Планшет принесли в дроидбуте . Прошивок никаких не принимал , писал что нет свободного места .
Выпаял флешку и на прграмматор . Считал BOOT1 , BOOT1 , ECSD_CSD , RPMB и первые 16 кб UserData .
Взял юзаную но рабочую флешку самсунг , тоже на 16 гб , прочитал отчет об ней -
APP Version : 12.50 Model : T56 MFG:2022-03-06
Device : KMV3W000LM-B310(ISP)_4Bit
1 Programmer Connected.
Device 1: XGecu T56 Ver: 00.01.68
USB POWER VOLTAGE: 04.88V
USB SPEED MODE: HS 480MHZ
< Analysis IC >
* Clock Frequence is 8.000 MHZ *
1..Emmc Initialization ......
OCR register : C0FF8080
2..Read device CID .......Successed
3..Read device CSD .......Successed
4..Read device ECSD ......Successed
<1> -- Production Info.and Device life time--
MID : 15
PNM : V3W00M
Product Date : 6-2014
Version : MMC V4.5/4.51
Device life time Type A : Not defined
Device life time Type B : Not defined
Device life time (PRE_EOL_INFO) : Not Defined
<2> -- Partition Size Info.--
BOOT1 SIZE : 4096 KB
BOOT2 SIZE : 4096 KB
RPMB SIZE : 4096 KB
GPP1 SIZE : 0 KB
GPP2 SIZE : 0 KB
GPP3 SIZE : 0 KB
GPP4 SIZE : 0 KB
USER SIZE : 15,267,840 KB
( 0x 03_A3E0_0000 )
<3> -- RPMB Security and Password --
Authentication Key not yet programmed, RPMB not used
Password Protect Features : YES
Password Protected : Not Locked
<4> -- Write Protection --
ERASE_GROUP_DEF : 00
Disable PERM_WP_PROTECT : No
User Permanent protection: Enable
Whole Chip Permanent Protect : Not protected
Whole Chip Temporary Protect : Not protected
BOOT1 Write Protection Status : Not protected
BOOT2 Write Protection Status : Not protected
Write Protect Group Size : 0x800000 ( 8192 KB )
User Write Protection Group (0=Not Protected TE=Temp Protected PO=Power On Protected PE=Permanently Protected)
WPG Start Addr. 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
00000 00-00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
00032 00-10000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
01856 03-A0000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
USER Partiton --- Not any Write Protected . Total Write Protect Groups : 1863
<5> -- other Informations --
MAX_READ_BL_LEN : 512 bytes
MAX_WRITE_BL_LEN : 512 bytes
MAX_TRAN_SPEED : 55.000 MHZ
BOOT_BUS_CONDITIONS[177] : 00
BOOT_CONFIG_PROT[178] : 00
PARTITION_CONFIG[179] : 48
RST_n_FUNCTION[162] : 01
PARTITIONING_SUPPORT[160] : 07
ENH_START_ADDR : 00000000
ENH_SIZE_MULT : 000000
MAX_ENH_SIZE_MULT : 0003A3
PARTITIONS_ATTRIBUTE : 00
WR_REL_SET : 1F
WR_REL_PARAM : 04
PARTITION_SETTING_COMPLETED : 00
HC_WP_GRP_SIZE : 16
HC_ERASE_GRP_SIZE : 1
WP_GRP_ENABLE : 1
WP_GRP_SIZE : 15
ERASE_GRP_MULT : 31
ERASE_GRP_SIZE : 31
CCC : 00F5
DSR implemented : 0
PARTITION_ACCESS : 10 ms
ERASED_MEM_CONT : 00
DYNCAP_NEEDED : 00
SECURE_WP_INFO : 00
SEC_ERASE_MULT : 1B
ERASE_TIMEOUT_MULT: 01
NATIVE_SECTOR_SIZE: 00 (512B)
INI_TIMEOUT_AP : 3000 ms
INI_TIMEOUT_EMU : 0 ms
<6> -- Result -- View More Information in ECSD and CSD
1 . BOOT1 Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
2 . BOOT2 Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
3 . GPP1 GPP2 GPP3 GPP4 The Partition Invalid
4 . USER Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
5 . RPMB Partition is Blank, not be Used.
