[Ищу дамп] Dahua IPC-HFW1220SP (?) https://vlab.su/viewtopic.php?f=270&t=128155 |
mazahaka011 [ 20 авг 2022, 14:39 ] | |
Заголовок сообщения: | [Ищу дамп] Dahua IPC-HFW1220SP (?) |
Модель точно не известна, этикетка на корпусе отсутствует Сабж убит прошивкой. При запуске поднимает на несколько сек сеть для tftp потом тишина
Лог
U-Boot 2010.06-svn2464 (Apr 16 2016 - 06:25:59)
DRAM: 256 MiB gBootLogPtr:80b80008. Check spi flash controller v350... Found Spi(cs1) ID: 0xC8 0x40 0x17 0xC8 0x40 0x17 Spi(cs1): Block:64KB Chip:8MB Name:"GD25Q64C" boot from spi *** Warning - bad CRC, using default environment boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 In: serial Out: serial Err: serial TEXT_BASE:81000000 Hisilicon ETH net controler MAC: 00-12-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending throu gh gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: * Retry count exceeded; starting again Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 00-12-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M *** ERROR: `serverip' not set Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 00-12-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending throu gh gateway 192.168.1.1 Download Filename 'failed.txt'. Download to address: 0x82000000 Downloading: * Retry count exceeded; starting again ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.0.8 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 861708 Bytes = 841.5 KiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 cmdLine mem=80M console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel.
Серийник на плате
2E02E65PAU04359
Нужен дамп на сей аппарат |
fobos [ 20 авг 2022, 14:49 ] | |
Заголовок сообщения: | Re: [Ищу дамп] Dahua IPC-HFW1220SP (?) |
остановите загрузку, нажав "*", и вывод команды printenv покажите |
mazahaka011 [ 20 авг 2022, 14:56 ] | |
fobos писал(а): остановите загрузку, нажав "*", и вывод команды printenv покажите
bootargs=mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ethaddr=00:12:34:56:78:9A ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 ID=000000000000000000 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm dh_keyboard=1 appauto=1 loglevel=4 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn2464 (Apr 16 2016 - 06:25:59) Environment size: 896/131068 bytes |
fobos [ 20 авг 2022, 15:41 ] | |
часом не от ростелекома отвязять хотите?...заводской дамп https://cloud.mail.ru/public/LcbD/sRxua9gx2 ...затем надо будет прописать ID (в вашем случае 2F02613PAU01525 или 2K058B2GA100014 на выбор), HWID IPC-HFW1220RM:01:02:02:36:13:00:01:00:00:00:00:1B8:00:00:00:00:00:00:00:00:80 (без него не будет загружаться) и чтобы все было по феншую пропишите devalias IPC-HFW1220S |
mazahaka011 [ 20 авг 2022, 15:54 ] | |
fobos писал(а): часом не от ростелекома отвязять хотите? Нет, обычная камера от Dahua. Белый цилиндр, на крышке dahua, но стикер сорван( Сейчас попробую дамп и отпишусь |
fobos [ 20 авг 2022, 15:59 ] | |
...еще чуть не забыл: пропишите правильный MAC-адрес. Для первого ID, который я давал 3C:EF:8C:D0:0E:7F, для второго - 3C:EF:8C:FF:C6:32 |
mazahaka011 [ 20 авг 2022, 16:21 ] | |
fobos писал(а): ...еще чуть не забыл: пропишите правильный MAC-адрес. Для первого ID, который я давал 3C:EF:8C:D0:0E:7F, для второго - 3C:EF:8C:FF:C6:32 Залил дамп, вроде все прописал, сохранил. Теперь сеть активна постоянно, 192.168.1.108 пингуется, но в веб не заходит. config tool ее не видит
printenv
DRAM: 256 MiB gBootLogPtr:80b80008. Check spi flash controller v350... Found Spi(cs1) ID: 0xC8 0x40 0x17 0xC8 0x40 0x17 Spi(cs1): Block:64KB Chip:8MB Name:"GD25Q64C" boot from spi boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 In: serial Out: serial Err: serial TEXT_BASE:81000000 Hit any key to stop autoboot: 0 > printenv bootargs=mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 ID=000000000000000000 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm dh_keyboard=1 appauto=1 loglevel=4 nv=ID 2K058B2GA100014 ethaddr=3C:EF:8C:FF:C6:32 HWID=IPC-HFW1220RM:01:02:02:36:13:00:01:00:00:00:00:1B8:00:00:00:00:00:00:00:00:80 devalias=IPC-HFW1220S stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn2464 (Apr 16 2016 - 06:25:59) Environment size: 1028/131068 bytes |
fobos [ 20 авг 2022, 16:28 ] | |
пропишите setenv dh_keyboard 0, saveenv и reset ...полный лог загрузки покажите ---------- Добавлено спустя 3 минуты 26 секунд: ---------- ...и почему перед ID присутствуют nv?...правильно будет так: setenv ID xxxxxxxxxxxxxxxx, saveenv |
mazahaka011 [ 20 авг 2022, 16:36 ] | |
fobos писал(а): полный лог загрузки покажите
лог
DRAM: 256 MiB gBootLogPtr:80b80008. Check spi flash controller v350... Found Spi(cs1) ID: 0xC8 0x40 0x17 0xC8 0x40 0x17 Spi(cs1): Block:64KB Chip:8MB Name:"GD25Q64C" boot from spi boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 In: serial Out: serial Err: serial TEXT_BASE:81000000 Hit any key to stop autoboot: 0 > setenv dh_keyboard 0 > saveenv Saving Environment to SPI Flash... Erasing SPI flash... Writing to SPI flash... done > setenv ID 2K058B2GA100014 > saveenv Saving Environment to SPI Flash... Erasing SPI flash... Writing to SPI flash... done > reset resetting ... U-Boot 2010.06-svn2464 (Apr 16 2016 - 06:25:59) DRAM: 256 MiB gBootLogPtr:80b80008. Check spi flash controller v350... Found Spi(cs1) ID: 0xC8 0x40 0x17 0xC8 0x40 0x17 Spi(cs1): Block:64KB Chip:8MB Name:"GD25Q64C" boot from spi boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 In: serial Out: serial Err: serial TEXT_BASE:81000000 Hisilicon ETH net controler MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: * Retry count exceeded; starting again Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M Up/Down PHY not link. Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'failed.txt'. Download to address: 0x82000000 Downloading: * Retry count exceeded; starting again ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.0.8 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 861708 Bytes = 841.5 KiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 cmdLine mem=80M console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518 appauto=1 dh_keyboard=0 ethaddr0=3c:ef:8c:ff:c6:32 ethaddr1=0:0:0:0:0:0 wifiAddr=0:12:34:56:78:91 lip0=192.168.1.108 lip1=0.0.0.0 id=2K058B2GA100014 U-Boot 0x30000 0x10000 0x0 hwid 0x20000 0x40000 0x0 partition 0x10000 0x60000 0x0 Kernel 0x100000 0x70000 0x0 romfs 0x490000 0x170000 0x0 web 0x190000 0x600000 0x0 config 0x60000 0x790000 0x0 num parts is 7. gLogRamRes: start=0x84f7e000;size=0x80000 dh_keyboard:0 console [ttyS0] enabled init started: BusyBox v1.18.4 (2014-12-08 20:28:09 CST) keyboard = 0 mkdir: can't create directory '/mnt/backup/Config': Read-only file system mkdir: can't create directory '/mnt/backup/debug': Read-only file system Hisilicon Media Memory Zone Manager ERROR: Conflict MMZ: PHYS(0x84D00000, 0x872FFFFF), GFP=0, nBYTES=38912KB, NAME="anonymous" MMZ conflict to kernel memory (0x80000000, 0x84FFFFFF) Add MMZ failed: PHYS(0x84D00000, 0x872FFFFF), GFP=0, nBYTES=38912KB, NAME="anonymous" Hisilicon UMAP device driver interface: v3.00 load sys.ko ...OK! insmod: can't insert 'hi3518_tde.ko': Operation not permitted insmod: can't insert 'hi3518_dsu.ko': unknown symbol in module, or unknown parameter load viu.ko ...OK! ISP Mod init! load vpss.ko ....OK! load venc.ko ...OK! load group.ko ...OK! load chnl.ko ...OK! load h264e.ko ...OK! load jpege.ko ...OK! load rc.ko ...OK! load region.ko ....OK! [OSA-DRV] OSA Build on Apr 16 2016 at 06:12:01. [OSA-DRV] SVN NUM: 1242. [OSA-DRV] Monitor Task pid=291 tid=291 [LOG-DRV] LOG Build on Apr 16 2016 at 06:02:48. [LOG-DRV] SVN NUM: 4731. [LOG-DRV] ramStart:0x84f7e000;ramSize:0x80000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 00:00:03|[Binder] Binder.ko Build on Apr 18 2016 at 19:01:41. 00:00:03|[Binder] SVN NUM: 1780. 00:00:03|[Binder] Create binder memory pool(size:524288) OK! 00:00:03|[Binder] Create binder memory pool(size:3145728) OK! 00:00:03|[Binder] NameServer Initial OK ! 00:00:03|[Binder] Binder Initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] SR driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] NS driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] Binder driver initial OK ! 00:00:03|[SPF] SPF Build on Apr 16 2016 at 06:40:12. 00:00:03|[SPF] SVN NUM: 5384. 00:00:03|[SPF] SIL initial OK ! 00:00:03|[SPF] SPF initial ok ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[SPF] SPF Proc Create OK!!! 00:00:03|[SPF] SPF driver initial ok ! 00:00:03|[prc] PRC Driver Build on Apr 16 2016 at 05:53:46. 00:00:03|[prc] SVN NUM: 2615. 00:00:03|[prc] Start to init module! 00:00:03|[prc] pinmux init ok 00:00:03|[prc] gpio soc init ok 00:00:03|[prc] spi init ok 00:00:03|[prc] IIC init ok 00:00:03|[prc] PRC_wdtInit OK 00:00:03|[prc] PRC_rtcInit OK! 00:00:03|[prc] i2c businit ok 00:00:03|[prc] DMA init ok 00:00:03|[SPF] Dai 3 register OK ! 00:00:03|[prc] IIS init: ok 00:00:03|[SPF] codecType 32 register OK ! 00:00:03|[prc] Codec init ok 00:00:03|[prc] Success to init module! 00:00:03|[pdc] PDC Build on Apr 16 2016 at 06:33:02. 00:00:03|[pdc] SVN NUM: 5609. 00:00:03|[pdc] BASE_LINE: 240 00:00:03|[pdc] OSA_kProcCreate OK 00:00:03|[OSA-DRV] recordTsk Task pid=321 tid=321 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] PDC_PartionInit ok!! 00:00:03|[pdc] HWID : 00:00:03|[pdc] ERROR (HWID_parsePdtType|2815): nPrdtLineId 0 wrong ! 00:00:03|[pdc] ERROR (PDC_hwidInit|3788): Hwid init failed ! 00:00:03|[pdc] ERROR (PDC_drvInit|158): PDC_hwidInit() 00:00:03|[pdc] PDC_PRODUCT_OWNER: 0 00:00:03|[pdc] ERROR (PDC_cfgFindInitOps|322): Not probed, please check it ! 00:00:03|[pdc] ERROR (PDC_cfgInit|347): Device not found ! 00:00:03|[pdc] ERROR (PDC_drvInit|164): PDC_cfgInit() 00:00:03|[pdc] WARN (PDC_keyMcuInit|249): Get mcu cfg failed!Can not Kernel: ssp initial ok! init keyMcu! 00:00:03|[pdc] Dev has No Key Cfg! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] SramFile init ok ! 00:00:03|[pdc] Both of Chief and Backup File CRC check OK! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] ERROR (PDC_drvInit|175): PDC Driver Initial Failed ! 00:00:03|[pwm] WARN (/home/xia_junming/re/pdc-now/pwm/./src//pwm.c|pwm_init|509): Fail to get iris configure! 00:00:04|[pdc] SramFile_devRelease OK! CATEGORY = 0 IPC Device [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] ERROR (PDI_productInit|643): Can't open /dev/pdcHwid [libpdi] ERROR (PDI_preInit|100): PDI_productInit execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_hwidGet|360): Ioctl execute error [libpdi] ERROR (PDI_preInit|105): PDI_hwidGet execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_productGetVinCfg|503): Ioctl execute error [libpdi] Init vinCfg Failed [libpdi] get vout failed [libpdi] WARN : RTC Dev not exists,status = -1 00:00:04|[pdc] Both of Chief and Backup File CRC check OK! 00:00:04|[pdc] phyaddr = 84ffe000, memLen = 2000 [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] ERROR (PDI_preInit|140): PDI_flashIinit execute Error and return OSA_EFAIL [libpdi] WARN : Device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 00:00:04|[pdc] Copy /mnt/mtd/flgFileBackUp To /mnt/mtd/flgFile OK! Fail to get env hwidEx! [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] can't find commLen cfg [Systools]: Build on Apr 17 2016 at 03:00:27. [Systools]:SVN NUM: 21111. [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. Fail to get env coremnt! 00:00:04|[systools] WARN : coremnt not found Syshelper: WdtSatrtTime = 60(s), appauto00:00:05|[pdc] SramFile_devRelease OK! = 0, hctosystime = 1500 00:00:05|[libpdi] ERROR (PDI_wdtOpen|109): wdt open error 00:00:05|[systools] WARN : open wdt period failed [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] ERROR (PDI_productInit|643): Can't open /dev/pdcHwid [libpdi] ERROR (PDI_preInit|100): PDI_productInit execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_hwidGet|360): Ioctl execute error [libpdi] ERROR (PDI_preInit|105): PDI_hwidGet execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_productGetVinCfg|503): Ioctl execute error [libpdi] Init vinCfg Failed [libpdi] get vout failed [libpdi] WARN : RTC Dev not exists,status = -1 00:00:05|[pdc] Both of Chief and Backup File CRC check OK! 00:00:05|[pdc] phyaddr = 84ffe000, memLen = 2000 [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] ERROR (PDI_preInit|140): PDI_flashIinit execute Error and return OSA_EFAIL [libpdi] WARN : Device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 00:00:05|[pdc] Copy /mnt/mtd/flgFileBackUp To /mnt/mtd/flgFile OK! Fail to get env hwidEx! [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] can't find commLen cfg UPGRADED_MSG: Do memlock Name: upgraded, bulid date: Apr 16 2016 06:37:16, svn: 352 UPGRADED_MSG: start download file! 00:00:05|[SEN-DRV] Sensor Build on Apr 16 2016 at 06:18:39. 00:00:05|[SEN-DRV] SVN NUM: 4288. 