: Registered protocol family 2
[ 1.193996@0] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.201088@0] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.208159@0] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.214580@0] TCP: reno registered
[ 1.217916@0] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.224170@0] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.231169@0] NET: Registered protocol family 1
[ 1.235609@0] RPC: Registered named UNIX socket transport module.
[ 1.241462@0] RPC: Registered udp transport module.
[ 1.246494@0] RPC: Registered tcp transport module.
[ 1.251255@0] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.258095@0] aml_wifi wifi.32: [wifi_dev_probe] no power_on_pin2
[ 1.264033@0] aml_wifi wifi.32: [wifi_dev_probe] set pwm as 32k output
[ 1.270769@0] aml_wifi wifi.32: [wifi_dev_probe] dhd_static_buf setup
[ 1.277121@0] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allocated
[ 1.284708@0] aml_wifi wifi.32: [wifi_dev_probe] interrupt_pin=241
[ 1.291033@0] aml_wifi wifi.32: [wifi_dev_probe] irq_num=100, irq_trigger_type=1
[ 1.298324@0] aml_wifi wifi.32: [wifi_dev_probe] power_on_pin=240
[ 1.304457@0] aml_wifi wifi.32: [wifi_dev_probe] clock_32k_pin=0
[ 1.310936@0] aml_wifi wifi.32: [wifi_setup_dt] wifi_setup_dt
[ 1.316291@0] aml_wifi wifi.32: [wifi_setup_dt] interrupt_pin(241)
[ 1.322494@0] aml_wifi wifi.32: [wifi_setup_dt] power_on_pin(240)
[ 1.329139@0] Unpacking initramfs...
[ 1.467302@1] Freeing initrd memory: 3756K (ffffffc073b0d000 - ffffffc073eb8000)
[ 1.473896@0] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.475601@0] audit: initializing netlink subsys (disabled)
[ 1.481221@0] audit: type=2000 audit(1.310:1): initialized
[ 1.487742@0] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.501168@0] VFS: Disk quotas dquot_6.5.2
[ 1.501472@0] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.512809@0] NFS: Registering the id_resolver key type
[ 1.512875@0] Key type id_resolver registered
[ 1.516854@0] Key type id_legacy registered
[ 1.521093@0] jffs2: version 2.2. (NAND) (SUMMARY) A© 2001-2006 Red Hat, Inc.
[ 1.529418@0] fuse init (API version 7.22)
[ 1.533137@0] msgmni has been set to 3549
[ 1.538048@0] NET: Registered protocol family 38
[ 1.541520@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.548864@0] io scheduler noop registered
[ 1.552833@0] io scheduler deadline registered
[ 1.557519@0] io scheduler cfq registered (default)
[ 1.618180@0] meson-rng c8834000.rng: hwrng registered
[ 1.621998@0] loop: module loaded
[ 1.622655@0] zram: Created 1 device(s) ...
[ 1.626375@0] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.633149@0] tun: Universal TUN/TAP device driver, 1.6
[ 1.637187@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.648354@0] libphy: stmmac: probed
[ 1.648389@0] eth0: PHY ID 01814400 at 8 IRQ POLL (stmmac-0:08) active
[ 1.654335@0] PPP generic driver version 2.4.2
[ 1.658415@0] PPP BSD Compression module registered
[ 1.663097@0] PPP Deflate Compression module registered
[ 1.668507@0] PPP MPPE Compression module registered
[ 1.673339@0] NET: Registered protocol family 24
[ 1.678208@0] usbcore: registered new interface driver asix
[ 1.683738@0] usbcore: registered new interface driver ax88179_178a
[ 1.690218@0] usbcore: registered new interface driver cdc_ether
[ 1.696030@0] usbcore: registered new interface driver net1080
[ 1.701905@0] usbcore: registered new interface driver cdc_subset
[ 1.708156@0] usbcore: registered new interface driver zaurus
[ 1.713853@0] usbcore: registered new interface driver cdc_ncm
[ 1.719872@0] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.726261@0] ehci-h20ahb: H20AHB-EHCI Host Controller driver
[ 1.732506@0] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.738852@0] usbcore: registered new interface driver cdc_acm
[ 1.744297@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.752847@0] usbcore: registered new interface driver usb-storage
[ 1.758999@0] usbcore: registered new interface driver usbserial
[ 1.765567@0] amlogic-new-usb2 d0078000.usb2phy: USB2 phy probe:phy_mem:0xd0078000, iomap phy_base:0xffffff80000ec000
[ 1.775929@0] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port
[ 1.782295@0] amlogic-new-usb3 d0078080.usb3phy: USB3 phy probe:phy_mem:0xd0078080, iomap phy_base:0xffffff80000ee080
[ 1.793830@0] mousedev: PS/2 mouse device common for all mice
[ 1.799259@0] usbcore: registered new interface driver xpad
[ 1.804538@0] i2c /dev entries driver
[ 1.808516@0] usbcore: registered new interface driver uvcvideo
[ 1.813954@0] USB Video Class driver (1.1.1)
[ 1.819196@0] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised:
dm-devel@redhat.com[ 1.827153@0] Bluetooth: HCI UART driver ver 2.2
[ 1.831538@0] Bluetooth: HCI H4 protocol initialized
[ 1.837919@0] @@@@@@@@@@_____2______in dia_init()
[ 1.841251@0] ATVR driver - init called!
