U-Boot 2010.06 (Aug 19 2013 - 10:56:44)
NAND: Special Nand id table Version 1.35
Nand ID: 0x01 0xF1 0x00 0x1D 0x01 0xF1 0x00 0x1D
Nand(Hardware): Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:1bit
128 MiB
Spiold(cs1) ID: 0xC2 0x20 0x15 0xC2 0x20 0x15
Spi(cs1): Block:64KB Chip:2MB Name:"MX25L1606E"
In: serial
Out: serial
Err: serial
current auto update version : 201308070921
cur device nand size 131072, spi size 2097152
current used param offset 0xa0000
current do_check_flash_boot_param
close watch dog begin...............
test wdg 0
test wdg 1
dog_close
dev 0 set background color!
dev 1 set background color!
dev 2 set background color!
dev 3 set background color!
dev 0 opened!
dev 1 opened!
dev 2 opened!
dev 3 opened!
jpeg decoding ...
<<addr=0xc0000000, size=0x4ca0, vobuf=0xc1000000>>
mmu_enable
<<imgwidth=480, imgheight=320, linebytes=960>>
decode success!!!!
dev 0 opened!
vo hd 0 end
dev 2 opened!
dev 3 opened!
vo cvbs end
graphic layer 0 opened!
graphic layer 2 opened!
graphic layer 3 opened!
wait end time
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
Hit any key to stop autoboot: 0
begin ... do_auto_logo_image
NAND read: device 0 offset 0x0, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.0.8
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3630560 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.8 (lzg@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #201309050002 SMP Thu Sep 5 10:46:21 CST 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: godnet
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c0a62000 s5536 r8192 d14944 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 109728
Kernel command line: mem=432M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=yaffs2 mtdparts=hi_sfc:2M(boot);hinand:8M(kernel),16M(rootfs),64M(user),32M(nva000000) pcieclkext=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 432MB = 432MB total
Memory: 431276k/431276k available, 11092k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xdb800000 - 0xfe000000 ( 552 MB)
lowmem : 0xc0000000 - 0xdb000000 ( 432 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0039000 ( 196 kB)
.text : 0xc0039000 - 0xc0677000 (6392 kB)
.data : 0xc0678000 - 0xc06a0de0 ( 164 kB)
.bss : 0xc06a0e04 - 0xc06fdd04 ( 372 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 155MHz, resolution 6ns, wraps every 27709ms
Console: colour dummy device 80x30
Calibrating delay loop... 1849.75 BogoMIPS (lpj=9248768)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3706.06 BogoMIPS).
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
uart:3: ttyAMA3 at MMIO 0x200b0000 (irq = 43) is a PL011 rev2
bio: create slab <bio-0> at 0
controller0, config base:0x20800000, mem size:0x800000
controller1, config base:0x20810000, mem size:0x800000
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers enabled
PCI: bus2: Fast back to back transfers disabled
PCI: bus3: Fast back to back transfers enabled
pci 0000:02:00.0: BAR 0: assigned [mem 0x60000000-0x607fffff pref]
pci 0000:02:00.0: BAR 0: set to [mem 0x60000000-0x607fffff pref] (PCI address [0x60000000-0x607fffff])
pci 0000:02:00.0: BAR 1: assigned [mem 0x60800000-0x6080ffff]
pci 0000:02:00.0: BAR 1: set to [mem 0x60800000-0x6080ffff] (PCI address [0x60800000-0x6080ffff])
pci 0000:02:00.0: BAR 6: assigned [mem 0x60810000-0x6081ffff pref]
pci 0000:02:00.0: PCI bridge to [bus 03-03]
pci 0000:02:00.0: bridge window [io disabled]
pci 0000:02:00.0: bridge window [mem disabled]
pci 0000:02:00.0: bridge window [mem pref disabled]
pci 0000:00:00.0: BAR 0: assigned [mem 0x30000000-0x307fffff pref]
pci 0000:00:00.0: BAR 0: set to [mem 0x30000000-0x307fffff pref] (PCI address [0x30000000-0x307fffff])
pci 0000:00:00.0: BAR 1: assigned [mem 0x30800000-0x3080ffff]
pci 0000:00:00.0: BAR 1: set to [mem 0x30800000-0x3080ffff] (PCI address [0x30800000-0x3080ffff])