6 . This chip's content can be completely copied to another chip .
Записал все , кроме RPMB и поставил в планшет .
XFSTK шьет без ошибок , но droidboot не грузит .
лог
xfstklog_Чт_6._апр_03-29-30_2023.txt
03:28:55 - XFSTK Downloader API 1.7.0 Copyright (c) 2014 Intel Corporation
03:28:55 - fwdnx -- C:/debrick380/dnx_fwr.bin
03:28:55 - fwimage -- C:/debrick380/FE380CXG_32_IFWI_v79.54_CRAK_DEV.bin
03:28:55 - osdnx -- C:/debrick380/dnx_osr.bin
03:28:55 - osimage -- C:/debrick380/os_image.bin
03:28:55 - gpflags -- 0x80000807
03:28:55 - XFSTK-LOG--virtual bool MerrifieldDownloader::SetDevice(IGenericDevice*)
03:28:55 - Initiating download...
03:28:55 - XFSTK-LOG--virtual bool MerrifieldDownloader::UpdateTarget()
03:28:55 - XFSTK-LOG--FWDnxPath -- C:/debrick380/dnx_fwr.bin
03:28:55 - XFSTK-LOG--FWImagePath -- C:/debrick380/FE380CXG_32_IFWI_v79.54_CRAK_DEV.bin
03:28:55 - XFSTK-LOG--OSDnxPath -- C:/debrick380/dnx_osr.bin
03:28:55 - XFSTK-LOG--OSImagePath -- C:/debrick380/os_image.bin
03:28:55 - XFSTK-LOG--MiscDnxPath -- C:/debrick380/dnx_fwr.bin
03:28:55 - XFSTK-LOG--MiscBinPath -- BLANK.bin
03:28:55 - XFSTK-LOG--Gpflags -- 80000807
03:28:55 - XFSTK-LOG--DebugLevel -- ffffffff
03:28:55 - XFSTK-LOG--UsbDelay ms -- 0
03:28:55 - XFSTK-LOG--TransferType -- USB
03:28:55 - XFSTK-LOG--WipeIFWI -- False
03:28:55 - XFSTK-LOG--Idrq -- False
03:28:55 - XFSTK-LOG--Verbose -- True
03:28:55 - XFSTK-LOG--void MerrifieldDownloader::Init()
03:28:55 - XFSTK-LOG--Open
03:28:55 - XFSTK-LOG--USB Device found - USBSN: 5E62D801C71379C2E88613EFB6184A7B Address:4
03:28:55 - XFSTK-LOG--void MerrifieldDownloader::do_update(MerrifieldOptions*)
03:28:55 - XFSTK-LOG--Start
03:28:55 - XFSTK-LOG--Sending DnER...
03:28:55 - XFSTK-LOG--WriteOutPipe DnER
03:28:55 - XFSTK-LOG--WriteOutPipe 0
03:28:55 - XFSTK-LOG--Write --->DnER
03:28:55 - XFSTK-LOG--GetOpCode
03:28:55 - XFSTK-LOG--ReadInAck
03:28:55 - XFSTK-LOG--GetAck - DFRM(4)
03:28:55 - XFSTK-LOG--Visit
03:28:55 - XFSTK-LOG--FW: Handle virgin part DnX ...
03:28:55 - XFSTK-LOG--Changing to DLDR_STATE_FW_NORMAL ...
03:28:55 - XFSTK-LOG--InitNoSize
03:28:55 - XFSTK-LOG--CheckFile
03:28:55 - XFSTK-LOG--C:/debrick380/dnx_fwr.bin size:109944 bytes
03:28:55 - XFSTK-LOG--InitFwImage
03:28:55 - XFSTK-LOG--allocating buffers for FW images...
03:28:55 - XFSTK-LOG--C:/debrick380/FE380CXG_32_IFWI_v79.54_CRAK_DEV.bin size:4194468 bytes
03:28:55 - XFSTK-LOG--allocating buffers for primary/secondary security FW images...