00:00:05|[SEN-DRV] ERROR (SEN_drvInit|68): get cfg failed insmod: can't insert '/usr/lib/modules/sensor.ko': Operation not permitted product_name = fvideo_chip = 0 sdcard_cap = 0 [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] ERROR (PDI_productInit|643): Can't open /dev/pdcHwid [libpdi] ERROR (PDI_preInit|100): PDI_productInit execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_hwidGet|360): Ioctl execute error [libpdi] ERROR (PDI_preInit|105): PDI_hwidGet execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_productGetVinCfg|503): Ioctl execute error [libpdi] Init vinCfg Failed [libpdi] get vout failed [libpdi] WARN : RTC Dev not exists,status = -1 00:00:06|[pdc] Both of Chief and Backup File CRC check OK! 00:00:06|[pdc] phyaddr = 84ffe000, memLen = 2000 [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] ERROR (PDI_preInit|140): PDI_flashIinit execute Error and return OSA_EFAIL [libpdi] WARN : Device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 00:00:06|[pdc] Copy /mnt/mtd/flgFileBackUp To /mnt/mtd/flgFile OK! Fail to get env hwidEx! [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] can't find commLen cfg [Systools]: Build on Apr 17 2016 at 03:00:27. [Systools]:SVN NUM: 21111. init eth0 to default 00:00:06|[libpdi] NET_disableRoute = 0 eth0: MAC: <3c:ef:8c:ff:c6:32> 00:00:06|[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO00:00:06|[libpdi] set eth0 as defaultEth IP: <192.168.1.108> netmask: <255.255.255.0> Gateway: <192.168.1.1> 00:00:06|[libpdi] ERROR (save_Attr_file|1269): open failed for HOSTIP00:00:06|[libpdi] ERROR (save_Attr_file|1269): open failed for SUBMASK00:00:06|[libpdi] SetGateWay success [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] ERROR (PDI_productInit|643): Can't open /dev/pdcHwid [libpdi] ERROR (PDI_preInit|100): PDI_productInit execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_hwidGet|360): Ioctl execute error [libpdi] ERROR (PDI_preInit|105): PDI_hwidGet execute Error and return OSA_EFAIL [libpdi] ERROR (PDI_productGetVinCfg|503): Ioctl execute error [libpdi] Init vinCfg Failed [libpdi] get vout failed [libpdi] WARN : RTC Dev not exists,status = -1 00:00:06|[pdc] Both of Chief and Backup File CRC check OK! 00:00:06|[pdc] phyaddr = 84ffe000, memLen = 2000 [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] ERROR (PDI_preInit|140): PDI_flashIinit execute Error and return OSA_EFAIL [libpdi] WARN : Device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 00:00:06|[pdc] Copy /mnt/mtd/flgFileBackUp To /mnt/mtd/flgFile OK! Fail to get env hwidEx! [libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo [libpdi] can't find commLen cfg [Systools]: Build on Apr 17 2016 at 03:00:27. [Systools]:SVN NUM: 21111. IPV6: only init eth0 00:00:06|[libpdi] NET_disableRoute = 0 "netinit6 help" for help eth0: MAC: <3c:ef:8c:ff:c6:32> IPV6: <2001:250:3000:1::1:2> preFixLen: <112> 00:00:06|[libpdi] WARN (NetWorkDelIP|1124): del ip failed:Cannot assign requested address 00:00:06|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:00:06|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup 00:00:06|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:00:06|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup IPV6 Gateway: <2001:250:3000:1::1:1> 00:00:06|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:00:06|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup appauto=1 ./usr/etc/app.sh: line 5: can't create /proc/osa_root/p: nonexistent directory [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. 00:00:12|[libenc] libenc.a svn num: 23096 compile time: Apr 16 2016 06:12:33 00:00:12|[Binder-Lib] libbinder.so Build on Apr 18 2016 at 19:01:39. 00:00:12|[Binder-Lib] SVN NUM: 1780. 00:00:12|[OSA-APP] Monitor Task pid=394 tid=395 00:00:12|[libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. 00:00:12|[libpdi] SVN NUM: 21357. 00:00:12|[libpdi] ERROR (PDI_productInit|643): Can't open /dev/pdcHwid 00:00:12|[libpdi] ERROR (PDI_preInit|100): PDI_productInit execute Error and return OSA_EFAIL 00:00:12|[libpdi] ERROR (PDI_hwidGet|360): Ioctl execute error 00:00:12|[libpdi] ERROR (PDI_preInit|105): PDI_hwidGet execute Error and return OSA_EFAIL 00:00:12|[libpdi] ERROR (PDI_productGetVinCfg|503): Ioctl execute error 00:00:12|[libpdi] Init vinCfg Failed 00:00:12|[libpdi] get vout failed 00:00:12|[libpdi] WARN : RTC Dev not exists,status = -1 00:00:12|[pdc] Both of Chief and Backup File CRC check OK! 00:00:12|[pdc] phyaddr = 84ffe000, memLen = 2000 00:00:12|[libpdi] Get fpga upgrade cfg failed, use default 00:00:12|[libpdi] Not support backup partition !!! 00:00:12|[libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 00:00:12|[libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo 00:00:12|[libpdi] ERROR (PDI_preInit|140): PDI_flashIinit execute Error and return OSA_EFAIL 00:00:12|[libpdi] WARN : Device has no crypt chip! 00:00:12|[libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 00:00:12|[pdc] Copy /mnt/mtd/flgFileBackUp To /mnt/mtd/flgFile OK! Fail to get env hwidEx! 00:00:12|[libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo 00:00:12|[libpdi] can't find commLen cfg 00:00:12|[libCapture] 00:00:12|[libCapture] VideoDaemon Build on Apr 16 2016 at 06:12:28. 00:00:12|[libCapture] SVN NUM: 22188. 00:00:12|[libCapture] nPrdtLineId = 0 00:00:12|[libCapture] nSensorId = 0 00:00:12|[libCapture] nPrdModelId = 0 00:00:12|[libCapture] nHwVersionId = 0 00:00:12|[libCapture] ERROR (CFG_findOps|265): Product ID:0 not Set! 00:00:12|[OSA-APP] encTsk Task pid=396 tid=397 00:00:12|[libpdi] ERROR (PDI_ircutCreate|339): Can't open /dev/pdcIRCut 00:00:12|[libCapture] WARN (VIDEO_aewbCreate|599): PDI_ircutCreate is fail 00:00:12|[OSA-APP] aewbTsk Task pid=396 tid=398 00:00:12|[OSA-APP] ctrlTsk Task pid=396 tid=399 00:00:12|[OSA-APP] severTsk Task pid=396 tid=400 00:00:12|[libCapture] VSERVER API: Sending START. 00:00:12|[libCapture] Sensor Initial OK! 00:00:12|[libCapture] I create encode task 00:00:12|[libencode] libencode.a svn num: 23096 compile time: Apr 16 2016 06:12:41 00:00:12|[libencode] nPrdtLineId = 0 nSensorId = 0 nHwVersionId = 0 00:00:12|[OSA-APP] cmdTsk Task pid=396 tid=401 00:00:12|[libencode] ERROR (ENCODE_mppCfg|1059): Unknow sensor 0 00:00:12|[libencode] ERROR (ENCODE_init|3511): Fail to init mpp config! 00:00:12|[libCapture] VSERVER API: Sending START...DONE 00:00:12|[libCapture] 00:00:12|[libCapture] VIDEO_serverStart() 00:00:20|[Manager] error tid:394 CCommonConfigManager::CCommonConfigManager() read config file /mnt/mtd/Config/Config1 /mnt/mtd/Config/Config2 failed 00:00:20|[Manager] warn tid:394 CCommonConfigManager::CCommonConfigManager() read old defalut config file failed. 00:00:20|[Manager] warn tid:394 CCommonConfigManager::CCommonConfigManager() read custom config file failed. 00:00:20|[libpdi] >-------System3_getSystemInfo-------> Fail to get env authcode! 00:00:20|[libpdi] Get authcode error 00:00:20|[libpdi] SeriNumBuf = 2K058B2GA100014 00:00:20|[libpdi] ERROR (PDI_comGetMapInfo|1204): Fail to Get ComMapInfo 00:00:20|[libpdi] ERROR (System_getSystemInfo|509): get deviceClass error 00:00:20|[libpdi] ERROR (System_getSystemInfo|547): get bandWidth error 00:00:20|[pdc] WARN (MISC_ioctl|591): Get SdCard cfg failed ! 00:00:20|[libpdi] deviceType: IPC-HFW1220S 00:00:20|[libpdi] processorType: 0 00:00:20|[libpdi] hardwareVersion: 1.00 00:00:20|[libpdi] appAutoStart: 0 00:00:20|[libpdi] serialNumber: 2K058B2GA100014 00:00:20|[libpdi] deviceClass: 00:00:20|[libpdi] noPtz: 1 00:00:20|[libpdi] noSdCard: 1 00:00:20|[libpdi] noRTC: 1 00:00:20|[libpdi] bandWidth: 0 00:00:20|[libpdi] <-------System3_getSystemInfo-------< 00:00:20|[Manager] warn tid:394 init:83 use default cmos def path! 00:00:20|[libpdi] read RTC_SRAM_REBOOT = 1 00:00:20|[libpdi] PDI_getStartUpFlag: 2 00:00:20|[Manager] info tid:394 CMagicBox::CMagicBox() getStartUpFlag 2 00:00:20|[Manager] warn tid:394 CFileLog::getLogsfromFile()>>> open file failed! filename = /mnt/mtd/Log/log.zip. 00:00:20|[Manager] trace tid:394 CFileLog::CFileLog()>>>>log file failed! 00:00:20|[Manager] warn tid:394 CFileLog::getLogsfromFile()>>> open file failed! filename = /mnt/mtd/Log/logbackup.zip. 00:00:20|[Manager] trace tid:394 CFileLog::CFileLog()>>>>backup log file failed! 00:00:20|[libInfra] debug tid:412 ThreadBody Enter name = EventManager, id = 412, prior = N64, stack = 0x47168ebc 00:00:20|[Manager] warn tid:394 CMagicBox::setSubModuleInfo fail! 00:00:20|[Manager] info tid:394 CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true] 00:00:20|[Manager] info tid:394 CMagicBox::startDstTune readCMOS DstTune flag is 0. 00:00:20|[libInfra] debug tid:413 ThreadBody Enter name = ClientCheck, id = 413, prior = N64, stack = 0x479caebc 00:00:20|[Manager] warn tid:394 CMagicBox::CMagicBox() load /var/tmp/pd/ProductDefinition product definition Languages file failed. 00:00:20|[Manager] error tid:394 currDevSerial:2K058B2GA100014 00:00:20|[Manager] error tid:394 DevInformation'SerialID:3c:ef:8c:ff:c6:32 00:00:20|[Manager] error tid:394 CMd5UserManager::initialize() second config file parsing failed too: 00:00:20|[Manager] trace tid:394 CMd5UserManager :: Load cfg failed(bToRead2ndFile[0] || (bMember[1] && bEqual[0])) 00:00:20|[Manager] error tid:394 currDevSerial:2K058B2GA100014, DevInformation'SerialID:3c:ef:8c:ff:c6:32 00:00:20|[Manager] error tid:394 CUserManager::setDefault() custom config file parsing failed: 00:00:20|[Manager] error tid:394 currDevSerial:2K058B2GA100014 00:00:20|[Manager] error tid:394 DevInformation'SerialID:2K058B2GA100014 00:00:20|[Manager] trace tid:394 CConsole::registerCmd had been register!! 00:00:20|[Manager] error tid:394 currDevSerial:2K058B2GA100014 00:00:20|[Manager] error tid:394 DevInformation'SerialID:3c:ef:8c:ff:c6:32 00:00:20|[Manager] error tid:394 COnvifUserManager::initialize() second config file parsing failed too: 0ID:3c:ef:8c:ff:c6:32 00:00:20|[Manager] error tid:394 currDevSerial:2K058B2GA100014 00:00:20|[Manager] trace tid:394 CConsole::registerCmd had been register!! 00:00:20|[Manager] trace tid:394 CFileLog::attachFilter 00:00:20|[Manager] warn tid:394 CMagicBox::getDeviceSubClass DeviceSubClass empty ! 00:00:20|[libpdi] WARN : Device has no crypt chip! 00:00:20|[libpdi] WARN : Device has no crypt chip! 00:00:20|[libpdi] 00:00:20|[Manager] error tid:394 Src/Locales.cpp:141 system has no supportLanguages. /var/tmp/sonia: Src/Locales.cpp: 142: virtual bool Dahua::Manager::CLocales::config(const Json::Value&): Assertion `0' failed. Aborted ####application exit:134, system will reboot! keyboard = 0 BusyBox v1.18.4 (2014-12-08 20:28:09 CST) built-in shell (ash) Revision: 7475 Enter 'help' for a list of built-in commands. ~ # |
fobos [ 20 авг 2022, 16:47 ] | |
на HWID ругается, странно...надо подумать |
mazahaka011 [ 20 авг 2022, 16:49 ] | |
fobos писал(а): на HWID ругается, странно...надо подумать Клиент мне позвонил, говорит нашел коробку от нее, а в ней... стикер :/ На стикере DH-IPC-HFW1220SP-0360B И серийник и мак как вы написали из второго варианта, такие как я прописал в камеру |
fobos [ 20 авг 2022, 16:54 ] | |
ревизия платы 28_401?...шелкография должна быть на плате |
mazahaka011 [ 20 авг 2022, 16:57 ] | |
fobos писал(а): ревизия платы 28_401? Верно, возле матрицы, ниже написано 80156462 |
fobos [ 20 авг 2022, 17:04 ] | |
все еще раз перепроверил - дал правильный дамп и остальную инфу...почему ругается на HWID не пойму...беру таймаут на подумать |
mazahaka011 [ 20 авг 2022, 17:08 ] | |
fobos писал(а): все еще раз перепроверил - дал правильный дамп и остальную инфу...почему ругается на HWID не пойму...беру таймаут на подумать Не тороплю, нисколько не горит |
fobos [ 20 авг 2022, 17:50 ] | |
попробуйте другую флешь |
mazahaka011 [ 20 авг 2022, 18:16 ] | |
fobos писал(а): попробуйте другую флешь 100% аналогичное поведение |
fobos [ 20 авг 2022, 22:40 ] | |
процессор какой установлен? 3516С или 3518? |
mazahaka011 [ 21 авг 2022, 08:16 ] | |
fobos писал(а): процессор какой установлен? 3516С или 3518? Hi3516 CRBCV100 Решил прошиться через TFTP, на hwid меньше ругаться стал)
Starting kernel ...
Uncompressing Linux... done, booting the kernel. CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518 appauto=1 dh_keyboard=0 ethaddr0=3c:ef:8c:ff:c6:32 ethaddr1=0:0:0:0:0:0 wifiAddr=0:12:34:56:78:91 lip0=192.168.1.108 lip1=0.0.0.0 id=2K058B2GA100014 U-Boot 0x30000 0x10000 0x0 hwid 0x20000 0x40000 0x0 partition 0x10000 0x60000 0x0 Kernel 0x100000 0x70000 0x0 romfs 0x490000 0x170000 0x0 web 0x190000 0x600000 0x0 config 0x60000 0x790000 0x0 num parts is 7. gLogRamRes: start=0x84f7e000;size=0x80000 dh_keyboard:0 console [ttyS0] enabled init started: BusyBox v1.18.4 (2014-12-08 20:28:09 CST) mount: mounting /dev/mtdblock5 on /mnt/doc/ failed: Invalid argument keyboard = 0 mkdir: can't create directory '/mnt/backup/Config': Read-only file system mkdir: can't create directory '/mnt/backup/debug': Read-only file system Hisilicon Media Memory Zone Manager ERROR: Conflict MMZ: PHYS(0x84D00000, 0x872FFFFF), GFP=0, nBYTES=38912KB, NAME="anonymous" MMZ conflict to kernel memory (0x80000000, 0x84FFFFFF) Add MMZ failed: PHYS(0x84D00000, 0x872FFFFF), GFP=0, nBYTES=38912KB, NAME="anonymous" Hisilicon UMAP device driver interface: v3.00 load sys.ko ...OK! insmod: can't insert 'hi3518_tde.ko': Operation not permitted insmod: can't insert 'hi3518_dsu.ko': unknown symbol in module, or unknown parameter load viu.ko ...OK! ISP Mod init! load vpss.ko ....OK! load venc.ko ...OK! load group.ko ...OK! load chnl.ko ...OK! load h264e.ko ...OK! load jpege.ko ...OK! load rc.ko ...OK! load region.ko ....OK! [OSA-DRV] OSA Build on Apr 16 2016 at 06:12:01. [OSA-DRV] SVN NUM: 1242. [OSA-DRV] Monitor Task pid=289 tid=289 [LOG-DRV] LOG Build on Apr 16 2016 at 06:02:48. [LOG-DRV] SVN NUM: 4731. [LOG-DRV] ramStart:0x84f7e000;ramSize:0x80000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 00:00:03|[Binder] Binder.ko Build on Apr 18 2016 at 19:01:41. 00:00:03|[Binder] SVN NUM: 1780. 00:00:03|[Binder] Create binder memory pool(size:524288) OK! 00:00:03|[Binder] Create binder memory pool(size:3145728) OK! 00:00:03|[Binder] NameServer Initial OK ! 00:00:03|[Binder] Binder Initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] SR driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] NS driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] Binder driver initial OK ! 00:00:03|[SPF] SPF Build on Apr 16 2016 at 06:40:12. 00:00:03|[SPF] SVN NUM: 5384. 00:00:03|[SPF] SIL initial OK ! 00:00:03|[SPF] SPF initial ok ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[SPF] SPF Proc Create OK!!! 00:00:03|[SPF] SPF driver initial ok ! 00:00:03|[prc] PRC Driver Build on Apr 16 2016 at 05:53:46. 00:00:03|[prc] SVN NUM: 2615. 00:00:03|[prc] Start to init module! 