pci 0000:00:00.0: BAR 6: assigned [mem 0x30810000-0x3081ffff pref]
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0: bridge window [io disabled]
pci 0000:00:00.0: bridge window [mem disabled]
pci 0000:00:00.0: bridge window [mem pref disabled]
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer1
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
L2cache cache controller enabled
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 842
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 68
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 68
Spi id table Version 1.22
Hisilicon Spi Flash Controller V300 Device Driver, Version 1.10
Spi(cs1) ID: 0xC2 0x20 0x15 0xC2 0x20 0x15
Spi(cs1): Block:64KB Chip:2MB (Name:MX25L1606E)
1 cmdlinepart partitions found on MTD device hi_sfc
Creating 1 MTD partitions on "hi_sfc":
0x000000000000-0x000000200000 : "boot"
Special nand id table Version 1.35
Hisilicon Nand Flash Controller V301 Device Driver, Version 1.10
Nand(Hardware): Block:128KB Page:2KB Chip:128MB OOB:64B ECC:1bit
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
4 cmdlinepart partitions found on MTD device hinand
Creating 4 MTD partitions on "hinand":
0x000000000000-0x000000800000 : "kernel"
0x000000800000-0x000001800000 : "rootfs"
0x000001800000-0x000005800000 : "user"
0x000005800000-0x000007800000 : "nva000000"
Fixed MDIO Bus: probed
sky2: driver version 1.28
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbmon: debugfs is not available
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver mdc800
mdc800: v0.7.5 (30/10/2000):USB Driver for Mustek MDC800 Digital Camera
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
registered taskstats version 1
ata1: SATA link down (SStatus 1 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
yaffs: dev is 32505858 name is "mtdblock2" rw
yaffs: passed flags ""
VFS: Mounted root (yaffs2 filesystem) on device 31:2.
Freeing init memory: 196K
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Jan 1 00:00:04 udevd (588): /proc/588/oom_adj is deprecated, please use /proc/588/oom_score_adj instead.
udevd[588]: main: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S81toe
yaffs: dev is 32505859 name is "mtdblock3" rw
yaffs: dev is 32505860 name is "mtdblock4" rw
STMMAC driver:
platform registration... current version 201310141753
done!
Set system config register 0x200300ec with value 0x003f003f
done!
DWMAC1000 - user ID: 0x10, Synopsys ID: 0x36
Enhanced descriptor structure
MACADDR in get is 0:0:0:0:0:0
no valid MAC address for MAC 1;please, use ifconfig or nwhwconfig!
eth0 - (dev. name: stmmaceth - id: 0, IRQ #119
IO base addr: 0xdb9c4000)
STMMAC MII Bus: probed
eth0: PHY ID 001cc980 at 0 IRQ 0 (1:00)
eth0: PHY ID 001cc912 at 1 IRQ -6 (1:01) active
no valid MAC address for MAC 0;please, use ifconfig or nwhwconfig!
eth1 - (dev. name: stmmaceth - id: 0, IRQ #119
IO base addr: 0xdb9c0000)
eth1: PHY ID 001cc980 at 0 IRQ 0 (1:00)
eth1: PHY ID 001cc912 at 1 IRQ -6 (1:01)
stmmac_reset: RESET COMPLETE!
* TNK driver built on Oct 14 2013 at 18:07:02
* TNK driver mode is BYPASS
stmmac: Rx Checksum Offload Engine supported
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 63, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 64, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
rm: /var/lock: is a directory
rm: /var/run: is a directory
No need to recovery program from USB
sh: missing ]
current used product type 16d1 or 16960h or nvr
SDK_TYPE type is 16d1
current system default mem=192M
Hisilicon Media Memory Zone Manager
ERROR: Conflict MMZ:
PHYS(0x8C000000, 0x9F9FFFFF), GFP=0, nBYTES=321536KB, NAME="anonymous"
MMZ conflict to kernel memory (0x80000000, 0x9AFFFFFF)
Add MMZ failed: PHYS(0x8C000000, 0x9F9FFFFF), GFP=0, nBYTES=321536KB, NAME="anonymous"
hi3531_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
Hisilicon UMAP device driver interface: v3.00
load sys.ko for Hi3531...OK!
