unsupport spi flash id!!!
U-Boot 2010.06-svn2854 (Dec 12 2015 - 03:27:37)
I2C: ready
DRAM: 110 MiB
gBootLogPtr:00b80008.
spinor flash ID is 0xc81840c8
partition file version 2
rootfstype squashfs root /dev/mtdblock5
TEXT_BASE:01000000
Net: Detected MACID:3c:ef:8c:96:80:c9
PHY:0x001cc816,addr:0x00
phy RTL8201 init
link down
link down
Try again use backup_serverip
link down
Failed to get info.txt
Fail to get info file!
Init error!
link down
state:ff,err_count:04
SPI probe: 16384 KiB GD25Q128C at 0:0 is now current device
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-3.10.50
Created: 2015-12-15 1:23:57 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1494768 Bytes = 1.4 MiB
Load Address: 00208000
Entry Point: 00208000
Verifying Checksum ... OK
Loading Kernel Image ...OK
OK
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
Starting kernel ...
crashflasg:1, logmagic:54410011.
I2C: ready
DRAM: 110 MiB
TEXT_BASE:01000000
phy RTL8201 init
link down
link down
link down
Init error!
link down
state:ff,err_count:05
Created: 2015-10-15 11:47:30 UTC
Data Size: 893200 Bytes = 872.3 KiB
OK
Starting kernel ...
init started: BusyBox v1.18.4 (2015-04-13 15:29:18 CST)
mount: mounting none on /proc/bus/usb failed: No such file or directory
mount: mounting tmpfs on /var failed: Invalid argument
mount: mounting /dev/mtdblock3 on /mnt/custom failed: Invalid argument
mount: mounting /dev/mtdblock4 on /mnt/pd failed: Invalid argument
mount: mounting /dev/mtdblock8 on /mnt/afix/autoFix failed: Invalid argument
mount: mounting /dev/mtdblock9 on /mnt/afix/autoFixBackup failed: Invalid argument
BusyBox v1.18.4 (2015-04-13 15:29:18 CST) built-in shell (ash)
Revision: 9308
Enter 'help' for a list of built-in commands.
/bin/sh: can't access tty; job control turned off
~ # UPGRADED_MSG: Do memlock
[libpdi] Support backup partition !!!
[libpdi] Flashtype = 3,patSize = 40000,rwSize = 10000,ersSize = 10000
pPartionId = 9
eth0:
MAC: <3c:ef:8c:96:80:c9>
[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO[libpdi] set eth0 as defaultEth
IP: <192.168.1.108> netmask: <255.255.255.0>
[libpdi] ERROR (save_Attr_file|1269): open failed for HOSTIP[libpdi] ERROR (PDI_rtcWriteSram|162): Fail to ioctl rtc
[libpdi] ERROR (SaveEthAttrInFile|1368): Fail to write ip paramenters
[libpdi] ERROR (save_Attr_file|1269): open failed for SUBMASK[libpdi] ERROR (PDI_rtcWriteSram|162): Fail to ioctl rtc
SOCK_PACKET: Address family not supported by protocol
[libpdi] [libPDI] Gateway: <192.168.1.1>
[libpdi] SetGateWay success
[libpdi] ERROR (save_Attr_file|1269): open failed for GATEWAYIP[libpdi] ERROR (PDI_rtcWriteSram|162): Fail to ioctl rtc
[libpdi] [libPDI] Name: upgraded, bulid date: Apr 13 2015 15:03:44, svn: 492
UPGRADED_MSG: start download file!
UPG-unsupport spi flash id!!!