00:00:03|[prc] pinmux init ok 00:00:03|[prc] gpio soc init ok 00:00:03|[prc] spi init ok 00:00:03|[prc] IIC init ok 00:00:03|[prc] PRC_wdtInit OK 00:00:03|[prc] PRC_rtcInit OK! 00:00:03|[prc] i2c businit ok 00:00:03|[prc] DMA init ok 00:00:03|[SPF] Dai 3 register OK ! 00:00:03|[prc] IIS init: ok 00:00:03|[SPF] codecType 32 register OK ! 00:00:03|[prc] Codec init ok 00:00:03|[prc] Success to init module! 00:00:03|[pdc] PDC Build on Apr 16 2016 at 06:33:02. 00:00:03|[pdc] SVN NUM: 5609. 00:00:03|[pdc] BASE_LINE: 240 00:00:03|[pdc] OSA_kProcCreate OK 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] PDC_PartionInit ok!! 00:00:03|[pdc] HWID : IPC-HFW1220RM:01:02:02:36:13:00:01:00:00:00:00:1B8:00:00:00:00:00:00:00:00:80 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] binderFlag: 0x3, funcap: 0x8518b,0x0,0x0,0x0 00:00:00:00:04|[OSA-DRV] recordTsk Task pid=336 tid=336 03|[pdc] videoOut Channel is 0 00:00:03|[pdc] PDC_PRODUCT_OWNER: 0 00:00:03|[pdc] Find Product: IPC-HFW1220RM. 00:00:03|[pdc] wifi cut down 0 00:00:03|[pdc] sd cut down 1610612755 00:00:03|[pdc] Config size 1584 ! 00:00:03|[pdc] SenCfg Match OK,pCfgParams->pCfg: bf266568 00:00:03|[pdc] SenCfgSize: 212 Bytes 00:00:03|[pdc] Init spiBus0 Successed! 00:00:03|[pdc] Init spiBus2 Successed! 00:00:03|[prc] WARN : The I2C0 has benn created 00:00:03|[pdc] Init I2CBus0 Successed! 00:00:03|[pdc] PDC_MODULE_RESET_STATE 00:00:03|[pdc] Dev has No shutDown Cfg! 00:00:03|[pdc]Kernel: ssp initial ok! PDC_pinInit As Usual! 00:00:03|[pdc] Get reset pin: 12 OK ! 00:00:03|[pdc] Reboot system counter 1! 00:00:03|[pdc] ircut types = [0] 00:00:03|[pdc] ircut types = [1] 00:00:03|[pdc] ircut types = [2] 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[pdc] Get comPort Cfg ok !0sa 00:00:03|[pdc] PDC_comInit OK! 00:00:03|[pdc] PDC_MODULE_SENSOR 00:00:03|[pdc] Try RtcDev: SocRtc 00:00:03|[pdc] phyaddr = 84ffe000, memLen = 2000 00:00:03|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:03|[pdc] phyaddr = 84ffe000, memLen = 2000 00:00:03|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:03|[pdc] A B OK 00:00:03|[pdc] Both of Chief and Backup File CRC check OK! 00:00:03|[pdc] phyaddr = 84ffe000, memLen = 2000 00:00:03|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:03|[pdc] Both of Chief and Backup File CRC check OK! 00:00:03|[pdc] phyaddr = 84ffe000, memLen = 2000 00:00:04|[pdc] Choose RtcType: 4 -> SocRtc 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] OSA_kProcAddFile:pdcRtc OK! 00:00:04|[pdc] smartIr light count:1 00:00:04|[OSA-DRV] Char device crea00:00:05|[pdc] SramFile_devRelease OK! te OK ! 00:00:04|[pdc] OSA_kProcAddFile:pdcSmartIR OK! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] WDT proc Add OSA_kProcAddFile ok! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] ADC init ok, id: 0 ! 00:00:04|[pdc] sclGpio = [60], sdaGpio = [57] 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] WARN (PDC_keyMcuInit|249): Get mcu cfg failed!Can not init keyMcu! 00:00:04|[pdc] Dev has No Key Cfg! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] SramFile init ok ! 00:00:04|[pdc] Both of Chief and Backup File CRC check OK! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] ERROR (PDC_drvInit|175): PDC Driver Initial Failed ! 00:00:04|[pwm] WARN (/home/xia_junming/re/pdc-now/pwm/./src//pwm.c|pwm_init|509): Fail to get iris configure! CATEGORY = 2 IPC Device [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support ba00:00:06|[SEN-DRV] default fmtId=0x200 00:00:07|[SEN-DRV] format set to id:0x200 00:00:07|[SEN-DRV] Succeed to init sensor with format=0x200. Fail to get env coremnt! 17:56:49|[systools] WARN : coremnt not found Syshelper: WdtSatrtTime = 60(s), appauto = 1, hctosystim17:56:49|[OSA-DRV] blackRecalcTsk Task pid=359 tid=359 e = 1500 17:56:49|[SEN-DRV] black Recalc !!! ;32m17:56:49|[SEN-DRV] Sensor 61 Init OK. 17:56:49|[OSA-DRV] Char device create OK ! 17:56:49|[libpdi] ERROR (NetGetMAC|2411): SIOCGIFHWADDR,eth0 product_name =IPC-HFW1220RM fvideo_chip = 61 sdcard_cap = 0 [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 17:56:49|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! [libpdi] can't find commLen cfg [Systools]: Build on Apr 17 2016 at 03:00:27. [Systools]:SVN NUM: 21111. init eth0 to default 17:56:49|[libpdi] NET_disableRoute = 0 eth0: MAC: <3c:ef:8c:ff:c6:32> 17:56:49|[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO17:56:49|[libpdi] set eth0 as defaultEth IP: <192.168.1.108> netmask: <255.255.255.0> Gateway: <192.168.1.1> 17:56:49|[libpdi] ERROR (save_Attr_file|1269): open failed for HOSTIP17:56:49|[libpdi] ERROR (save_Attr_file|1269): open failed for SUBMASK17:56:49|[libpdi] SetGateWay success [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 17:56:50|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! [libpdi] can't find commLen cfg [Systools]: Build on Apr 17 2016 at 03:00:27. [Systools]:SVN NUM: 21111. IPV6: only init eth0 17:56:50|[libpdi] NET_disableRoute = 0 "netinit6 help" for help eth0: MAC: <3c:ef:8c:ff:c6:32> IPV6: <2001:250:3000:1::1:2> preFixLen: <112> 17:56:50|[libpdi] WARN (NetWorkDelIP|1124): del ip failed:Cannot assign requested address 17:56:50|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 17:56:50|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup 17:56:50|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 17:56:50|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup IPV6 Gateway: <2001:250:3000:1::1:1> 17:56:50|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 17:56:50|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup unzip: can't open /mnt/pd/product.zip, /mnt/pd/product.zip.zip, /mnt/pd/product.zip.ZIP cp: can't stat '/var/tmp/product/ProductTransform': No such file or directory product = IPC-HFW12XX cp: can't stat '/var/tmp/product/IPC-HFW12XX/*': No such file or directory sed: /var/tmp/pd/CustomConfig: No such file or directory NULL string appauto=1 [OSA-APP] OSA Build on Apr 16 2016 at 06:11:48. [OSA-APP] SVN NUM: 1086. 17:56:56|[libenc] libenc.a svn num: 23096 compile time: Apr 16 2016 06:12:33 17:56:56|[Binder-Lib] libbinder.so Build on Apr 18 2016 at 19:01:39. 17:56:56|[Binder-Lib] SVN NUM: 1780. 17:56:56|[libpdi] libpdi.so Build on Apr 16 2016 at 06:27:13. 17:56:56|[libpdi] SVN NUM: 21357. 17:56:56|[OSA-APP] Monitor Task pid=434 tid=435 17:56:56|[libpdi] Get fpga upgrade cfg failed, use default 17:56:56|[libpdi] Not support backup partition !!! 17:56:56|[libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 17:56:56|[libpdi] The device has no crypt chip! 17:56:56|[libpdi] phyaddr= 0x84ffe000, memLen= 0x2000 17:56:56|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! 17:56:56|[libpdi] can't find commLen cfg 17:56:56|[libCapture] 17:56:56|[libCapture] VideoDaemon Build on Apr 16 2016 at 06:12:28. 17:56:56|[libCapture] SVN NUM: 22188. 17:56:56|[libCapture] nPrdtLineId = 2 17:56:56|[libCapture] nSensorId = 61 17:56:56|[libCapture] nPrdModelId = 188 17:56:56|[libCapture] nHwVersionId = 0 17:56:56|[libCapture] Product name:HF5200! 17:56:56|CFG_prvInit_HF5200 17:56:56|[OSA-APP] encTsk Task pid=436 tid=437 17:56:56|[libpdi] ircutType 1 17:56:56|[OSA-APP] aewbTsk Task pid=436 tid=438 17:56:56|[OSA-APP] ctrlTsk Task pid=436 tid=439 17:56:56|[OSA-APP] severTsk Task pid=436 tid=440 17:56:56|[libCapture] VSERVER API: Sending START. 17:56:56|[AEW] AEWB ALG Build on Apr 16 2016 at 06:14:07. 17:56:56|[AEW] SVN NUM: 26647. 17:56:56|[AEW] plat is created ok! 17:56:56|[AEW] params is created ok! 17:56:56|[AEW] params is inited ok! 17:56:56|[AEW] msg between 2A and sonia is created ok! 17:56:56|[libpdi] ircutType 1 17:56:56|[AEW] icr is created ok! 17:56:56|[AEW] smartIr is created ok! 17:56:56|[libpdi] pAdcObj->aDex = 1.000000 17:56:56|[libpdi] pAdcObj->bDex = 0.000000 17:56:56|[AEW] ADC is created ok, type is 4! 17:56:56|[libpdi] ERROR (PDI_irisCreate|226): Can't open /dev/pdcIris create iris handle failed 17:56:56|[libpdi] >-------System3_getSystemInfo-------> Fail to get env authcode! 17:56:56|[libpdi] Get authcode error 17:56:56|[libpdi] SeriNumBuf = 2K058B2GA100014 17:56:56|[pdc] WARN (MISC_ioctl|591): Get SdCard cfg failed ! 17:56:56|[libpdi] deviceType: IPC-HFW1220S 17:56:56|[libpdi] processorType: 19 17:56:56|[libpdi] hardwareVersion: 1.00 17:56:56|[libpdi] appAutoStart: 1 17:56:56|[libpdi] serialNumber: 2K058B2GA100014 17:56:56|[libpdi] deviceClass: IPC 17:56:56|[libpdi] noPtz: 1 17:56:56|[libpdi] noSdCard: 1 17:56:56|[libpdi] noRTC: 0 17:56:56|[libpdi] bandWidth: 24 17:56:56|[libpdi] <-------System3_getSystemInfo-------< 17:56:56|[AEW] -------------SN: 2K058B2GA1 17:56:56|[AEW] aewb creat over 17:56:56|[libCapture] IMX122 17:56:56|[libCapture] Sensor IMX122 Initial OK! 17:56:56|[libCapture] I create encode task 17:56:56|[libencode] libencode.a svn num: 23096 compile time: Apr 16 2016 06:12:41 17:56:56|[libencode] nPrdtLineId = 2 nSensorId = 61 nHwVersionId = 0 17:56:56|[OSA-APP] cmdTsk Task pid=436 tid=441 17:56:56|[libencode] ERROR (ENCODE_hiMppInit|575): HI_MPI_VB_Init failed! 17:56:56|[libencode] ERROR (ENCODE_mppInit|2561): Fail to init hi mpp! 17:56:56|[libencode] ERROR (ENCODE_init|3518): Fail to init mpp! 17:56:56|[libCapture] VSERVER API: Sending START...DONE 17:56:56|[libCapture] 17:56:56|[libCapture] VIDEO_serverStart() 17:56:59|[SEN-DRV] black Recalc !!! 17:57:04|[Manager] error tid:434 CCommonConfigManager::CCommonConfigManager() read config file /mnt/mtd/Config/Config1 /mnt/mtd/Config/Config2 failed 17:57:04|[Manager] warn tid:434 CCommonConfigManager::CCommonConfigManager() read old defalut config file failed. 17:57:04|[Manager] warn tid:434 CCommonConfigManager::CCommonConfigManager() read custom config file failed. 17:57:04|[libpdi] >-------System3_getSystemInfo-------> Fail to get env authcode! 17:57:04|[libpdi] Get authcode error 17:57:04|[libpdi] SeriNumBuf = 2K058B2GA100014 17:57:04|[pdc] WARN (MISC_ioctl|591): Get SdCard cfg failed ! 17:57:04|[libpdi] deviceType: IPC-HFW1220S 17:57:04|[libpdi] processorType: 19 17:57:04|[libpdi] hardwareVersion: 1.00 17:57:04|[libpdi] appAutoStart: 1 17:57:04|[libpdi] serialNumber: 2K058B2GA100014 17:57:04|[libpdi] deviceClass: IPC 17:57:04|[libpdi] noPtz: 1 17:57:04|[libpdi] noSdCard: 1 17:57:04|[libpdi] noRTC: 0 17:57:04|[libpdi] bandWidth: 24 17:57:04|[libpdi] <-------System3_getSystemInfo-------< 17:57:04|[Manager] warn tid:434 init:83 use default cmos def path! 17:57:04|[libpdi] read RTC_SRAM_REBOOT = 1 17:57:04|[libpdi] PDI_getStartUpFlag: 2 17:57:04|[Manager] info tid:434 CMagicBox::CMagicBox() getStartUpFlag 2 17:57:04|[Manager] warn tid:434 CFileLog::getLogsfromFile()>>> open file failed! filename = /mnt/mtd/Log/log.zip. 17:57:04|[Manager] trace tid:434 CFileLog::CFileLog()>>>>log file failed! 17:57:04|[Manager] warn tid:434 CFileLog::getLogsfromFile()>>> open file failed! filename = /mnt/mtd/Log/logbackup.zip. 17:57:04|[Manager] trace tid:434 CFileLog::CFileLog()>>>>backup log file failed! 17:57:04|[Manager] warn tid:434 CMagicBox::setSubModuleInfo fail! 17:57:04|[Manager] info tid:434 CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true] 17:57:04|[libInfra] debug tid:452 ThreadBody Enter name = EventManager, id = 452, prior = N64, stack = 0x46e8febc 17:57:04|[libInfra] debug tid:453 ThreadBody Enter name = ClientCheck, id = 453, prior = N64, stack = 0x476b9ebc 17:57:04|[Manager] info tid:434 CMagicBox::startDstTune readCMOS DstTune flag is 0. 17:57:04|[Manager] warn tid:434 CMagicBox::CMagicBox() load /var/tmp/pd/ProductDefinition product definition Languages file failed. 17:57:04|[Manager] error tid:434 currDevSerial:2K058B2GA100014 17:57:04|[Manager] error tid:434 DevInformation'SerialID:2K058B2GA100014 17:57:04|[Manager] error tid:434 currDevSerial:2K058B2GA100014 17:57:04|[Manager] error tid:434 DevInformation'SerialID:2K058B2GA100014 17:57:04|[Manager] trace tid:434 CConsole::registerCmd had been register!! 17:57:04|[Manager] error tid:434 currDevSerial:2K058B2GA100014 17:57:04|[Manager] error tid:434 DevInformation'SerialID:2K058B2GA100014 17:57:04|[Manager] error tid:434 currDevSerial:2K058B2GA100014 17:57:04|[Manager] error tid:434 DevInformation'SerialID:2K058B2GA100014 17:57:04|[Manager] trace tid:434 CConsole::registerCmd had been register!! 17:57:04|[Manager] trace tid:434 CFileLog::attachFilter 17:57:04|[Manager] warn tid:434 CMagicBox::getDeviceSubClass DeviceSubClass empty ! 17:57:05|[libpdi] WARN : Device has no crypt chip! 17:57:05|[libpdi] WARN : Device has no crypt chip! 17:57:05|[libpdi] 17:57:04|[Manager] error tid:434 Src/Locales.cpp:141 system has no supportLanguages. /var/tmp/sonia: Src/Locales.cpp: 142: virtual bool Dahua::Manager::CLocales::config(const Json::Value&): Assertion `0' failed. Aborted ####application exit:134, system will reboot! keyboard = 0 BusyBox v1.18.4 (2014-12-08 20:28:09 CST) built-in shell (ash) Revision: 7475 Enter 'help' for a list of built-in commands. ~ # 17:57:09|[SEN-DRV] black Recalc !!! |
fobos [ 22 авг 2022, 09:07 ] | |
Заголовок сообщения: | Re: [Ищу дамп] Dahua IPC-HFW1220SP (?) [РЕШЕНО] |
пробуйте дамп с рабочей камеры, только ID и MAC свой пропишите https://cloud.mail.ru/public/zAHR/AzwEw6vJV |
mazahaka011 [ 22 авг 2022, 13:11 ] | |
fobos писал(а): пробуйте дамп с рабочей камеры, только ID и MAC свой пропишите https://cloud.mail.ru/public/zAHR/AzwEw6vJV Огромное спасибо! Прописал ID и МАС. Камера завелась и нашлась на 192.168.1.92. Сменил пароль. Все работает! |
fobos [ 22 авг 2022, 14:04 ] | |
покажите printenv и полный лог, пожалуйста, с работающей камеры...хочу посмотреть почему заводской дамп не подошел...и потом пропишите dh_keyboard 1, чтобы лог в терминал не сыпал |
mazahaka011 [ 22 авг 2022, 14:12 ] | |
fobos писал(а): покажите printenv и полный лог, пожалуйста, с работающей камеры... Уже только завтра. Сегодня уже уехал, к сожалению |
mazahaka011 [ 23 авг 2022, 17:15 ] | |
fobos писал(а): покажите printenv и полный лог, пожалуйста, с работающей камеры... Как и просили.