insmod: can't insert 'hi3531_tde.ko': Operation not permitted
hi3531_dsu: Unknown symbol TdeOsiMbBlit (err 0)
hi3531_dsu: Unknown symbol TdeOsiMb2Mb (err 0)
hi3531_dsu: Unknown symbol TdeOsiCancelJob (err 0)
hi3531_dsu: Unknown symbol TdeOsiOpen (err 0)
hi3531_dsu: Unknown symbol TdeOsiOsd2Mb (err 0)
hi3531_dsu: Unknown symbol TdeOsiEndJob (err 0)
hi3531_dsu: Unknown symbol TdeOsiClose (err 0)
hi3531_dsu: Unknown symbol TdeOsiMbFill (err 0)
hi3531_dsu: Unknown symbol TdeOsiGetFiltParam (err 0)
hi3531_dsu: Unknown symbol TdeOsiBeginJobEx (err 0)
hi3531_dsu: Unknown symbol TdeOsiSetFiltParam (err 0)
hi3531_dsu: Unknown symbol TdeOsiMemRequest (err 0)
hi3531_dsu: Unknown symbol TdeOsiRegisterMemManage (err 0)
hi3531_dsu: Unknown symbol TdeOsiGetJobNumInFifo (err 0)
insmod: can't insert 'hi3531_dsu.ko': unknown symbol in module or invalid parameter
load venc.ko for Hi3531...OK!
load group.ko for Hi3531...OK!
load chnl.ko for Hi3531...OK!
load h264e.ko for Hi3531...OK!
load rc.ko for Hi3531...OK!
load jpege.ko for Hi3531...OK!
load mpeg4e.ko for Hi3531...OK!
load viu.ko for Hi3531...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load region.ko ....OK!
load vda.ko ....OK!
hifb: Unknown symbol TdeOsiCancelJob (err 0)
hifb: Unknown symbol TdeOsiOpen (err 0)
hifb: Unknown symbol TdeOsiEndJob (err 0)
hifb: Unknown symbol TdeOsiClose (err 0)
hifb: Unknown symbol tde_get_procentry (err 0)
hifb: Unknown symbol TdeOsiBlit (err 0)
hifb: Unknown symbol TdeOsiBeginJob (err 0)
hifb: Unknown symbol TdeOsiEnableRegionDeflicker (err 0)
insmod: can't insert 'hifb.ko': unknown symbol in module or invalid parameter
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
jpeg: Unknown symbol tde_get_procentry (err 0)
insmod: can't insert 'jpeg.ko': unknown symbol in module or invalid parameter
i2c version : 201205031405
NVP1918 Driver Version 201307031555
channel mux out mode[4D1]
NVP1918 Clock 144M Mode
~~~~~~~~~~~~~~~~S/W reset~~~~~~~~~~~~~~~~
NC PAL 960H MODE SETTING!!!
NC 2012_07_30_version!!!NC Decoder[0x80][0x60] INIT OK
current decode chip type is nvp1918
++++++++g_chip_type = 0
2408 rtc Device Driver 201203081801 v1.0.0
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
current watchdog version 201206151658
keybaord gpio init version : 201207021137
HISI_IRDA-MF @Hi3520v100R001_C_0_2_0 2011-04-29 14:05:20
hiir: init ok. ver 201206151658 =Jun 16 2012, 17:05:48.
version:2012030908580+->TD3515
TVT 35xx CryptoMemory Device Driver v1.0.0: Mar 9 2012 09:30:34
Kernel: ssp initial ok!
modprobe: chdir(/lib/modules): No such file or directory
rm: can't remove '/mnt/mtd/preupgrade.sh': No such file or directory
rm: can't removeMACADDR in set is 0:18:ae:45:79:e8
'/mnt/mtd/produADDRCONF(NETDEV_UP): eth0: link is not ready
ctcheck': No such file or directory
Auto login as root ...
(none) login: PUB_common.cpp, 1924, pid = 973, tid=974
xdvr.cpp, 638, pid = 973, tid=973
PHY: 1:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
check OK!
LocalDevice.cpp,4160,no write crytoinfo
#############xdvr.cpp,661,productID:0
productID:0,subProductID:0
xdvr.cpp,682,programeId:0,subProductID:0.xdvr.cpp,715,g_bProIdequeSubProdID:1
######################xdvr.cpp,734,no change CVBS Resolution
hdtype=0
current flash param ==
------get 1------current param type == 4066
product Item (Product.cpp,417)from programe
Product.cpp,19142, no this product
------get 0------current param type == 4068
5512 configEx Product.cpp,21159,szTmp:2
------get 0------current param type == 4073
5517 Product.cpp,21164,szTmp:0080
Initial product manager fail!
DVRService.cpp, 132, child process exit!
DVRService.cpp, 141 system exit!