[ 1.[ 3.519344@1] aml_snd_card: headphone detection disable=1
[ 3.519381@1] aml_snd_card: no spk event delay time set
[ 3.524905@1] aml_snd_m8_card aml_m8_snd.47: T9015-audio-hifi <-> I2S.40 mapping ok
[ 3.532395@1] aml_snd_m8_card aml_m8_snd.47: dit-hifi <-> SPDIF.41 mapping ok
[ 3.539189@1] aml_snd_m8_card aml_m8_snd.47: pcm2bt-pcm <-> PCM.42 mapping ok
[ 3.546033@1] aml_snd_m8_card aml_m8_snd.47: ASoC: no source widget found for LOUTL
[ 3.553656@1] aml_snd_m8_card aml_m8_snd.47: ASoC: Failed to add route LOUTL -> direct -> Ext Spk
[ 3.562426@1] aml_snd_m8_card aml_m8_snd.47: ASoC: no source widget found for LOUTR
[ 3.570012@1] aml_snd_m8_card aml_m8_snd.47: ASoC: Failed to add route LOUTR -> direct -> Ext Spk
WARNING: Unimplemented Sip Call: 0x82000035
[ 3.691302@1] aml_snd_card: audio use jtag pinmux as i2s output, read val =ffffffff
WARNING: Unimplemented Sip Call: 0x82000036
[ 3.703491@1] GACT probability NOT on
[ 3.706406@1] Mirror/redirect action on
[ 3.710238@1] u32 classifier
[ 3.713034@1] Actions configured
[ 3.716574@1] Netfilter messages via NETLINK v0.30.
[ 3.721483@1] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.728147@1] ctnetlink v0.93: registering with nfnetlink.
[ 3.733676@1] xt_time: kernel timezone is -0000
[ 3.737620@1] ipip: IPv4 over IPv4 tunneling driver
[ 3.743219@1] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.747916@1] arp_tables: (C) 2002 David S. Miller
[ 3.752647@1] TCP: cubic registered
[ 3.755989@1] Initializing XFRM netlink socket
[ 3.761439@1] NET: Registered protocol family 10
[ 3.766089@1] mip6: Mobile IPv6
[ 3.768088@1] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.773850@1] sit: IPv6 over IPv4 tunneling driver
[ 3.779931@1] NET: Registered protocol family 17
[ 3.782939@1] NET: Registered protocol family 15
[ 3.787583@1] Bridge firewalling registered
[ 3.791783@1] Bluetooth: RFCOMM TTY layer initialized
[ 3.796627@1] Bluetooth: RFCOMM socket layer initialized
[ 3.801936@1] Bluetooth: RFCOMM ver 1.11
[ 3.805760@1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.811219@1] Bluetooth: BNEP filters: protocol multicast
[ 3.816546@1] Bluetooth: BNEP socket layer initialized
[ 3.821656@1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.827667@1] Bluetooth: HIDP socket layer initialized
[ 3.832840@1] l2tp_core: L2TP core driver, V2.0
[ 3.837243@1] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.842175@1] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 3.847869@1] l2tp_netlink: L2TP netlink interface
[ 3.852655@1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 3.858648@1] l2tp_debugfs: L2TP debugfs support
[ 3.863219@1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 3.869822@1] NET: Registered protocol family 35
[ 3.874393@1] Key type dns_resolver registered
[ 3.880583@1] Registering SWP/SWPB emulation handler
[ 3.884299@1] regulator-dummy: disabling
[ 3.887911@1] aml_vrtc rtc.31: setting system clock to 2015-01-01 00:00:30 UTC (1420070430)
[ 3.896930@1] cpufreq-scpi cpufreq-meson.7: enter cpufreq
[ 3.901330@1] cpufreq-scpi cpufreq-meson.7: probe cpufreq okay
[ 3.910139@0] gxbb_pm: enter meson_pm_probe!