03:28:55 - XFSTK-LOG--loading buffers for FW images...
03:28:55 - XFSTK-LOG--loading buffers for FUPH...
03:28:55 - XFSTK-STATUS--FW download is in progress ...
03:28:55 - XFSTK-LOG--StartFw
03:28:55 - XFSTK-LOG--sending 6 DWORDS of DnxFW size and checksum...
03:28:55 - XFSTK-LOG--WriteOutPipe x
03:28:55 - XFSTK-LOG--Write --->x
03:28:55 - XFSTK-LOG--LogProgress
03:28:55 - XFSTK-LOG--End of MrfdStHandleFwNormal
03:28:55 - XFSTK-LOG--GetAck - DCFI00(6)
03:28:55 - XFSTK-STATUS--FW: Sending DnX DCFI00 ...
03:28:55 - XFSTK-LOG--WriteOutPipe __BINARY__
03:28:55 - XFSTK-LOG--Write --->__BINARY__
03:28:55 - XFSTK-LOG--GetAck - DXBL(4)
03:28:55 - XFSTK-LOG--FW: Sending DnX ...
03:28:55 - XFSTK-LOG--FwDXBL
03:28:55 - XFSTK-LOG--Sending FW Dnx data...6214040
03:28:55 - XFSTK-LOG--GetAck - RUPHS(8)
03:28:55 - XFSTK-LOG--FW: Sending FW Update Profile Hdr Size...
03:28:55 - XFSTK-LOG--WriteOutPipe ¤
03:28:55 - XFSTK-LOG--Write --->¤
03:28:55 - XFSTK-LOG--GetAck - RUPH(4)
03:28:55 - XFSTK-LOG--FW: Sending FW Update Profile Hdr...
03:28:55 - XFSTK-LOG--GetAck - DIFWI00(8)
03:28:55 - XFSTK-LOG--GetAck - DIFWI01(8)
03:28:55 - XFSTK-LOG--GetAck - DIFWI02(8)
03:28:55 - XFSTK-LOG--GetAck - DIFWI03(8)
03:28:55 - XFSTK-LOG--GetAck - DIFWI04(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI05(8)
03:28:56 - XFSTK-LOG--WriteOutPipe __BINARY__
03:28:56 - XFSTK-LOG--WriteOutPipe 0
03:28:56 - XFSTK-LOG--Write --->__BINARY__
03:28:56 - XFSTK-LOG--LogProgress
03:28:56 - XFSTK-LOG--GetOpCode
03:28:56 - XFSTK-LOG--ReadInAck
03:28:56 - XFSTK-LOG--GetAck - DIFWI06(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI07(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI08(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI09(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI10(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI11(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI12(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI13(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI14(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI15(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI16(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI17(8)
03:28:56 - XFSTK-LOG--GetAck - DIFWI18(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI19(8)
03:28:57 - XFSTK-LOG--WriteOutPipe __BINARY__
03:28:57 - XFSTK-LOG--WriteOutPipe 0
03:28:57 - XFSTK-LOG--Write --->__BINARY__
03:28:57 - XFSTK-LOG--LogProgress
03:28:57 - XFSTK-LOG--GetOpCode
03:28:57 - XFSTK-LOG--ReadInAck
03:28:57 - XFSTK-LOG--GetAck - DIFWI20(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI21(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI22(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI23(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI24(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI25(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI26(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI27(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI28(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI29(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI30(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI31(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI00(8)
03:28:57 - XFSTK-LOG--GetAck - DIFWI01(8)
03:28:58 - XFSTK-LOG--LogProgress
03:28:58 - XFSTK-LOG--GetOpCode
03:28:58 - XFSTK-LOG--ReadInAck
03:28:58 - XFSTK-LOG--GetAck - DIFWI02(8)
03:28:58 - XFSTK-LOG--WriteOutPipe __BINARY__
03:28:58 - XFSTK-LOG--WriteOutPipe 0
03:28:58 - XFSTK-LOG--Write --->__BINARY__