лог
U-Boot 2010.06-svn2464 (Jul 07 2015 - 06:01:47)
DRAM: 256 MiB gBootLogPtr:80b80008. Check spi flash controller v350... Found Spi(cs1) ID: 0xC8 0x40 0x17 0xC8 0x40 0x17 Spi(cs1): Block:64KB Chip:8MB Name:"GD25Q64C" boot from spi boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 In: serial Out: serial Err: serial TEXT_BASE:81000000 Hisilicon ETH net controler MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: * Retry count exceeded; starting again Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M *** ERROR: `serverip' not set Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:0' miiphy_register: non unique device name '0:2' MAC: 3C-EF-8C-FF-C6-32 UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'failed.txt'. Download to address: 0x82000000 Downloading: * Retry count exceeded; starting again SPI probe: 8192 KiB hi_sfc at 0:0 is now current device Wrong Image Format for bootm command ERROR: can't get kernel image! try:kload 0x82000000 succeed! ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.0.8 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 861708 Bytes = 841.5 KiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK boot from spi partition file version 2 rootfstype squashfs root /dev/mtdblock4 cmdLine mem=77M console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518 appauto=1 dh_keyboard=0 ethaddr0=3c:ef:8c:ff:c6:32 ethaddr1=0:0:0:0:0:0 wifiAddr=0:12:34:56:78:91 lip0=192.168.1.108 lip1=0.0.0.0 id=2K058B2GA100014 U-Boot 0x30000 0x10000 0x0 hwid 0x20000 0x40000 0x0 partition 0x10000 0x60000 0x0 Kernel 0x100000 0x70000 0x0 romfs 0x490000 0x170000 0x0 web 0x190000 0x600000 0x0 config 0x60000 0x790000 0x0 num parts is 7. gLogRamRes: start=0x84c7e000;size=0x80000 dh_keyboard:0 console [ttyS0] enabled init started: BusyBox v1.18.4 (2014-12-08 20:28:09 CST) keyboard = 0 mkdir: can't create directory '/mnt/backup/Config': Read-only file system mkdir: can't create directory '/mnt/backup/debug': Read-only file system Hisilicon Media Memory Zone Manager Hisilicon UMAP device driver interface: v3.00 pa:84d00000, va:c51c0000 load sys.ko ...OK! load viu.ko ...OK! ISP Mod init! load vpss.ko ....OK! load venc.ko ...OK! load group.ko ...OK! load chnl.ko ...OK! load h264e.ko ...OK! load jpege.ko ...OK! load rc.ko ...OK! load region.ko ....OK! [OSA-DRV] OSA Build on Jul 7 2015 at 05:46:58. [OSA-DRV] SVN NUM: 1242. [OSA-DRV] Monitor Task pid=292 tid=292 [LOG-DRV] LOG Build on Jul 7 2015 at 05:41:41. [LOG-DRV] SVN NUM: 4731. [LOG-DRV] ramStart:0x84c7e000;ramSize:0x80000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 00:00:03|[Binder] Binder.ko Build on Jul 7 2015 at 05:36:23. 00:00:03|[Binder] SVN NUM: 1780. 00:00:03|[Binder] Create binder memory pool(size:524288) OK! 00:00:03|[Binder] Create binder memory pool(size:3145728) OK! 00:00:03|[Binder] NameServer Initial OK ! 00:00:03|[Binder] Binder Initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] SR driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] NS driver initial OK ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[Binder] Binder driver initial OK ! 00:00:03|[SPF] SPF Build on Jul 7 2015 at 06:13:45. 00:00:03|[SPF] SVN NUM: 5384. 00:00:03|[SPF] SIL initial OK ! 00:00:03|[SPF] SPF initial ok ! 00:00:03|[OSA-DRV] Char device create OK ! 00:00:03|[SPF] SPF Proc Create OK!!! 00:00:03|[SPF] SPF driver initial ok ! 00:00:03|[prc] PRC Driver Build on Jul 7 2015 at 06:37:44. 00:00:03|[prc] SVN NUM: 2615. 00:00:03|[prc] Start to init module! 00:00:03|[prc] pinmux init ok 00:00:03|[prc] gpio soc init ok 00:00:03|[prc] spi init ok 00:00:03|[prc] IIC init ok 00:00:03|[prc] PRC_wdtInit OK 00:00:03|[prc] PRC_rtcInit OK! 00:00:03|[prc] i2c businit ok 00:00:03|[prc] DMA init ok 00:00:03|[SPF] Dai 3 register OK ! 00:00:03|[prc] IIS init: ok 00:00:03|[SPF] codecType 32 register OK ! 00:00:03|[prc] Codec init ok 00:00:03|[prc] Success to init module! 00:00:04|[pdc] PDC Build on Jul 7 2015 at 06:08:12. 00:00:04|[pdc] SVN NUM: 5417. 00:00:04|[pdc] BASE_LINE: 240 00:00:04|[pdc] OSA_kProcCreate OK 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] PDC_PartionInit ok!! 00:00:04|[pdc] HWID : IPC-HFW1220RM:01:02:02:36:13:00:01:00:00:00:00:1B8:00:00:00:00:00:00:00:00:80 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] binderFlag: 0x3, funcap: 0x8518b,0x0,0x0,0x0 00:00:04|[pdc] videoOut Channel is 0 00:00:04|[OSA-DRV] recordTsk Task pid=336 tid=336 00:00:04|[pdc] PDC_PRODUCT_OWNER: 0 00:00:04|[pdc] Find Product: IPC-HFW1220RM. 00:00:04|[pdc] wifi cut down 0 00:00:04|[pdc] sd cut down 1610612755 00:00:04|[pdc] Config size 1584 ! 00:00:04|[pdc] SenCfg Match OK,pCfgParams->pCfg: bf263ce4 00:00:04|[pdc] SenCfgSize: 212 Bytes 00:00:04|[pdc] Init spiBus0 Successed! 00:00:04|[pdc] Init spiBus2 Successed! 00:00:04|[prc] WARN : The I2C0 has benn created 00:00:04|[pdc] Init I2CBus0 Successed! 00:00:04|[pdc] PDC_MODULE_RESET_STATE 00:00:04|[pdc] Dev has No shutDown Cfg! 00:00:04|[pdc] PDC_pinInit As Usual! 00:00:04|[pdc] Get reset pin: 12 OK ! 00:00:04|[Kernel: ssp initial ok! pdc] Reboot system counter 1! 00:00:04|[pdc] ircut types = [0] 00:00:04|[pdc] ircut types = [1] 00:00:04|[pdc] ircut types = [2] 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] Get comPort Cfg ok !0sa 00:00:04|[pdc] PDC_comInit OK! 00:00:04|[pdc] PDC_MODULE_SENSOR 00:00:04|[pdc] Try RtcDev: SocRtc 00:00:04|[pdc] phyaddr = 84cfe000, memLen = 2000 00:00:04|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:04|[pdc] phyaddr = 84cfe000, memLen = 2000 00:00:04|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:04|[pdc] A B OK 00:00:04|[pdc] Both of Chief and Backup File CRC check OK! 00:00:04|[pdc] phyaddr = 84cfe000, memLen = 2000 00:00:04|[pdc] DDRdata crc incorrect, Load from sramFile 00:00:04|[pdc] Both of Chief and Backup File CRC check OK! 00:00:04|[pdc] phyaddr = 84cfe000, memLen = 2000 00:00:04|[pdc] Choose RtcType: 4 -> SocRtc 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] OSA_kProcAddFile:pdcRtc OK! 00:00:04|[pdc] smartIr light count:1 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] OSA_kProcAddFile:pdcSmartIR OK! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] WDT proc Add OSA_kProcAddFile ok! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] ADC init ok, id: 0 ! 00:00:04|[pdc] sclGpio = [60], sdaGpio = [57] 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] WARN (PDC_keyMcuInit|249): Get mcu cfg failed!Can not init keyMcu! 00:00:04|[pdc] Dev has No Key Cfg! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] SramFile init ok ! 00:00:04|[pdc] Both of Chief and Backup File CRC check OK! 00:00:04|[OSA-DRV] Char device create OK ! 00:00:04|[pdc] ERROR (PDC_drvInit|175): PDC Driver Initial Failed ! 00:00:04|[pwm] WARN (/home/xia_junming/re/pdc-now/pwm/./src//pwm.c|pwm_init|509): Fail to get iris configure! 00:00:05|[pdc] SramFile_devRelease OK! CATEGORY = 2 IPC Device [OSA-APP] OSA Build on Jul 7 2015 at 05:46:52. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Jul 7 2015 at 06:02:51. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84cfe000, memLen= 0x2000 00:00:06|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! [libpdi] can't find commLen cfg [Systools]: Build on Jul 7 2015 at 06:03:11. [Systools]:SVN NUM: 21111. [OSA-APP] OSA Build on Jul 7 2015 at 05:46:52. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Jul 7 2015 at 06:02:51. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84cfe000, memLen= 0x2000 00:00:06|[pdc] Both of Chief and Backup File CRC check OK! 00:00:06|[SEN-DRV] Sensor Build on Jul 7 2015 at 05:51:54. 00:00:06|[SEN-DRV] SVN NUM: 4288. 00:00:06|[SEN-DRV] Set default clk srcClk 27000000 pixClk 74250000 00:00:06|[SEN-DRV] write reg table type parallel 00:00:07|[SEN-DRV] default fmtId=0x200 00:00:07|[SEN-DRV] format set to id:0x200 00:00:07|[SEN-DRV] Succeed to init sensor with format=0x200. Fail to get env hwidEx! [libpdi] can't find commLen cfg UPGRADED_MSG: Do memlock Fail to get env coremnt! 00:05:20|[systools] WARN : coremnt not found Syshelper: WdtSatrtTime = 60(s), appauto = 1, hctosystim00:05:20|[OSA-DRV] blackRecalcTsk Task pid=358 tid=358 e = 1500 00:05:20|[SEN-DRV] black Recalc !!! ;32m00:05:20|[SEN-DRV] Sensor 61 Init OK. 00:05:20|[OSA-DRV] Char device create OK ! 00:05:20|[libpdi] ERROR (NetGetMAC|2411): SIOCGIFHWADDR,eth0 Name: upgraded, bulid date: Jul 7 2015 06:11:07, svn: 352 UPGRADED_MSG: start download file! product_name =IPC-HFW1220RM fvideo_chip = 61 sdcard_cap = 0 [OSA-APP] OSA Build on Jul 7 2015 at 05:46:52. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Jul 7 2015 at 06:02:51. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84cfe000, memLen= 0x2000 00:05:20|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! [libpdi] can't find commLen cfg [Systools]: Build on Jul 7 2015 at 06:03:11. [Systools]:SVN NUM: 21111. init eth0 to default 00:05:20|[libpdi] NET_disableRoute = 0 eth0: MAC: <3c:ef:8c:ff:c6:32> 00:05:20|[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO00:05:20|[libpdi] set eth0 as defaultEth IP: <192.168.0.220> netmask: <255.255.255.0> Gateway: <192.168.0.1> 00:05:20|[libpdi] ERROR (save_Attr_file|1269): open failed for HOSTIP00:05:20|[libpdi] ERROR (save_Attr_file|1269): open failed for SUBMASK00:05:21|[libpdi] SetGateWay success [OSA-APP] OSA Build on Jul 7 2015 at 05:46:52. [OSA-APP] SVN NUM: 1086. [libpdi] libpdi.so Build on Jul 7 2015 at 06:02:51. [libpdi] SVN NUM: 21357. [libpdi] Get fpga upgrade cfg failed, use default [libpdi] Not support backup partition !!! [libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 [libpdi] The device has no crypt chip! [libpdi] phyaddr= 0x84cfe000, memLen= 0x2000 00:05:21|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! [libpdi] can't find commLen cfg [Systools]: Build on Jul 7 2015 at 06:03:11. [Systools]:SVN NUM: 21111. IPV6: only init eth0 00:05:21|[libpdi] NET_disableRoute = 0 "netinit6 help" for help eth0: MAC: <3c:ef:8c:ff:c6:32> IPV6: <2001:250:3000:1::1:2> preFixLen: <112> 00:05:21|[libpdi] WARN (NetWorkDelIP|1124): del ip failed:Cannot assign requested address 00:05:21|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:05:21|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup 00:05:21|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:05:21|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup IPV6 Gateway: <2001:250:3000:1::1:1> 00:05:21|[libpdi] ERROR (NetWorkSetConfig6|566): Open and create failed 00:05:21|[libpdi] ERROR (NetWorkSaveAttributes|1265): Cann't save Attributes into Backup product = IPC-HFW12XX appauto=1 [OSA-APP] OSA Build on Jul 7 2015 at 05:46:52. [OSA-APP] SVN NUM: 1086. 00:05:27|[libenc] libenc.a svn num: 23096 compile time: Jul 7 2015 05:47:12 00:05:27|[Binder-Lib] libbinder.so Build on Jul 7 2015 at 05:36:20. 00:05:27|[Binder-Lib] SVN NUM: 1780. 00:05:27|[OSA-APP] Monitor Task pid=428 tid=429 00:05:27|[libpdi] libpdi.so Build on Jul 7 2015 at 06:02:51. 00:05:27|[libpdi] SVN NUM: 21357. 00:05:27|[libpdi] Get fpga upgrade cfg failed, use default 00:05:27|[libpdi] Not support backup partition !!! 00:05:27|[libpdi] Flashtype = 3,patSize = 30000,rwSize = 10000,ersSize = 10000 00:05:27|[libpdi] The device has no crypt chip! 00:05:27|[libpdi] phyaddr= 0x84cfe000, memLen= 0x2000 00:05:27|[pdc] Both of Chief and Backup File CRC check OK! Fail to get env hwidEx! 00:05:27|[libpdi] can't find commLen cfg 00:05:27|[libCapture] 00:05:27|[libCapture] VideoDaemon Build on Jul 7 2015 at 05:47:07. 00:05:27|[libCapture] SVN NUM: 22188. 00:05:27|[libCapture] nPrdtLineId = 2 00:05:27|[libCapture] nSensorId = 61 00:05:27|[libCapture] nPrdModelId = 188 00:05:27|[libCapture] nHwVersionId = 0 00:05:27|[libCapture] Product name:HF5200! 00:05:27|CFG_prvInit_HF5200 00:05:27|[OSA-APP] encTsk Task pid=430 tid=431 00:05:27|[libpdi] ircutType 1 00:05:27|[OSA-APP] aewbTsk Task pid=430 tid=432 00:05:27|[OSA-APP] ctrlTsk Task pid=430 tid=433 00:05:27|[OSA-APP] severTsk Task pid=430 tid=434 00:05:27|[libCapture] VSERVER API: Sending START. 00:05:27|[AEW] AEWB ALG Build on Jul 7 2015 at 15:36:12. 00:05:27|[AEW] SVN NUM: 23162. 00:05:27|[AEW] plat is created ok! 00:05:27|[AEW] params is created ok! 00:05:27|[AEW] params is inited ok! 00:05:27|[AEW] msg between 2A and sonia is created ok! 00:05:27|[libpdi] ircutType 1 00:05:27|[AEW] icr is created ok! 00:05:27|[AEW] smartIr is created ok! 00:05:27|[libpdi] pAdcObj->aDex = 1.000000 00:05:27|[libpdi] pAdcObj->bDex = 0.000000 00:05:27|[AEW] ADC is created ok, type is 4! 00:05:27|[libpdi] >-------System3_getSystemInfo-------> Fail to get env authcode! 00:05:27|[libpdi] Get authcode error 00:05:27|[libpdi] SeriNumBuf = 2K058B2GA100014 00:05:27|[pdc] WARN (MISC_ioctl|540): Get SdCard cfg failed ! 00:05:27|[libpdi] deviceType: IPC-HDW1220S 00:05:27|[libpdi] processorType: 19 00:05:27|[libpdi] hardwareVersion: 1.00 00:05:27|[libpdi] appAutoStart: 1 00:05:27|[libpdi] serialNumber: 2K058B2GA100014 00:05:27|[libpdi] deviceClass: IPC 00:05:27|[libpdi] noPtz: 1 00:05:27|[libpdi] noSdCard: 1 00:05:27|[libpdi] noRTC: 0 00:05:27|[libpdi] bandWidth: 24 00:05:27|[libpdi] <-------System3_getSystemInfo-------< 00:05:27|[AEW] -------------SN: 2K058B2GA1 00:05:27|[AEW] aewb creat over 00:05:27|[libCapture] IMX122 00:05:27|[libCapture] Sensor IMX122 Initial OK! 00:05:27|[libCapture] I create encode task 00:05:27|[libencode] libencode.a svn num: 23096 compile time: Jul 7 2015 05:47:21 00:05:27|[libencode] nPrdtLineId = 2 nSensorId = 61 nHwVersionId = 0 00:05:27|[OSA-APP] cmdTsk Task pid=430 tid=435 00:05:27|[libencode] nSensorId 0x3d nSensorInst 0x0 00:05:27|[AEW] isp params register to sensor 61 00:05:27|[AEW] isp linear mode5570651 00:05:27|[AEW] black level linear 00:05:27|[AEW] ae def linear 00:05:27|[AEW] awb def linear 00:05:27|[libencode] HISEN_init Done 00:05:27|ALG_aewStart enc [1920 1080] sensor [1920 1080]! 00:05:27|[libCapture] Start VIDEO_apiAewbLock 00:05:27|[AEW] begin start aewb...... 00:05:27|[AEW] aewb module is starting...... 00:05:27|[AEW] linear mode params is inited ok! 00:05:27|[AEW] plat module is inited ok! 00:05:27|[AEW] encWidth = 1920,encHeight = 1080,realWidth = 1920,realHeight = 1080 00:05:27|[AEW] awb module is inited ok! 00:05:27|[AEW] ICR:the state is inited to b&w and night icr! 00:05:27|[AEW] SMARTIR:the state is inited to closed! 00:05:27|[AEW] evTagFlag = 1 00:05:27|[AEW] gammalevel = 50, currGamma = 8, endGamma = 25 00:05:27|[AEW] ISP module is inited ok! 00:05:27|[AEW] aew module is started,time = 10 ms 00:05:27|[libCapture] Start VIDEO_apiAewbUnlock 00:05:27|ALG_aewStart Done! 00:05:27|[libencode] success to register cmd record! 00:05:27|[libencode] success to register cmd rawCapture! 00:05:27|[libencode] success to register cmd setrc! 00:05:27|[libencode] success to register cmd isp! 00:05:27|[libencode] success to register cmd task! 00:05:27|[libencode] success to register cmd bitrate! 00:05:27|[libencode] success to register cmd yuvCapture! 