[ 3.911370@0] gxbb_pm: meson_pm_probe done
[ 3.916098@0] cpucore_cooling_register, max_cpu_core_num:4
[ 3.936087@0] aml_istbt_dev_ready NULL
[ 3.9361?[ 3.940842@0] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[ 3.944179@0] Freeing unused kernel memory: 1160K (ffffffc001e80000 - ffffffc001fa2000)
[ 3.969267@1] init: init started!
[ 4.113603@1] audit: type=1403 audit(1420070430.720:2): policy loaded auid=4294967295 ses=4294967295
[ 4.117516@1] init: (Initializing SELinux non-enforcing took 0.15s.)
[ 4.130012@2] init: init second stage started!
[ 4.130397@2] init: property_set("ro.boot.selinux", "enforcing" failed
[ 4.166483@2] init: waitpid failed: No child processes
[ 4.167602@2] init: (Loading properties from /default.prop took 0.00s.)
[ 4.173247@2] init: /init.rc: 7: invalid command 'setcon'
[ 4.177955@2] init: /init.rc: 61: invalid command 'load_all_props'
[ 4.184209@2] init: (Parsing /init.recovery.amlogic.rc took 0.00s.)
[ 4.190277@2] init: (Parsing /init.rc took 0.02s.)
[ 4.194985@2] init: aml-firstboot-init insert aml-firstboot-init
[ 4.201019@2] init: Starting service 'ueventd'...
[ 4.207974@0] ueventd: ueventd started!
[ 4.739194@1] ueventd: Coldboot took 0.52s.
[ 4.915111@2] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.915159@2] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.923745@2] xhci-hcd xhci-hcd.0.auto: irq 62, io mem 0xc9000000
[ 4.931015@1] hub 1-0:1.0: USB hub found
[ 4.932849@1] hub 1-0:1.0: 2 ports detected
[ 4.937150@1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.942608@1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.952023@1] hub 2-0:1.0: USB hub found
[ 4.954239@1] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 4.962410@1] init: Waiting for /dev/.coldboot_done...
[ 4.966[ 4.972984@1] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[ 4.990874@1] file system registered
[ 4.991787@1] init: write_file: Unable to write to '/sys/class/android_usb/android0/enable': No such device
[ 4.998591@1] init: write_file: Unable to open '/sys/class/android_usb/android0/f_ffs/aliases': No such file or directory
[ 5.009480@1] android_usb: Cannot enable 'adb' (-22)init: Starting service 'healthd'...
[ 5.017593@1] init: Starting service 'recovery'...
[ 5.019963@3] healthd: No charger supplies found
[ 5.019975@3] healthd: No battery devices found
[ 5.031553@1] init: Starting service 'console'...
[ 5.033528@3] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 5.033545@3] systemcontrol: [ubootenv] Cannot read : -1.
[ 5.033555@3] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 5.033563@3] systemcontrol: [ubootenv] Cannot read : -1.
[ 5.033572@3] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 5.033580@3] systemcontrol: [ubootenv] Cannot read : -1.
[ 5.033590@3] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 5.033598@3] systemcontrol: [ubootenv] Cannot read : -1.
[ 5.033607@3] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 5.033615@3] systemcontrol: [ubootenv] Cannot read : -1.
[`[ 5.107057@2] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[ 5.108309@3] systemcontrol: /etc/mesondisplay.cfg:12: Expected keyword, got '/etc/mesondisplay.cfg:12'.systemcontrol: [ubootenv] ubootenv.var.hdmimode is not a ubootenv varible.