03:28:58 - XFSTK-LOG--GetAck - DIFWI03(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI04(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI05(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI06(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI07(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI08(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI09(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI10(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI11(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI12(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI13(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI14(8)
03:28:58 - XFSTK-LOG--GetAck - DIFWI15(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI16(8)
03:28:59 - XFSTK-LOG--WriteOutPipe __BINARY__
03:28:59 - XFSTK-LOG--WriteOutPipe 0
03:28:59 - XFSTK-LOG--Write --->__BINARY__
03:28:59 - XFSTK-LOG--LogProgress
03:28:59 - XFSTK-LOG--GetOpCode
03:28:59 - XFSTK-LOG--ReadInAck
03:28:59 - XFSTK-LOG--GetAck - DIFWI17(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI18(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI19(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI20(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI21(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI22(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI23(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI24(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI25(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI26(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI27(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI28(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI29(8)
03:28:59 - XFSTK-LOG--GetAck - DIFWI30(8)
03:29:00 - XFSTK-LOG--LogProgress
03:29:00 - XFSTK-LOG--GetOpCode
03:29:00 - XFSTK-LOG--ReadInAck
03:29:00 - XFSTK-LOG--GetAck - DIFWI31(8)
03:29:00 - XFSTK-LOG--WriteOutPipe __BINARY__
03:29:00 - XFSTK-LOG--WriteOutPipe 0
03:29:00 - XFSTK-LOG--Write --->__BINARY__
03:29:00 - XFSTK-LOG--GetAck - HLT$(4)
03:29:00 - XFSTK-LOG--FW: Firmware update completed...
03:29:00 - XFSTK-LOG--LogError
03:29:00 - XFSTK-STATUS--Error Code: 0 - Success
03:29:00 - XFSTK-LOG--void MerrifieldDownloader::do_abort()
03:29:00 - XFSTK-LOG--Abort
03:29:00 - XFSTK-LOG--C:/debrick380/FE380CXG_32_IFWI_v79.54_CRAK_DEV.bin size:4194468 bytes
03:29:00 - XFSTK-STATUS--PASS
03:29:00 - XFSTK-STATUS--Firmware download completed. Continuing to OS...
03:29:10 - XFSTK-STATUS--Reconnecting to device - Attempt #1
03:29:11 - XFSTK-STATUS--Reconnecting to device - Attempt #2
03:29:12 - XFSTK-STATUS--Reconnecting to device - Attempt #3
03:29:13 - XFSTK-STATUS--Reconnecting to device - Attempt #4
03:29:14 - XFSTK-STATUS--Reconnecting to device - Attempt #5
03:29:15 - XFSTK-STATUS--Reconnecting to device - Attempt #6
03:29:16 - XFSTK-STATUS--Reconnecting to device - Attempt #7
03:29:17 - XFSTK-STATUS--Reconnecting to device - Attempt #8
03:29:18 - XFSTK-STATUS--Reconnecting to device - Attempt #9
03:29:19 - XFSTK-STATUS--Reconnecting to device - Attempt #10
03:29:20 - XFSTK-STATUS--Reconnecting to device - Attempt #11
03:29:21 - XFSTK-STATUS--Reconnecting to device - Attempt #12
03:29:22 - XFSTK-STATUS--Reconnecting to device - Attempt #13
03:29:23 - XFSTK-STATUS--Reconnecting to device - Attempt #14
03:29:24 - XFSTK-STATUS--Reconnecting to device - Attempt #15
03:29:25 - XFSTK-STATUS--Reconnecting to device - Attempt #16
03:29:26 - XFSTK-STATUS--Reconnecting to device - Attempt #17
03:29:27 - XFSTK-STATUS--Reconnecting to device - Attempt #18
03:29:28 - XFSTK-STATUS--Reconnecting to device - Attempt #19
03:29:29 - XFSTK-STATUS--Reconnecting to device - Attempt #20
03:29:30 - XFSTK-STATUS--Timeout to detect the device, make sure to charge up your phone before flashing
В чем моя ошибка ?