00:05:27|[libencode] success to register cmd encode! 00:05:27|[AEW] aew is runing! 00:05:27|[OSA-APP] debug Task pid=430 tid=437 00:05:27|[libCapture] VSERVER API: Sending START...DONE 00:05:27|[libCapture] 00:05:27|[libCapture] VIDEO_serverStart() 00:05:27|[AEW] fullLine = 1328 00:05:28|[AEW] ae get params ok 00:05:28|[AEW] ae Route state change to 1 success 00:05:28|[AEW] set ae ctrl params is ok 00:05:28|[AEW] set ae flicker params is ok 00:05:28|[AEW] set ae iris params is ok! 00:05:28|[AEW] set ae type params is ok! 00:05:28|[AEW] default c2bThr is 20.000000 00:05:29|[libenc] BND_2(IENC_COM_00000001 --> 28191396) 00:05:29|[libencode] IENC_CMD_SET_STOP_DTC 00:05:29|[AEW] ICR parm->value:1 00:05:29|[pdc] needReverse = 1 00:05:29|[pdc] ....turn into DAY mode.... 00:05:29|[AEW] set ktnf params ok 00:05:29|[libCapture] SetViEnable = 0 00:05:29|[libencode] IENC_CMD_SET_VI_ENABLE: 0 00:05:29|[libCapture] SetViEnable = 0 Done 00:05:29|[AEW] linear mode params is inited ok! 00:05:29|[AEW] ######sensor Disable VI###### 00:05:29|[AEW] ++sensor operation mode change to 0 00:05:29|[AEW] set sensor operation mode ok... 00:05:29|[AEW] set drc params ok 00:05:29|[AEW] gammalevel = 50, currGamma = 8, endGamma = 25 00:05:29|[AEW] Set gamma ok! 00:05:29|[AEW] Change CCM OK! 00:05:29|[AEW] Set ccm ok! 00:05:29|[AEW] 111 Set Auto Shading table Success 00:05:29|[AEW] Set shading ok! 00:05:30|[SEN-DRV] black Recalc !!! 00:05:30|[AEW] set ae ctrl params is ok 00:05:30|[AEW] ######sensor operation mode change###### 00:05:30|[AEW] ae get params ok 00:05:30|[AEW] set ae ctrl params is ok 00:05:30|[AEW] set awb params ok 00:05:30|[AEW] curr shp level =50 00:05:30|[AEW] set sharpen params ok 00:05:30|[AEW] set 2D denoise params ok 00:05:30|[AEW] set ktnf params ok 00:05:30|[AEW] set cfa params ok 00:05:30|[AEW] set sensor operation mode ok... 00:05:30|[AEW] set drc params ok 00:05:30|[AEW] gammalevel = 50, currGamma = 8, endGamma = 25 00:05:30|[AEW] Set gamma ok! 00:05:30|[AEW] Change CCM OK! 00:05:30|[AEW] Set ccm ok! 00:05:30|[AEW] set blc params ok 00:05:31|[libCapture] SetViEnable = 1 00:05:31|[libencode] IENC_CMD_SET_VI_ENABLE: 1 00:05:31|[libCapture] SetViEnable = 1 Done 00:05:31|[AEW] ######sensor re_enable VI###### 00:05:31|[AEW] set all AEW run flags is OK ... ########## SSL_library_init #################### ########## OpenSSL_add_all_algorithms ########## ########## SSL_load_error_strings ############## ########## OpenSSL1.0.1j Ready ################# 00:05:36|[libpdi] >-------System3_getSystemInfo-------> Fail to get env authcode! 00:05:36|[libpdi] Get authcode error 00:05:36|[libpdi] SeriNumBuf = 2K058B2GA100014 00:05:36|[pdc] WARN (MISC_ioctl|540): Get SdCard cfg failed ! 00:05:36|[libpdi] deviceType: IPC-HDW1220S 00:05:36|[libpdi] processorType: 19 00:05:36|[libpdi] hardwareVersion: 1.00 00:05:36|[libpdi] appAutoStart: 1 00:05:36|[libpdi] serialNumber: 2K058B2GA100014 00:05:36|[libpdi] deviceClass: IPC 00:05:36|[libpdi] noPtz: 1 00:05:36|[libpdi] noSdCard: 1 00:05:36|[libpdi] noRTC: 0 00:05:36|[libpdi] bandWidth: 24 00:05:36|[libpdi] <-------System3_getSystemInfo-------< 00:05:36|[Manager] warn init:82 use default cmos def path! 00:05:36|[libpdi] read RTC_SRAM_REBOOT = 1 00:05:36|[libpdi] PDI_getStartUpFlag: 2 00:05:36|[Manager] info CMagicBox::CMagicBox() getStartUpFlag 2 00:05:36|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:36|[Manager] trace CFileLog::append detail = { "Time" : "2022-08-23 17:18:09" } , type = Abort, device = (null) 00:05:36|[libInfra] debug ThreadBody Enter name = [EventManager], id = 443, prior = N64, stack = 0x44186ebc 00:05:36|[Manager] trace CFileLog::append detail = { "Flag" : 2 } , type = StartUp, device = (null) 00:05:36|[Manager] warn CMagicBox::setSubModuleInfo fail! 00:05:36|[Manager] info CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true] 00:05:36|[Manager] info CMagicBox::startDstTune readCMOS DstTune flag is 0. 00:05:36|[libInfra] debug ThreadBody Enter name = WatchDog, id = 444, prior = N1, stack = 0x44a10ebc 00:05:36|[Manager] info CMagicBox::m_systemInfo.noPtz == [1] 00:05:36|[Manager] info CMagicBox::m_systemInfo.noSdCard == [1] 00:05:36|[Manager] info CMagicBox::m_systemInfo.bandWidth == [24] 00:05:36|[Manager] debug setProductTransform: DeviceTypeTransform = { "CEList" : { "CE-C100" : "LC003", "CE-C10S" : "LC004" }, "General" : { "CE-C100" : "IP Camera", "CE-TO1" : "IP Camera", "CE-TP1" : "IP Camera", "Default" : "IP Camera", "IPC-HFW11XX-V2" : "IP Camera" } } 00:05:36|[Manager] error currDevSerial:2K058B2GA100014 00:05:36|[Manager] error DevInformation'SerialID:2K058B2GA100014 00:05:36|[Manager] error currDevSerial:2K058B2GA100014 00:05:36|[Manager] error DevInformation'SerialID:2K058B2GA100014 00:05:36|[Manager] trace CConsole::registerCmd had been register!! 00:05:36|[Manager] error currDevSerial:2K058B2GA100014 00:05:36|[Manager] error DevInformation'SerialID:2K058B2GA100014 00:05:36|[Manager] error currDevSerial:2K058B2GA100014 00:05:36|[Manager] error DevInformation'SerialID:2K058B2GA100014 00:05:36|[Manager] trace CConsole::registerCmd had been register!! 00:05:36|[Manager] warn CMagicBox::getDeviceSubClass DeviceSubClass empty ! 00:05:36|[libpdi] WARN : Device has no crypt chip! 00:05:36|[libpdi] WARN : Device has no crypt chip! 00:05:36|[libpdi] 00:05:36|[Manager] info SetLanguage(Russian) load file:/mnt/custom/Russian.txt 00:05:36|[Manager] trace CLocales::SetLanguage()===============>>>/mnt/custom/Russian.txt 00:05:36|[libpdi] WARN : Device has no crypt chip! 00:05:36|[libpdi] WARN : Device has no crypt chip! 00:05:36|[libpdi] 00:05:37|[Manager] info ======================================================================== 00:05:37|[Manager] info CMagicBox::onSecondTimer current date and time are : 2000-01-01 00:05:37 00:05:37|[Manager] info ======================================================================== 00:05:37|info >>>>>>>>>>>>>>>>>MANAGER_end:42949397650 00:05:37|info >>>>>>>>>>>>>>>>>GDI_begin:42949397650 00:05:37|info CFontManager::config cfg is: { "BufSize" : 150, "FontDir" : "\/usr\/data\/Fonts", "Mode" : "BufMode" } 00:05:37|info >>>>>>>>>>>>>>>>>GDI_end:42949397650 00:05:37|info >>>>>>>>>>>>>>>>>DVRIP_INIT_begin:42949397650 00:05:37|trace setDefault DVRIP 00:05:37|trace AlarmServer setDefault 00:05:37|trace setDefault Qos config 00:05:37|info >>>>>>>>>>>>>>>>>DVRIP_INIT_end:42949397660 00:05:37|info >>>>>>>>>>>>>>>>>NETAPP_begin:42949397660 00:05:37|[libInfra] info [*] StreamApp 2.1.1.259618 Built in 2015/ 7/ 7 [*] 00:05:37|[libInfra] info [*] NetApp 2.0.0.259632 Built in 2015/ 7/ 7 [*] 00:05:37|[libNetApp] trace CNetApp getNetInterfaceList success, system support 1 NetInterface! 00:05:37|[libNetApp] info MAC IS 3c:ef:8c:ff:c6:32 00:05:37|[libpdi] GetLinkLocalAddress 00:05:37|[libpdi] eth0 MAC : 3c:ef:8c:ff:c6:32 00:05:37|[libpdi] fe80::3eef:8cff:feff:c632/64 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[libNetApp] error CDeviceUdp::getComponentInstance failed, Src/AutoSearchIP/MulticastSearchServer.cpp,36 00:05:37|trace IDevVideoIn channel = 1 00:05:37|[libInfra] error getComponentFactory iid=DevVideoOut could not been found,on line:123 ! 00:05:37|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:37|[Manager] info CUser::CUser(0x0x21a7d50)>>>>> 00:05:37|trace udn is:uuid:www.dahuatech.com.device_3_0-2K058B2GA100014 00:05:37|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:37|[NetProt-258820] error Src/ssdp/Ssdp.cpp,2301:IP_ADD_MEMBERSHIP failed, Address already in use Start Upnp Mini Server success! listen port: 49152 00:05:37|[libNetApp] trace CUPnPDevPoint config, param:{ "DeviceType" : "urn:schemas-upnp-org:device:3.0-2K058B2GA100014", "FriendlyName" : "IPC-HDW1220S-2K058B2GA100014", "Manufacturer" : "Dahua", "ManufacturerUrl" : "http:\/\/\/", "ModelDescription" : "Dahua IPC-HDW1220S", "ModelName" : "IPC-HDW1220S", "ModelNum" : "IPC-HDW1220S", "ModelUrl" : "http:\/\/\/", "PresentationUrl" : "http:\/\/192.168.0.220:80", "SerialNumber" : "3c:ef:8c:ff:c6:32", "Udn" : "uuid:www.dahuatech.com.device_3_0-2K058B2GA100014", "Upc" : "" } 00:05:37|[libNetApp] trace BroadcastSearchServer::config, param:{ "TCPPort" : 5000 } 00:05:37|[libNetApp] trace MulticastSearchServer::config, param:{ "TCPPort" : 5000 } 00:05:37|[libNetApp] trace CDeviceUdp::config, param:{ "TCPPort" : 5000 } 00:05:37|[libNetApp] trace NetApp start >>>>>>>>>>>>>>>>>>>>>>> 00:05:37|[libpdi] NET_disableRoute = 1 00:05:37|[libpdi] GetLinkLocalAddress 00:05:37|[libpdi] eth0 MAC : 3c:ef:8c:ff:c6:32 00:05:37|[libpdi] fe80::3eef:8cff:feff:c632/64 00:05:37|[libNetApp] trace UpdateConfigNetwork loading... 00:05:37|[libpdi] delete route: eth0, 192.168.0.0, 255.255.255.0 00:05:37|[libpdi] EthName:eth0 route delete ok! 00:05:37|[libpdi] delete route: eth0, default, 192.168.0.1 00:05:37|[libpdi] delete route success 00:05:37|[libpdi] add route: eth0, 192.168.0.0, 255.255.255.0 00:05:37|[libpdi] add route success 00:05:37|[libpdi] add route: eth0, default, 192.168.0.1 00:05:37|[libpdi] add route success 00:05:37|[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO00:05:37|[libpdi] set eth0 as defaultEth 00:05:37|[libNetApp] info Set default route to eth0:192.168.0.1 00:05:37|[libpdi] ERROR (save_Attr_file|1269): open failed for HOSTIP00:05:37|[libpdi] ERROR (save_Attr_file|1269): open failed for SUBMASK00:05:37|[libpdi] ERROR (save_Attr_file|1269): open failed for GATEWAYIP00:05:37|[libpdi] delete route: eth0, 192.168.0.0, 255.255.255.0 00:05:37|[libpdi] EthName:eth0 route delete ok! 00:05:37|[libpdi] EthName:eth0 route delete ok! 00:05:37|[libpdi] delete route: eth0, default, 192.168.0.1 00:05:37|[libpdi] delete route success 00:05:37|[libpdi] add route: eth0, 192.168.0.0, 255.255.255.0 00:05:37|[libpdi] add route success 00:05:37|[libpdi] add route: eth0, default, 192.168.0.1 00:05:37|[libpdi] add route success 00:05:37|[libpdi] ERROR (save_Attr_file|1269): open failed for PRIO00:05:37|[libpdi] set eth0 as defaultEth 00:05:37|[libNetApp] info Set default route to eth0:192.168.0.1 00:05:37|[libNetApp] trace CDhcpClientv4 Enter-------- 00:05:37|[libNetApp] trace CDhcpClientv4::initDhcpv4()----------------- 00:05:37|[libNetApp] trace CDhcpClientv6::CDhcpClientv6() Enter -----------. 00:05:37|[libNetApp] trace CDhcpClientv6::initDhcpv6()--------------. 00:05:37|[libInfra] error getComponentFactory iid=IPv6ConfigStateless could not been found,on line:123 ! 00:05:37|[libNetApp] error hth[initDhcpv6()][143]: m_ipv6Cli[0].stateless_cli == NULL. 00:05:37|[libNetApp] warn CDhcpClientv4::stopDhcp(), [eth0] is already in stop status. 00:05:37|[libNetApp] trace CDhcpClientv6::stopDhcp(eth0)----------- 00:05:37|[libNetApp] trace CNetApp::ARPPingSetIP() Start>>>>>>>>>> 00:05:37|[libNetApp] trace CArp::CArp()>>>>>>>>> 00:05:37|[libNetApp] trace CArp::Start()>>>>>>>>>>>>>>>>>> 00:05:37|[libNetApp] trace CNtpCli Enter-------- 00:05:37|[libNetApp] trace host[clock.isc.org], port[123] 00:05:37|[libNetApp] trace CSmtpCli::CSmtpClient()>>>>>>>>> 00:05:37|[libNetApp] trace CArp:: ThreadProc 00:05:37|[libNetApp] trace CSmtpCli::Start()>>>>>>>>>>>>>>>>>>>>> 00:05:37|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:37|[libNetApp] trace CUpnpCli::Start()>>>>>>>>> 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:37|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:37|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:38|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:38|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:38|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:38|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:38|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:38|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:38|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:38|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:38|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue! 00:05:38|[libNetApp] trace CDdnsCli::Start()>>>>>>>>>>>>>>>>>>>>> DHBonjour_Start >> watch_process pid = 428, Thread 1215304896 enter ! DHBonjour: Registered service[0x2279bd0] name '1K017C6PAX00344', type '_http._tcp.', port 80 00:05:38|[libNetApp] trace Src/Bonjour/DHBonjourRunner.cpp:115 bonjour run seccess 00:05:38|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:38|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:38|[libNetApp] trace MulticastSearchServer::start()>>>>>>>>>>>>>>>>>> 00:05:38|[libNetApp] trace CProviderManager::start()>>>>>>>>>>>>>>>>>> 00:05:38|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:38|[libNetApp] trace CProviderManager::start()>>>>>>>>>>>>>>>>>> 00:05:38|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:38|info >>>>>>>>>>>>>>>>>NETAPP_end:42949398350 00:05:38|[libStorage] trace CStorage config, param:{ "DefaultFileSystem" : { "General" : "FAT32", "HardDisk" : "FAT32", "SDCard" : "FAT32", "UsbDisk" : "FAT32", "UsbFlash" : "FAT32" }, "FileCountStat" : false, "MountDir" : "\/mnt", "Summary" : "File" } 00:05:38|[libStorage] trace ---->>CStorage::CStorage() 00:05:38|[libStorage] info storage m_configStorageGroup:[ { "Channels" : [ { "MaxPictures" : 0, "Path" : null } ], "FileHoldTime" : 0, "Memo" : "For Reading & Writing Files", "Name" : "ReadWrite", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" }, { "Channels" : [ { "MaxPictures" : 0, "Path" : null } ], "FileHoldTime" : 0, "Memo" : "For FTP Files", "Name" : "FTP", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" } ] 00:05:38|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:38|info >>>>>>>>>>>>>>>>>MEDIA_begin:42949398410 00:05:38|error CDisplay::start() setConfig failed! 