Ipad air battery percentage stuck https://vlab.su/viewtopic.php?f=263&t=59126 |
niktele [ 27 мар 2017, 10:49 ] | |
Заголовок сообщения: | Ipad air battery percentage stuck |
I have a problem with ipad air after nand upgrade battery percentage don't update and if I plug in charger and then turn off device and after some time I start up device battery percentage are up like it's should be. Only update if device turned off. I read about "gas gauge" near battery connector but I'm not sure what part to check. Thx sent from gsmsverige |