[ 5.108335@3] systemcontrol: [ubootenv] ubootenv.var.cvbsmode is not a ubootenv varible.
[ 5.108384@3] systemcontrol: [ubootenv] ubootenv.var.576i_x is not a ubootenv varible.
[ 5.108394@3] systemcontrol: [ubootenv] ubootenv.var.576i_y is not a ubootenv varible.
[ 5.108404@3] systemcontrol: [ubootenv] ubootenv.var.576i_w is not a ubootenv varible.
[ 5.108413@3] systemcontrol: [ubootenv] ubootenv.var.576i_h is not a ubootenv varible.
[ 5.108879@1] init: avc: denied { set } for property=sys.open.deepcolor scontext=u:r:recovery:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 5.109030@3] vout_serve: vmode set to 576cvbs
[ 5.109032@3] vout_serve: don't set the same mode as current
[ 5.109634@3] amhdmitx amhdmitx0: hdmitx20: stop14
[ 5.109685@3] amhdmitx amhdmitx0: hdmitx20: stop22
[ 5.109767@1] init: no such service 'hdcp_tx22'
[ 5.111947@3] systemcontrol: [ubootenv] ubootenv.var.digitaudiooutput is not a ubootenv varible.
[ 5.111964@3] systemcontrol: [ubootenv] bootenv do not init
[ 5.111973@3] systemcontrol:or: No such file or directory
[ 6.134472@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.139791@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.147526@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.152915@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.160658@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.165985@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.173769@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.179129@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.186855@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.192222@1] systemcontrol: [ubootenv] read failed
[ 6.197258@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.204999@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.210342@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.218078@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.223447@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.231210@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.236537@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.244319@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.249666@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.257408@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.262774@1] systemcontrol: [ubootenv] read failed
[ 6.267797@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.275553@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.280890@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.288630@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.294000@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.301763@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.307090@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.314869@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.320220@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.327961@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.333329@1] systemcontrol: [ubootenv] read failed
[ 6.338349@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.346104@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.351443@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.359206@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.364532@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.372314@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.377642@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.385425@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.390777@1] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 6.398513@1] systemcontrol: [ubootenv] Cannot read : -1.
[ 6.403879@1] systemcontrol: [ubootenv] read failed
[ 6.412198@1] fb: Frame buffer memory assigned at
[ 6.413349@1] fb: 0, phy: 0x000000007e000000, vir:0xffffff8001d80000, size=24576K
[ 6.413349@1]
[ 6.422746@1] fb: ---------------clear fb0 memory ffffff8001d80000
[ 6.438756@1] fb: osd[0] canvas.idx =0x40
[ 6.438773@1] fb: osd[0] canvas.addr=0x7e000000
[ 6.441969@1] fb: osd[0] canvas.width=7680
[ 6.445668@1] fb: osd[0] canvas.height=3240
[ 6.449832@1] fb: osd[0] frame.width=1920
[ 6.453775@1] fb: osd[0] frame.height=1080
[ 6.506396@0] fb: osd[0] canvas.idx =0x40
[ 6.506544@0] fb: osd[0] canvas.addr=0x7e000000
[ 6.506547@0] fb: osd[0] canvas.width=7680
[ 6.506548@0] fb: osd[0] canvas.height=2160
[ 6.506549@0] fb: osd[0] frame.width=1920
[ 6.506551@0] fb: osd[0] frame.height=1080
[ 6.545588@0] fb: osd[0] enable: 0 (recovery)
[ 6.549852@0] fb: osd[0] enable: 1 (recovery)
[ 7.146593@0] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.148782@0] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.154144@0] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.161895@0] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.167347@0] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.175009@0] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.180355@0] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.188210@0] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.193464@0] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.201223@0] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.206667@0] systemcontrol: [ubootenv] read failed
[ 7.446457@2] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.448674@2] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.454063@2] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.461772@2] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.467100@2] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.474877@2] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.480219@2] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.487973@2] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.487983@2] systemcontrol: [ubootenv] open devices error: No such file or directory
[ 7.487991@2] systemcontrol: [ubootenv] Cannot read : -1.
[ 7.487999@2] systemcontrol: [ubootenv] read failed
[ 37.646366@0] random: nonblocking pool is initialized