00:05:38|[libpdi] getConfig fun[0]: 0x8518b 00:05:38|[libpdi] getConfig fun[1]: 0x0 00:05:38|[libpdi] getConfig fun[2]: 0x0 00:05:38|[libpdi] bndFlag: 0x3 00:05:38|[libpdi] ---------------------------------- 00:05:38|[libpdi] device videoInCaps: 00:05:38|[libpdi] exposure: 16 00:05:38|[libpdi] syncFocus: 0 00:05:38|[libpdi] iris: 1 00:05:38|[libpdi] irisAuto: 0 00:05:38|[libpdi] rotate90: 1 00:05:38|[libpdi] maxRotatableWidth: 1920 00:05:38|[libpdi] maxRotatableHeight: 1080 00:05:38|[libpdi] gammaMode: 1 00:05:38|[libpdi] gammaModeRange: 100 00:05:38|[libpdi] ---------------------------------- VideoInput Caps : m_caps.maxWidth[1920] m_caps.maxHeight[1080] m_caps.ladenBitrate[972000] m_caps.horizontalBinning[0] m_caps.verticalBinning[0] m_caps.downScaling[0] m_caps.upScaling[0] m_caps.exposure[16] m_caps.backlight[2] m_caps.dayNightColor[1] m_caps.mirror[1] m_caps.flip[1] m_caps.whiteBalance[3] m_caps.gain[1] m_caps.gainAuto[1] m_caps.coverCount[3] m_caps.coverType[1] m_caps.titleCount[2] m_caps.iris[1] m_caps.irisAuto[0] m_caps.infraRed[1] m_caps.setcolor[1] m_caps.formatCout[5] m_caps.rotate90[1] m_caps.signalForamtMask[0] m_caps.syncChipChannels[0] m_caps.chipID[0] m_caps.multiOptions[0] m_caps.snapshotExposure[0] m_caps.limitedAutoExposure[1] m_caps.customManualExposure[1] m_caps.externalSyncInput[0] m_caps.refrenceLevel[0] m_caps.flashAdjust[0] m_caps.minExposureTime[1] m_caps.maxExposureTime[300] m_caps.wideDynamicRange[1] m_caps.glareInhibition[1] m_caps.doubleExposure[0] m_caps.utc[0] m_caps.version[0] m_caps.meteringRegionCount[0] m_caps.exposureMode[31] m_caps.afPeak[0] m_caps.gammaModeRange[100] m_caps.gammaMode[1] m_caps.fishEye[0] m_caps.dayNightSwitchCtrl[1] 00:05:38|[libpdi] format P width:1920 height:1080 fps:25.000000 00:05:38|[libpdi] format P width:1280 height:1024 fps:25.000000 00:05:38|[libpdi] format P width:1280 height:960 fps:25.000000 00:05:38|[libpdi] format P width:1280 height:720 fps:25.000000 00:05:38|[libpdi] format P width:704 height:576 fps:25.000000 00:05:38|info CDevVideoIn::CDevVideoIn VideoIn getFormatCaps success, Standard[0],Height[1080],Width[1920],FPS[25.000000] 00:05:38|[libpdi] format N width:1920 height:1080 fps:30.000000 00:05:38|[libpdi] format N width:1280 height:1024 fps:30.000000 00:05:38|[libpdi] format N width:1280 height:960 fps:30.000000 00:05:38|[libpdi] format N width:1280 height:720 fps:30.000000 00:05:38|[libpdi] format N width:704 height:576 fps:30.000000 00:05:38|info CDevVideoIn::CDevVideoIn VideoIn getFormatCaps success, Standard[1],Height[1080],Width[1920],FPS[30.000000] 00:05:38|[libpdi] WARN (VIDEOINPUT_getFormatCaps|215): Parameter standard is Not PAL or NTSC! Parameter standard = 2, 2:stand for standard SECAM, 3:stand for standard Nr 00:05:38|warn CDevVideoIn::CDevVideoIn VideoIn getFormatCaps failed, [2] not support,[0,PAL][1,NTSC],[2,SECAM] 00:05:38|[Manager] warn CCommonConfigManager::getConfig VideoOut is Json::nullValue! 00:05:38|info CFontManager::initFontSolution fontDir : /usr/data/Fonts, solutionName : default-font, sm_workMode :BufMode, line : 590 00:05:38|info CRasterFontBuf::getHeadInfo get headinfo '/usr/data/Fonts/Font.bin' successfully!m_maxWidth:7 00:05:38|info CFontManager::initFontSolution fontDir : /usr/data/Fonts, solutionName : default-font, size : 1, line : 633 00:05:38|[libenc] BND_0(IENC_COM_00000001 --> 28191396) 00:05:38|[libencode] IENC_CMD_CREATE_STREAM[0] vencgroup[0],vencchn[0] 00:05:38| H264 CBR Rc Set! 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] WARN (ENCODE_hiSetRoi|1400): roi[x:0, y:0, w:32, h: 32] is out of img[w: 0, h:0] 00:05:38|[libencode] ENCODE_hiGetStreamBufInfo[0]! 00:05:38|stream[0] phyaddr=0x87300000 len=2088960 00:05:38|[OSA-APP] getStreamTsk Task pid=430 tid=455 00:05:38|stream[0] phyaddr=0x87300000 len=2088960 00:05:38|stream[0] viraddr=0x4a0e9000 00:05:38|[libenc] qrCodePacket only support snap stream! 00:05:38|info CDevVideoEnc::CDevVideoEnc>>>>maxMemSize: 7208960 Bytes 00:05:38|[libencode] IENC_CMD_GET_CAP 00:05:38|[libencode] get streamid[0] caps,titleCount=5,coverCount=4,snapFps=1.000000 00:05:38|info CDevVideoEnc stream [0] encoder Caps:[types 24,coverCount:4,titleCount:5,snapByOtherSize:0coverRemain:0,snapFps:1.000000,roiCount:4,h264ProfileMask:0xb,svcTLevel:0indepBymainCapture:0, bppTypeMask:0, dynamicTrack:0, maxRoiWidth:0, maxRoiHeight:0] 00:05:38|[libencode] IENC_CMD_GET_ENCODE_CFG 00:05:38|[libenc] get chipcaps :1209600 00:05:38|info CDevVideoEnc stream [0] encoder ChipCaps:[ladenBitrate:1209600] 00:05:38|trace getTitleCount : 5, stream:0 00:05:38|trace get title count: 5, cover count: 4, stream: 0 00:05:38|info CFontManager::sm_workMode == BufMode. 00:05:38|[libencode] IENC_CMD_CREATE_STREAM[1] vencgroup[1],vencchn[1] 00:05:39| H264 CBR Rc Set! 00:05:39|[libencode] ENCODE_hiGetStreamBufInfo[1]! 00:05:39|stream[1] phyaddr=0x87e00000 len=405504 00:05:39|[OSA-APP] getStreamTsk Task pid=430 tid=456 00:05:39|stream[1] phyaddr=0x87e00000 len=405504 00:05:39|stream[1] viraddr=0x45b67000 00:05:39|[libenc] qrCodePacket only support snap stream! 00:05:39|[libencode] IENC_CMD_GET_CAP 00:05:39|[libencode] get streamid[1] caps,titleCount=5,coverCount=4,snapFps=1.000000 00:05:39|info CDevVideoEnc stream [1] encoder Caps:[types 24,coverCount:4,titleCount:5,snapByOtherSize:0coverRemain:0,snapFps:1.000000,roiCount:4,h264ProfileMask:0xb,svcTLevel:0indepBymainCapture:0, bppTypeMask:0, dynamicTrack:0, maxRoiWidth:0, maxRoiHeight:0] 00:05:39|[libencode] IENC_CMD_GET_ENCODE_CFG 00:05:39|[libenc] get chipcaps :1209600 00:05:39|info CDevVideoEnc stream [1] encoder ChipCaps:[ladenBitrate:1209600] 00:05:39|trace getTitleCount : 5, stream:1 00:05:39|trace get title count: 5, cover count: 4, stream: 1 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 2 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 3 00:05:39|[libencode] IENC_CMD_CREATE_STREAM[4] vencgroup[3],vencchn[3] 00:05:39|[libencode] ENCODE_hiGetStreamBufInfo[3]! 00:05:39|stream[4] phyaddr=0x87b00000 len=2088960 00:05:39|[libencode] ENCODE_qrCodeCreateChn .....! 00:05:39|[OSA-APP] getStreamTsk Task pid=430 tid=457 00:05:39|stream[4] phyaddr=0x87b00000 len=2088960 00:05:39|stream[4] viraddr=0x4a661000 00:05:39|[libencode] IENC_CMD_GET_CAP 00:05:39|[libencode] get streamid[4] caps,titleCount=5,coverCount=0,snapFps=1.000000 00:05:39|info CDevVideoEnc stream [4] encoder Caps:[types 16,coverCount:0,titleCount:5,snapByOtherSize:0coverRemain:0,snapFps:1.000000,roiCount:0,h264ProfileMask:0xb,svcTLevel:0indepBymainCapture:0, bppTypeMask:0, dynamicTrack:0, maxRoiWidth:0, maxRoiHeight:0] 00:05:39|[libencode] IENC_CMD_GET_ENCODE_CFG 00:05:39|[libenc] get chipcaps :1209600 00:05:39|info CDevVideoEnc stream [4] encoder ChipCaps:[ladenBitrate:1209600] 00:05:39|trace getTitleCount : 5, stream:4 00:05:39|trace get title count: 5, cover count: 0, stream: 4 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 2 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 3 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 2 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 3 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 2 00:05:39|trace COSDObj::instance channel = 0, group = 0, stream = 3 00:05:39|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:39|trace ==channel:0=streamId:0=enable:1=type:3=gop:50=width:1920=height:1080=fps:25.000000=stand:0=wdrMode:0=eisEnable:0=denoise:0=vinFps:25.000000 =dewarp:0 00:05:39|trace ==channel:0=streamId:1=enable:1=type:3=gop:50=width:704=height:576=fps:25.000000=stand:0=wdrMode:0=eisEnable:0=denoise:0=vinFps:25.000000 =dewarp:0 00:05:39|trace videoEncGetChnCaps ret:-1 00:05:39|error CDevAudioEnc :: createAudioEncoder Failed !!! 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|error CDevAudioEnc :: createAudioEncoder Failed !!! 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|error CDevAudioEnc :: createAudioEncoder Failed !!! 00:05:39|error CDevAudioEnc :: createAudioEncoder Failed !!! 00:05:39|[libpdi] WARN : Get partion updateflag failed! 00:05:39|[libpdi] Not support backup partition !!! 00:05:39|[libpdi] WARN : Get partion updateflag failed! 00:05:39|[libpdi] Not support backup partition !!! DHBonjour: Callback: Registered 00:05:39|[libInfra] error getComponentFactory iid=Alarm could not been found,on line:123 ! 00:05:39|trace ==channel:0=streamId:0=enable:1=type:3=gop:50=width:1920=height:1080=fps:25.000000=stand:0=wdrMode:0=eisEnable:0=denoise:0=vinFps:25.000000 =dewarp:0 00:05:39|trace ==channel:0=streamId:1=enable:1=type:3=gop:50=width:704=height:576=fps:25.000000=stand:0=wdrMode:0=eisEnable:0=denoise:0=vinFps:25.000000 =dewarp:0 00:05:39|trace videoEncGetChnCaps ret:-1 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|info >>>getDynamicCaps 00:05:39|info CDevVideoEnc::getRoiCount>>>4 00:05:39|[Manager] warn CCommonConfigManager::getConfig VideoInputBufferPolicy is Json::nullValue! 00:05:39|info CVideoInSensorCfg::setVideoSensor() >>> Enter setVideoInSensor 00:05:39|warn CVideoInSensorCfg::setVideoSensor m_input(0x0x22b7fe8) or m_input->setSensorOptions error! 00:05:39|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:39|info CEncode::onConfigVideoInDefog enter! 00:05:39|error Src/Media/Encode.cpp:6153: profile mode=-1 is wrong!!! 00:05:39|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:39|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:39|trace CDevVideoIn::setFormat channel = 0, size = [1920, 1080], fps = 25.000000, window = [0, 0, 1920, 1080] 00:05:39|trace CDevVideoEnc::setFormat channel = 0, stream = 0, size = [1920, 1080], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 4096 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:39|[libencode] IENC_CMD_SET_FORMAT[0] 00:05:39|[libencode] VENC: streamId 0 bitrate 4096 bitrateControl 0 fps 25.000000 00:05:39|[libencode] gop 50 width 1920 height 1080 profile 3 type 3 00:05:39|[libencode] H264CBR width 1920, Height 1080, gop 50, ViFrmRate 25 00:05:39|[libencode] TargetFrmRate 25,BitRate 4096 ,FluctuateLevel 1 00:05:39|info Src/Media/DevVideoEnc.cpp:930 m_encoder->setFormat stream: 0, ret: 0, beReset:1 00:05:39|[libencode] IENC_CMD_SET_COVER[0] 00:05:39|[libencode] IENC_CMD_SET_COVER[0] 00:05:39|[libencode] IENC_CMD_SET_COVER[0] 00:05:39|[libencode] IENC_CMD_SET_COVER[0] 00:05:39|[libencode] IENC_CMD_SET_ROI 00:05:39|info CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed 00:05:39|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:0 00:05:39|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:39|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:39|trace CDevVideoEnc::setFormat channel = 0, stream = 1, size = [704, 576], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 1024 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:39|[libencode] IENC_CMD_SET_FORMAT[1] 00:05:39|[libencode] VENC: streamId 1 bitrate 1024 bitrateControl 0 fps 25.000000 00:05:39|[libencode] gop 50 width 704 height 576 profile 3 type 3 00:05:39|[libencode] H264CBR width 704, Height 576, gop 50, ViFrmRate 25 00:05:39|[libencode] TargetFrmRate 25,BitRate 1024 ,FluctuateLevel 1 00:05:39|info Src/Media/DevVideoEnc.cpp:930 m_encoder->setFormat stream: 1, ret: 0, beReset:1 00:05:39|[libencode] IENC_CMD_SET_COVER[1] 00:05:39|[libencode] IENC_CMD_SET_COVER[1] 00:05:39|[libencode] IENC_CMD_SET_COVER[1] 00:05:39|[libencode] IENC_CMD_SET_COVER[1] 00:05:39|[libencode] IENC_CMD_SET_ROI 00:05:39|info CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed 00:05:39|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 704, height: 576 m_stream:1 00:05:39|info CDevVideoEnc::parseConfig SVCTLayer:1 :0 00:05:39|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:39|trace CDevVideoEnc::setFormat channel = 0, stream = 4, size = [1920, 1080], fps = 1.000000, gop = 60, bitratectrl = 1, bitrate = 5120 kbps, quality = 5,pack = 0, type = 4, h264profile = 0, priority = 0 00:05:39|[libencode] IENC_CMD_SET_FORMAT[4] 00:05:39|[libencode] VENC: streamId 4 bitrate 5120 bitrateControl 1 fps 1.000000 00:05:39|[libencode] gop 60 width 1920 height 1080 profile 0 type 4 00:05:39|[libencode] MJPEG VBR width 1920, MaxBitRate 5120, ViFrmRate 25 fps, TargetFrmRate 0x1 fps 00:05:39|[libencode] MJPEG VBR MaxQp 75, MinQp 37, statTime 4 00:05:39|info Src/Media/DevVideoEnc.cpp:930 m_encoder->setFormat stream: 4, ret: 0, beReset:1 00:05:39|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:4 00:05:39|[Manager] warn CCommonConfigManager::getConfig Talkback is Json::nullValue! 00:05:39|[libencode] IENC_CMD_DTC_CREATE 00:05:40|[libencode] IENC_CMD_DTC_GET_CAP 00:05:40|[libencode] IENC_CMD_DTC_SET_MOTION 00:05:40|[libencode] windowNum:1 level:0 enable:0 pirMotion:0,newMode:1 00:05:40|[VUTL] windowNum = 1 level = 0 enable = 0 pirMotion = 0 00:05:40|[libencode] IENC_CMD_DTC_SET_BLIND 00:05:40|[SEN-DRV] black Recalc !!!enable:1 00:05:40|[libencode] IENC_CMD_DTC_SET_UNFOCUS 00:05:40|trace CDetect::CfgMotionDisable::m_cfgMotionEnable[channel:0]: 0 00:05:40|[libencode] IENC_CMD_SET_COVER[0] 00:05:40|[libencode] IENC_CMD_SET_COVER[1] 00:05:40|[libencode] IENC_CMD_SET_COVER[0] 00:05:40|[libencode] IENC_CMD_SET_COVER[1] 00:05:40|[libencode] IENC_CMD_SET_COVER[0] 00:05:40|[libencode] IENC_CMD_SET_COVER[1] 00:05:40|[libencode] IENC_CMD_SET_COVER[0] 00:05:40|[libencode] IENC_CMD_SET_COVER[1] 00:05:40|info CPacketManager: malloc total(16777216) pagesize(1024)blockCount (16384) ManagermentSize(327980) 00:05:40|info AddrRange(0x4aa5d400-0x4ba5d400) 00:05:40|[libpdi] NewOptions:backlight 0, bottom 5096, left 3096, right 5096, top 3096 wideDynamicRange 0, glareInhibition 0 00:05:40|[libpdi] CurOptions:backlight 255, bottom -1, left -1, right -1, top -1 wideDynamicRange 255, glareInhibition 255 00:05:40|[libpdi] flag 0, level 0,bottom 0, left 0, right 0, top 0 00:05:40|[libpdi] whiteBalance 1, gainBlue 50, gainRed 50 00:05:40|[libpdi] top 0, left 0, right 0, bottom 0 00:05:40|[libpdi] aeMode 0, level 0,expMin 0.000000, expMax 40.000000, gainMin 0, gainMax 70 manualGain 50 antiFlicker0 00:05:40|[libpdi] VIDEOINPUT_rotate90: pWinParam->rotate = 0 00:05:40|[libpdi] redLedLevel = 0 00:05:40|trace CDevVideoIn::setTemporaryOptions(): set setOptions() Day mode success. 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|warn Src/Media/DevVideoEnc.cpp:889, inFormat is the same, do nothing 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 0, size = [1920, 1080], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 4096 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:0 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 1, size = [704, 576], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 1024 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 704, height: 576 m_stream:1 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :0 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 4, size = [1920, 1080], fps = 1.000000, gop = 60, bitratectrl = 1, bitrate = 5120 kbps, quality = 5,pack = 0, type = 4, h264profile = 0, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:4 00:05:40|[AEW] APP:awbMode=1 00:05:40|[AEW] APP:awbRbCustom rCustom=50,bCustom=50 00:05:40|[AEW] APP:awbCustomLocalRect left=0,top=0,right=0,bottom=0 00:05:40|[AEW] APP:dayNightColor=1,c2bSensitivityLevel=2,waitingTime=6 00:05:40|[AEW] APP:irCutTransMode=0, irCutImgMode=0, b2cThr=0, c2bThr=0 00:05:40|[AEW] APP:receive param:aeMode=0,level=0,expMax=40.000000,expMin=0.000000,gainMax=70 00:05:40|[AEW] APP:gainMin=0,manualGain = 50,antiFlicker=0,aeSpeed=0,aeSenstive=0 00:05:40|[AEW] APP:evdefault=50,evdefaultLow=0,expMid=0.000000,smartIrEnable=0 00:05:40|[AEW] APP:receive params:width=1600,height=1200,startX=320,startY=10,rotate=0 00:05:40|[AEW] WARN (APP_msgProc|537): APP:Unsupported cmd_type:20 00:05:40|[AEW] set ae ctrl params is ok 00:05:40|[AEW] middle c2bThr is 20.000000 00:05:40|[libencode] IENC_CMD_AWEB_CFG 00:05:40|[AEW] set vd rotate is OK... 00:05:40|[libpdi] WARN (VIDEOINPUT_setPreviewOptions|1004): EEMode 50 00:05:40|[libpdi] pColorParam->gamLevel = 50 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|warn Src/Media/DevVideoEnc.cpp:889, inFormat is the same, do nothing 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 0, size = [1920, 1080], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 4096 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:0 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :1 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 1, size = [704, 576], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 1024 kbps, quality = 4,pack = 0, type = 3, h264profile = 3, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 704, height: 576 m_stream:1 00:05:40|info CDevVideoEnc::parseConfig SVCTLayer:1 :0 00:05:40|trace Src/Media/DevVideoIn.cpp:3531 profileMode is: 0, rotate state is: 0 00:05:40|trace CDevVideoEnc::setFormat channel = 0, stream = 4, size = [1920, 1080], fps = 1.000000, gop = 60, bitratectrl = 1, bitrate = 5120 kbps, quality = 5,pack = 0, type = 4, h264profile = 0, priority = 0 00:05:40|info Src/Media/DevVideoEnc.cpp:935 format is same, do nothing. 00:05:40|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:4 00:05:40|[AEW] APP:brightness=50,contrast=50,hue=50,saturation=50,sharpness=50 00:05:40|[AEW] APP:gamLevel=50,sharpSuppress=0,chomaSuppress=0,colortype=0 00:05:40|[AEW] APP:brightness=50,contrast=50,hue=50,saturation=50,sharpness=50 00:05:40|[AEW] APP:gamLevel=50,sharpSuppress=0,chomaSuppress=0,colortype=0 00:05:40|info devVideoEnc->setEncrypt! 00:05:40|warn onConfigEncrypt failed,at channelID 0 stream 0 00:05:40|info devVideoEnc->setAuth! 00:05:40|error onConfigAuth failed,at channelID 0 CDevVideoEnc::setWaterMark channel:0 set WaterMark: enable:1, data:DigitalCCTV, length:11, key:1, keyLen:1 00:05:40|info CDevVideoEnc::setWaterMark:m_encoder->setWaterMark call 1 ok, 0 failed! returne:1>>>>> 00:05:40|[libencode] IENC_CMD_SET_ROI 00:05:40|info CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed 00:05:40|[libencode] IENC_CMD_SET_ROI 00:05:40|info CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed 00:05:40|error CDevVideoIn::setTemporaryMeterMode VideoIn setMeteringMode no exist!!! 00:05:40|[Manager] warn CCommonConfigManager::getConfig AudioInput is Json::nullValue! 00:05:40|[Manager] warn CCommonConfigManager::getConfig AudioInputVolume is Json::nullValue! 00:05:40|[Manager] warn CCommonConfigManager::getConfig AudioInDenoise is Json::nullValue! 00:05:40|info CEncode::onConfigVideoInFaceAutoExposure enter! 00:05:40|info CDevVideoIn::setFaceAutoExposure enter! 00:05:40|error CDevVideoIn::setFaceAutoExposure not support 0x22b7fe8 (nil)!! 00:05:40|error CEncode::onConfigVideoInFaceAutoExposure call CDevVideoIn::setFaceAutoExposure return failed(0)!! 00:05:40|[AEW] curr brt level =50 00:05:40|[AEW] curr crt level =50 00:05:40|[AEW] curr sat level =50 00:05:40|[AEW] curr shp level =50 00:05:40|[AEW] set sharpen params ok 00:05:40|[AEW] set ktnf params ok 00:05:40|[AEW] gammalevel = 50, currGamma = 8, endGamma = 25 00:05:40|[AEW] Set gamma ok! 00:05:40|[libNetApp] error getaddrinfo:59, GetAddrInfo failed, ret:-1. 00:05:40|[libNetApp] trace CNtpCli::AdjustTimeWithNTP gethostbyname failed! 00:05:40|info Src/Media/RecordManager.cpp:236 Device suppert "dav" record format 00:05:40|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:40|trace VolumeDetect 0 0 0 00:05:40|warn CAudioDetect::start()>>>unSupported AudioDetect! 00:05:40|trace CDetect::start() Create Detect Thread>>>>>>>>>>>>>>>> 00:05:40|info >>>>>>>>>>>>>>>>>MEDIA_end:42949400950 00:05:40|info >>>>>>>>>>>>>>>>>RPCCOM_begin:42949400950 00:05:40|trace RPCS 2000-01-01 00:05:40 +++++++++++++++++++++++++++++++ 00:05:40|trace RPCS 2000-01-01 00:05:40 |build date: Jul 7 2015 | 00:05:40|trace RPCS 2000-01-01 00:05:40 |build time: 05:18:33 | 00:05:40|trace RPCS 2000-01-01 00:05:40 +++++++++++++++++++++++++++++++ 00:05:40|info >>>>>>>>>>>>>>>>>RPCCOM_end:42949400960 00:05:40|info >>>>>>>>>>>>>>>>>DVRIP_begin:42949400960 00:05:40|trace NetWorkService Run=======>>>>>>>>>>>>>>>>> 00:05:40|[Manager] warn CCommonConfigManager::getConfig NetAlarm is Json::nullValue! 00:05:40|trace CNetWorkService::QueryDeviceLine() 946685140 do_init: initialized context 0x243ecd0 00:05:40|trace @@@@@@@ enble 0 state 1 00:05:40|info >>>>>>>>>>>>g_maxBitrateLimit = [24576] 00:05:40|[Manager] error CEventManager::attach>>>>>>>ret:1 00:05:40|info >>>>>>>>>>>>>>>>>DVRIP_end:42949400990 00:05:40|info >>>>>>>>>>>>>>>>>STORAGE_begin:42949400990 00:05:40|[libStorage] info 00:05:40|[libInfra] info [*] Storage 1.0.1.269631 Built in 2015/ 7/ 7 [*] 00:05:40|[libStorage] info IsLocalStore:false ,RemoteStoreList:[ "FTP" ] 00:05:40|[libStorage] info CStorage::start start FTP 00:05:40|[libStorage] trace CFtpClient::Start General : { "LocalNo" : 8, "LockLoginEnable" : true, "LockLoginTimes" : 3, "LoginFailLockTime" : 1800, "MachineName" : "1K017C6PAX00344", "MaxOnlineTime" : 3600 } , line : 113 00:05:40|[libStorage] trace CFtpClient::OnConfigFtpServer() { "Address" : "", "CharacterEncoding" : "UTF-8", "Directory" : "share", "Enable" : false, "NO" : "doubleftp0", "Password" : "", "Port" : 21, "Protocol" : "FTP", "TimeOut" : 5000, "UserName" : "anonymity" } , line : 1081 00:05:41|trace stream 0 chn 0 fps 25 width 1920 height 1080 rate 4096 minDspRate:3584 00:05:41|trace stream 1 chn 0 fps 25 width 704 height 576 rate 1024 minDspRate:768 00:05:41|trace stream 2 chn 0 fps 25 width 352 height 288 rate 512 minDspRate:192 00:05:41|trace stream 3 chn 0 fps 25 width 352 height 288 rate 512 minDspRate:192 00:05:41|trace @@@@@@@@@@@have extra stream 00:05:41|[libStorage] warn CWorkDirectory::The WorkDirectory list is empty! 00:05:41|[libStorage] trace CFtpClient::CreateFtpAttr()----- 00:05:41|[libStorage] trace delWorkDir(IFtp *pIFtp, bool force)------ 00:05:41|info >>>>>>>>>>>>>>>>>STORAGE_end:42949401350 00:05:41|info >>>>>>>>>>>>>>>>>RECORDMANAGER_begin:42949401350 00:05:41|trace CRecordManager::Start()>>>>>>>>> 00:05:41|trace >>>>>>>>>>>IPV6 00:05:41|trace _________lvpin sock =70 ########## SSL_library_init #################### ########## OpenSSL_add_all_algorithms ########## ########## SSL_load_error_strings ############## 00:05:41|trace CDevVideoEnc::start----channel: 0,stream: 0 00:05:41|[libencode] IENC_CMD_ENABLE_STREAM[0] 00:05:41| H264 CBR Rc Set! 00:05:41|warn CDevVideoEnc::start(Proc proc):m_run to true, m_stream: 0 ########## OpenSSL1.0.1j Ready ################# 00:05:41|trace CRecord::setStreamType Type to 0 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 65 00:05:41|trace setFileFormat: same file format 00:05:41|trace CRecord::setStreamType Type to 0 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 65 00:05:41|trace setFileFormat: same file format 00:05:41|trace CRecord::setStreamType Type to 0 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 65 00:05:41|trace setFileFormat: same file format 00:05:41|trace CRecord::setStreamType Type to 0 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 65 00:05:41|trace setFileFormat: same file format 00:05:41|trace CRecord::setStreamType Type to 0 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 7 00:05:41|trace presecond set to: 65 00:05:41|trace setFileFormat: same file format 00:05:41|warn CDevVideoEnc::stop All proc detached, encoder will be stoped!!!!!!! 00:05:41|[libencode] IENC_CMD_DISABLE_STREAM[0] 00:05:41|warn m_run to false, m_stream: 0 00:05:41|trace ++++++++++++start in CRecord::checkStreamAndFileType() start++++++++++ 00:05:41|trace CDevVideoEnc::start----channel: 0,stream: 0 00:05:41|[libencode] IENC_CMD_ENABLE_STREAM[0] 00:05:41| H264 CBR Rc Set! 00:05:41|warn CDevVideoEnc::start(Proc proc):m_run to true, m_stream: 0 00:05:41|[libenc] WARN (IENC_pktRelease|498): no packet! 00:05:41|trace >>>>>>>>>>>IPV6 00:05:41|info >>>>>>>>>>>>>>>>>RECORDMANAGER_end:42949401600 00:05:41|info >>>>>>>>>>>>>>>>>SNAPMANAGER_begin:42949401600 00:05:41|trace CSnapManager::Start()>>>>>>>>> 00:05:41|trace _________lvpin sock =208 00:05:41|error @@@@@@@@@@@@@@@@ Port Reuse initialize success!! 00:05:41|info GetTotalChannels 1 00:05:41|trace mode:1, mask:2 00:05:41|trace mode:5, mask:2 00:05:41|trace mode:3, mask:2 00:05:41|trace mode:4, mask:2 00:05:41|trace mode:2, mask:2 00:05:41|info CDevVideoEnc::CDevVideoEnc IDevVideoAnalyse start m_stream = 0 00:05:41|[libInfra] error getComponentFactory iid=DevVideoAnalyse could not been found,on line:123 ! 00:05:41|info CDevVideoEnc::CDevVideoEnc IDevVideoAnalyse start m_stream = 1 00:05:41|[libInfra] error getComponentFactory iid=DevVideoAnalyse could not been found,on line:123 ! 00:05:41|info >>>>>>>>>>>>>>>>>SNAPMANAGER_end:42949401630 00:05:41|info >>>>>>>>>>>>>>>>>WEBSVR_begin:42949401630 00:05:41|[Manager] trace get Vendor: Dahua m_config:{ "Anonymous" : false, "HttpPort" : { "InnerPort" : 80, "OuterPort" : 8080 }, "HttpsPort" : { "InnerPort" : 443 }, "NAS_Protocol_Mask" : 100, "TCPPort" : 37777, "deviceType" : "IPC-HDW1220S", "eth0" : { "IPAddress" : "192.168.0.220", "IPv6Address" : "2001:250:3000:1::1:2" }, "is_385_intellent" : 1, "is_8M_Flash" : 1, "is_expertParams_intellent" : 0, "is_has_SnapFormatAs" : 0, "is_has_detectPic" : 1, "is_k6_DeviceType" : 0, "is_samrt1_intellent" : 0, "is_show_ExposureSpeed" : 1, "is_show_Gamma" : 1, "is_show_HTTPS" : 0, "is_show_LDAP" : 0, "is_show_LocationInfo" : 1, "is_show_MP4DownLoad" : 0, "is_show_OSDinfo" : 1, "is_show_PtzLimit" : 1, "is_show_PtzZoom" : 1, "is_show_QSEE" : 0, "is_show_RTMP" : 0, "is_show_Syslog" : 0, "is_show_T2UServer" : 0, "is_show_VPN_Certificate" : 0, "is_show_WatchNet" : 0, "is_show_WideView" : 1, "is_show_azimuthDisp" : 0, "is_show_duck" : 1, "is_show_eventManage" : 0, "is_show_faceDetect" : 1, "is_show_fastPosition" : 1, "is_show_fontSize" : 0, "is_show_mousecontrolptz" : 0, "is_show_pic_OSD" : 0, "is_show_platform" : 0, "is_show_roi" : 1, "is_show_rotate2" : 1, "is_show_startDeviceDiscover" : 0, "is_show_switchByAlarm" : 0, "is_show_upnpMode" : 1, "mac_plugins_version" : 3, "show_ATM_config" : 0, "show_Device_type" : 1, "show_NAS_config" : 0, "show_SNMP_config" : 1, "show_auto_register" : 1, "show_bonjour_config" : 1, "show_comm_config" : 0, "special_GOP_728WP" : 1, "use_mac_plugins" : 1, "vendor" : "Dahua", "videodetect_default_sensitive" : 58, "videodetect_default_threshold" : 4, "win_plugins_version" : 3 } 00:05:41|info Src/WebSvr.cpp:189 Start Http Server success! listen port: 80 ########## SSL_library_init #################### ########## OpenSSL_add_all_algorithms ########## ########## SSL_load_error_strings ############## ########## OpenSSL1.0.1j Ready ################# 00:05:41|info >>>>>>>>>>>>>>>>>WEBSVR_end:42949401730 00:05:41|info >>>>>>>>>>>>>>>>>ONVIF_begin:42949401730 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0082 | ONVIF is starting... 00:05:41|[Manager] trace get Vendor: Dahua 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifComm.cpp::initOnvifDefaultConifg@0118 | OldVersion is 20141008, NewVersion is 20141008 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/DeviceMgmt/OnvifDeviceMgmt.cpp::COnvifDeviceMgmt@0035 | COnvifDeviceMgmt::AttachConfigChange attach success 00:05:41|[Manager] error CEventManager::attach>>>>>>>ret:1 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/Event/OnvifEventCollector.cpp::COnvifEventCollector@0372 | OnvifEventProducer::AttachEventNotify attach success 00:05:41|trace CDetect::CfgMotionDisable::m_cfgMotionEnable[channel:0]: 0 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/PTZ/OnvifPTZController.cpp::init@0072 | PTZ isn't supported00:05:41|[Manager] warn CCommonConfigManager::getConfig PtzPreset is Json::nullValue! 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/PTZ/OnvifPTZController.cpp::COnvifPTZController@0046 | OnvifEventProducer::AttachConfigChange attach success 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/PTZ/OnvifPTZController.cpp::COnvifPTZController@0053 | Onvif support 80 preset! 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/VideoAnalytics/OnvifVideoAnalyticsManager.cpp::initConfig@0050 | COnvifVideoAnalyticsManager initConfig 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifComm.cpp::getAudioInChannel@0293 | AudioIn number:0 00:05:41|[AEW] APP:brightness=50,contrast=50,hue=50,saturation=50,sharpness=50 00:05:41|[AEW] APP:gamLevel=50,sharpSuppress=0,chomaSuppress=0,colortype=0 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/Service/Media/OnvifProfileManager.cpp::COnvifProfileManager@0148 | COnvifProfileManager::AttachConfigChange attach success 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifComm.cpp::getAudioInChannel@0293 | AudioIn number:0 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0084 | OnvifDefaultConifg is completed 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0086 | OnvifSnapshotServer is completed 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/CGIServer/CGIServerImpl.cpp::start@0058 | listening port 9990 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0088 | OnvifSOAPServer is completed 00:05:41|[AEW] curr brt level =50 00:05:41|[AEW] curr crt level =50 00:05:41|[AEW] curr sat level =50 00:05:41|[AEW] curr shp level =50 00:05:41|[AEW] set sharpen params ok 00:05:41|[AEW] gammalevel = 50, currGamma = 8, endGamma = 25 00:05:41|[AEW] Set gamma ok! 00:05:41|[Manager] trace get Country: china 00:05:41|[Manager] trace get Vendor: Dahua 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0090 | OnvifDeviceDiscovery is completed 2000-01-01 00:05:41 | ONVIF2.4.1 | Src/OnvifInterVideo.cpp::Run@0091 | ONVIF start OK 00:05:41|info >>>>>>>>>>>>>>>>>ONVIF_end:42949401910 00:05:41|info >>>>>>>>>>>>>>>>>INTERVIDEO_begin:42949401910 00:05:41|trace CInterVideo::Start!! 00:05:41|trace CInterVideo::IsExpiredVersion version type [R] 00:05:41|info >>>>>>>>>>>>>>>>>INTERVIDEO_end:42949401920 00:05:42|info >>>>>>>>>>>>>>>>>RTSP_begin:42949402260 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspServerRunner.cpp:723 CRtspServerRunner::set_sockbuf_config 00:05:42|trace IDevVideoIn channel = 1 00:05:42|trace IDevVideoIn channel = 1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|trace IDevVideoIn channel = 1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp 105 video_channel_num:1, audio_channel_num:0 max_channel_num:1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=0 start init 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:0 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:0> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=0, srctype=1, this=0x248bac0 00:05:42|info CDH3DevVideoEnc::start 00:05:42|trace CDevVideoEnc::start----channel: 0,stream: 0 00:05:42|info CDevVideoEnc::start(Proc proc):m_signal.Attach more proc num!!!ret =2 00:05:42|[libencode] IENC_CMD_FORCE_I_FRAME[0] 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=1 start init 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:1> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=1, srctype=1, this=0x248e2d0 00:05:42|info CDH3DevVideoEnc::start 00:05:42|trace CDevVideoEnc::start----channel: 0,stream: 1 00:05:42|[libencode] IENC_CMD_DISABLE_STREAM[1] 00:05:42|[libencode] IENC_CMD_ENABLE_STREAM[1] 00:05:42| H264 CBR Rc Set! 00:05:42|warn CDevVideoEnc::start(Proc proc):m_run to true, m_stream: 1 00:05:42|[libencode] IENC_CMD_FORCE_I_FRAME[1] 00:05:42|info CDH3DevVideoEnc::stop 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp 154 invalid channel_id:0, stream_id:2 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp 154 invalid channel_id:0, stream_id:3 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|info CDH3DevVideoEnc::stop 00:05:42|warn CDevVideoEnc::stop All proc detached, encoder will be stoped!!!!!!! 00:05:42|[libencode] IENC_CMD_DISABLE_STREAM[1] 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=4 start init 00:05:42|warn m_run to false, m_stream: 1 00:05:42|[libenc] WARN (IENC_pktRelease|498): no packet! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:4 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:4> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=4, srctype=1, this=0x248ed58 00:05:42|info CDH3DevVideoEnc::start 00:05:42|trace CDevVideoEnc::start----channel: 0,stream: 4 00:05:42|info CDevVideoEnc::SnapShotMode successful Mode[1] 00:05:42|[libencode] IENC_CMD_ENABLE_STREAM[4] 00:05:42|warn CDevVideoEnc::start(Proc proc):m_run to true, m_stream: 4 00:05:42|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : false, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20000, "StreamType" : "Main" } 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:727 stop multicast_type 2 channel = 0 stream=0 00:05:42|[StreamApp@259618] error Src/RtspServer/RtspLiveServer.cpp:748, stop_one_multicast_channel,cannot find this channel.channel=0, stream=0, multi-type=2 00:05:42|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : false, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20008, "StreamType" : "Extra1" } 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:727 stop multicast_type 2 channel = 0 stream=1 00:05:42|[StreamApp@259618] error Src/RtspServer/RtspLiveServer.cpp:748, stop_one_multicast_channel,cannot find this channel.channel=0, stream=1, multi-type=2 00:05:42|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40000, "StreamType" : "Main", "TTL" : 64 } 00:05:42|[StreamApp@259618] warn Src/StreamSource/StreamSource.cpp 371 <channel:1 subtype:4> snapstream do not check video info 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:695 start multicast_type 1 channel = 0 stream=0 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:754 start_one_multicast multicast_type 1 channel = 0 stream=0 00:05:42|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40008, "StreamType" : "Extra1", "TTL" : 64 } 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:695 start multicast_type 1 channel = 0 stream=1 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:754 start_one_multicast multicast_type 1 channel = 0 stream=1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=0&encrypt=1 start init 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=0&encrypt=1&unicast=false start init 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:0 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:0> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=0, srctype=10, this=0x2496aa8 00:05:42|info CDH3DevVideoEnc::start 00:05:42|trace CDevVideoEnc::start----channel: 0,stream: 0 00:05:42|info CDevVideoEnc::start(Proc proc):m_signal.Attach more proc num!!!ret =2 00:05:42|[libencode] IENC_CMD_FORCE_I_FRAME[0] 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=1&encrypt=1 start init 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=1&encrypt=1&unicast=false start init 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:1 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:1> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=1, srctype=10, this=0x2499a98 00:05:42|info CDH3DevVideoEnc::start 00:05:42|trace CDevVideoEnc::start----channel: 0,stream: 1 00:05:42|[libencode] IENC_CMD_DISABLE_STREAM[1] 00:05:42|[libencode] IENC_CMD_ENABLE_STREAM[1] 00:05:42| H264 CBR Rc Set! 00:05:42|warn CDevVideoEnc::start(Proc proc):m_run to true, m_stream: 1 00:05:42|[libencode] IENC_CMD_FORCE_I_FRAME[1] 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp 154 invalid channel_id:0, stream_id:2 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp 154 invalid channel_id:0, stream_id:3 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 523 live channel:cam/realmonitor?channel=1&subtype=4&encrypt=1 start init 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[libInfra] error getComponentFactory iid=DevAudioEnc could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:72 Get <IDevAudioEnc> Failed! channel:0 stream:4 00:05:42|[libInfra] error getComponentFactory iid=DevAudioIn could not been found,on line:123 ! 00:05:42|[StreamApp@259618] warn Src/StreamSource/EncodeStreamSource.cpp:428 <channel:1 subtype:4> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] 00:05:42|[StreamApp@259618] info Src/StreamSource/EncodeStreamSource.cpp 127 EncodeStreamSource Init! ch=1,stream=4, srctype=10, this=0x249db28 00:05:42|info CDH3DevVideoEnc::start 00:05:42|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : false, "IPType" : null, "IPV6" : null, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20000, "StreamType" : "Main", "TTL" : null } 00:05:43|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:727 stop multicast_type 2 channel = 0 stream=0 00:05:43|[StreamApp@259618] error Src/RtspServer/RtspLiveServer.cpp:748, stop_one_multicast_channel,cannot find this channel.channel=0, stream=0, multi-type=2 00:05:43|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : false, "IPType" : null, "IPV6" : null, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20008, "StreamType" : "Extra1", "TTL" : null } 00:05:43|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:727 stop multicast_type 2 channel = 0 stream=1 00:05:43|[StreamApp@259618] error Src/RtspServer/RtspLiveServer.cpp:748, stop_one_multicast_channel,cannot find this channel.channel=0, stream=1, multi-type=2 00:05:43|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40000, "StreamType" : "Main", "TTL" : 64 } 00:05:43|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:695 start multicast_type 1 channel = 0 stream=0 00:05:43|[StreamApp@259618] warn Src/RtspServer/RtspLiveServer.cpp:709 this multicast channel already starting, channel:0 stream:0 00:05:43|[StreamApp@259618] trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40008, "StreamType" : "Extra1", "TTL" : 64 } 00:05:43|[StreamApp@259618] trace Src/RtspServer/RtspLiveServer.cpp:695 start multicast_type 1 channel = 0 stream=1 00:05:43|[StreamApp@259618] warn Src/RtspServer/RtspLiveServer.cpp:709 this multicast channel already starting, channel:0 stream:1 00:05:43|info CDH3DevVideoEnc::stop 00:05:43|info CDH3DevVideoEnc::stop 00:05:43|info CDH3DevVideoEnc::stop 00:05:43|warn CDevVideoEnc::stop All proc detached, encoder will be stoped!!!!!!! 00:05:43|[libencode] IENC_CMD_DISABLE_STREAM[1] 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=0 end init 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=0&unicast=false end init 00:05:43|[libInfra] info [*] StreamSvr 2.1.1.245306 Built in 2015/ 7/ 7 [*] 00:05:43|warn m_run to false, m_stream: 1 00:05:43|[libenc] WARN (IENC_pktRelease|498): no packet! 00:05:43|trace stream_app->StartSvr() start sucess! 00:05:43|info >>>>>>>>>>>>>>>>>RTSP_end:42949403490 00:05:43|info >>>>>>>>>>>>>>>>>P2P_begin:42949403490 00:05:43|info >>>>>>>>>>>>>>>>>P2P_end:42949403490 00:05:43|info >>>>>>>>>>>>>>>>>SOME_begin:42949403500 00:05:43|[Manager] warn CCommonConfigManager::getConfig VideoAnalyseGlobal is Json::nullValue! 00:05:43|[libInfra] info Threads: 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=1 end init 00:05:43|[libInfra] info Name TID Prior State 00:05:43|[libInfra] info _______________________________________________________ 00:05:43|[libInfra] info Main 428 64 Normal 00:05:43|[libInfra] info COnvifDeviceDiscovery 470 64 Normal 00:05:43|[libInfra] info IV_Worker 469 64 Normal 00:05:43|[libInfra] info IV_Worker 466 64 Normal 00:05:43|[libInfra] info IV_Worker 468 64 Normal 00:05:43|[libInfra] info IV_Worker 467 64 Normal 00:05:43|[libInfra] info IV_CCIServer 465 64 Normal 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=1&unicast=false end init 00:05:43|[libInfra] info OnvifSnapshotServer 464 64 Normal 00:05:43|[libInfra] info COnvifEventService 463 64 Normal 00:05:43|[libInfra] info RecordStorage-Remote 462 7 Normal 00:05:43|[libInfra] info NetWorkService 461 64 Normal 00:05:43|[libInfra] info Video-Detect 460 3 Normal 00:05:43|[libInfra] info Encoder 458 5 Normal 00:05:43|[libInfra] info COsdAppend 459 3 Normal 00:05:43|[libInfra] info AndroidProvider 454 64 Normal 00:05:43|[libInfra] info AppleProvider 453 64 Normal 00:05:43|[libInfra] info BroadcastSearchServer 452 64 Normal 00:05:43|[libInfra] info SMTP 450 64 Normal 00:05:43|[libInfra] info [Pooled] 449 64 Normal 00:05:43|[libInfra] info [NetAppCheckNetState] 448 64 Normal 00:05:43|[libInfra] info Arp 447 8 Normal 00:05:43|[libInfra] info [Pooled] 446 64 Normal 00:05:43|[libInfra] info Console 445 1 Normal 00:05:43|[libInfra] info WatchDog 444 1 Normal 00:05:43|[libInfra] info [Pooled] 443 64 Normal 00:05:43|[libInfra] info TimerManager 442 1 Normal 00:05:43|[StreamApp@259618] warn Src/StreamSource/StreamSource.cpp 371 <channel:1 subtype:4> snapstream do not check video info 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=0&encrypt=1 end init 00:05:43|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=0&encrypt=1&unicast=false end init 00:05:43|[libInfra] info NetFramework 438 64 Normal 00:05:43|[libInfra] info NetFramework 441 64 Normal 00:05:43|[libInfra] info NetFramework 440 64 Normal 00:05:43|[libInfra] info NetFramework 439 64 Normal 00:05:43|[libInfra] info 00:05:43|[libInfra] trace CTimerManager::CTimerManager()>>>>>>>>> 00:05:43|[libInfra] info Timers: ( 42949403950 Milli-Seconds Elapsed ) 00:05:43|[libInfra] info Name NextTime RunningTime Period Used/Timeout State 00:05:43|[libInfra] info ____________________________________________________________________________ 00:05:43|[libInfra] info EventManager 42949404370 3 1000 0/ 60000 Idle 00:05:43|[libInfra] info CMOS Timer 42949404370 5 1000 0/ 60000 Idle 00:05:43|[libInfra] info SectionTimer 42949404610 18 1000 0/ 60000 Idle 00:05:43|[libInfra] info OnvifEvetTimer 42949404750 0 1000 0/ 0 Idle 00:05:43|[libInfra] info EncodeMonitor 42949404760 0 1000 0/ 60000 Idle 00:05:43|[libInfra] info previewOptionsTimer 42949404760 1 1000 0/ 60000 Idle 00:05:43|[libInfra] info VideoColor 42949404780 2 1000 0/ 60000 Idle 00:05:43|[libInfra] info cfgMoDetect-0 42949404790 0 0 0/ 60000 Idle 00:05:43|[libInfra] info NetAppCheckNetState 42949405880 81 2000 0/ 60000 Idle 00:05:43|[libInfra] info BitrateLimitCheck 42949405970 0 5000 0/ 60000 Idle 00:05:43|[libInfra] info ConfigSaveTimer 42949407180 0 10000 0/180000 Idle 00:05:43|[libInfra] info DDNSUpdateTimer 42949408325 2 5000 0/ 0 Idle 00:05:43|[libInfra] info AutoMaintain 42949411370 0 10000 0/ 60000 Idle 00:05:43|[libInfra] info ConnState 42949430970 0 30000 0/ 60000 Idle 00:05:43|[libInfra] info LogSyncTimer 42949456370 0 10000 0/ 60000 Idle 00:05:43|[libInfra] info appstartcheck 42949457640 0 180000 0/ 60000 Idle 00:05:43|[libInfra] info AndroidResender 42949458340 0 60000 0/ 0 Idle 00:05:43|[libInfra] info AppleResender 42949458340 0 60000 0/ 0 Idle 00:05:43|[libInfra] info SendFreeArp 42949697900 0 300000 0/ 60000 Idle 00:05:43|[libInfra] info ntp 42949997880 2998 600000 0/ 60000 Idle 00:05:43|[libInfra] info PushCfgChecker 42949998340 0 600000 0/ 60000 Idle 00:05:43|[libInfra] info 00:05:43|info The application program starts ok,and the appstartcheck timer is going to stop! 00:05:43|info >>>>>>>>>>>>>>>>>SOME_end:42949403960 00:05:43|info >>>>>>>>>>>>>>>>>RUNTIME_end:42949403980 00:05:43|info [ DVRIP] run time: 30############# 00:05:43|info [DVRIP_INIT] run time: 10############# 00:05:43|info [ GDI] run time: 0############# 00:05:44|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=4 end init 00:05:44|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=1&encrypt=1 end init 00:05:44|info [ INFRA] run time: 60############# 00:05:44|info [ INITION] run time: 8010############# 00:05:44|info [INTERVIDEO] run time: 10############# 00:05:44|info [ MANAGER] run time: 1980############# 00:05:44|info [ MEDIA] run time: 2540############# 00:05:44|info [ NETAPP] run time: 690############# 00:05:44|info [ ONVIF] run time: 180############# 00:05:44|info [ P2P] run time: 0############# 00:05:44|info [RECORDMANAGER] run time: 250############# 00:05:44|info [ RPCCOM] run time: 10############# 00:05:44|info [ RTSP] run time: 1230############# 00:05:44|info [ RUNTIME] run time:16410############# 00:05:44|info [SNAPMANAGER] run time: 30############# 00:05:44|info [ SOME] run time: 460############# 00:05:44|info [ STORAGE] run time: 360############# 00:05:44|info [ WEBSVR] run time: 100############# 00:05:44|info CDH3DevVideoEnc::stop 00:05:44|info CDevVideoEnc::SnapShotMode successful Mode[0] 00:05:44|warn CDevVideoEnc::stop All proc detached, encoder will be stoped!!!!!!! 00:05:44|[libencode] IENC_CMD_DISABLE_STREAM[4] 00:05:44|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=1&encrypt=1&unicast=false end init 00:05:44|warn m_run to false, m_stream: 4 00:05:44|[StreamApp@259618] info Src/RtspServer/RtspLiveServer.cpp 264 live channel:cam/realmonitor?channel=1&subtype=4&encrypt=1 end init 00:05:44|trace CDetect::OnCfgMotionEnable::m_cfgMotionEnable[channel:0]: 1 00:05:50|[SEN-DRV] black Recalc !!! 00:06:00|[SEN-DRV] black Recalc !!! 00:06:10|[SEN-DRV] black Recalc !!! |
fobos [ 24 авг 2022, 17:11 ] | |
Заголовок сообщения: | Re: [Ищу дамп] Dahua IPC-HFW1220SP (?) |
сорри за назойливость..., а printenv? |
mazahaka011 [ 26 авг 2022, 23:30 ] | |
Блин, вот это забыл скопировать. В воскресенье пришлю, извиняюсь) |
mazahaka011 [ 29 авг 2022, 14:36 ] | |
Приветствую
лог
> printenv
bootdelay=1 baudrate=115200 ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 appauto=1 loglevel=4 BSN=1J00B91PAP01217 HWID=IPC-HFW1220RM:01:02:02:36:13:00:01:00:00:00:00:1B8:00:00:00:00:00:00:00:00: 80 icrtype=1 devalias=IPC-HDW1220S da=tftp 0x82000000 dhboot.bin.img;flwrite;tftp 0x82000000 dhboot-min.bin.img;flw rite; dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite; dk=tftp 0x82000000 kernel.img;flwrite; du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite; dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img;flwrite; tk=tftp 0x82000000 uImage;bootm; bootcmd=sf read 0x82000000 0x90000 0x160000;bootm 0x82000000; bootargs=mem=77M console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=squashfs filesize=162040 fileaddr=82000000 ID=2K058B2GA100014 ethaddr=3C:EF:8C:FF:C6:32 dh_keyboard=1 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn2464 (Jul 07 2015 - 06:01:47) Environment size: 1094/131068 bytes |
