Текущее время: 28 апр 2024, 02:26
Marozoff
Заголовок сообщения: Re: дамп для камеры dahua IPC-HFW1431S1P-A-S4 в поиске Добавлено: 15 фев 2024, 23:11 |
Сообщения: 5 Откуда: регион33
printenv
> printenv bootcmd=kload 0x22000000; bootm 0x22000000 bootdelay=1 baudrate=115200 ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 da=tftp 0x22000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x22000000 romfs-x.squashfs.img; flwrite dk=tftp 0x22000000 kernel.img; flwrite du=tftp 0x22000000 user-x.squashfs.img; flwrite dw=tftp 0x22000000 web-x.squashfs.img; flwrite dp=tftp 0x22000000 partition-x.cramfs.img;flwrite dc=tftp 0x22000000 custom-x.squashfs.img; flwrite up=tftp 0x22000000 update.img; flwrite tk=tftp 0x22000000 uImage; bootm loglevel=4 pd=tftp 0x22000000 pd-x.squashfs.img; flwrite ethact=sstar_emac BSN=хххххххххххххххххх HWID=IPC-HFW1431S1P-A-S4:01:02:05:BA:49:00:01:10:01:00:00:4B0:00:00:00:00:00:00:00:00:80 hwidEx=00:03:00:00:00:00:00:00:00:00:00:00:00:00:00:00 devalias=DH-IPC-HFW1431S1-A-S4 bootargs=mem=58240K root=/dev/mtdblock6 rootfstype=squashfs ro init=/linuxrc LX_MEM=0x7fe0000 mma_heap=mma_heap_name0,miu=0,sz=0x4700000 filesize=D86738 fileaddr=22000000 autolip=192.168.1.251 mp_autotest=0 ID=8FMG19DPAGM9026 ethaddr=хххххххххххххххххх dh_keyboard=0 appauto=0 stdin=serial stdout=serial stderr=serial ver=U-Boot 2010.06-svn10443 (Nov 09 2022 - 20:29:50)
help
> help ? - alias for 'help' boot - boot default, i.e., run 'bootcmd' bootm - boot application image from memory ebist - PHY loopback test edump - EMAC Register settings dump eloopback- Long loopback test epd - emac power down erasepart- erasepart
estart - EMAC start ewavetest- EMAC wave test flwrite - flwrite - write data into FLASH memory
help - print command description/usage kload - kload - load uImage file from parttion
loadspi - load data from SPI macaddr - setup EMAC MAC addr memsize - memsize - set mem size
otp_printf- print TracingCode environment variables partition- print partition information ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables rarpboot- boot image via network using RARP/TFTP protocol reset - Perform RESET of the CPU run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables tftpboot- tftpboot- boot image via network using TFTP protocol
Последний раз редактировалось Marozoff 16 фев 2024, 01:14, всего редактировалось 1 раз.
Marozoff
Заголовок сообщения: Re: дамп для камеры dahua IPC-HFW1431S1P-A-S4 в поиске Добавлено: 16 фев 2024, 00:20 |
вывод команды partition
> partition name cs offset size flag fs_flags fs_type mini-Boot 0 0x0000000000000000 0x0000000000040000 0x00000000 0x00000000 0x00000000 U-Boot 0 0x0000000000080000 0x0000000000040000 0x00000000 0x00000000 0x00000000 hwid 0 0x00000000000c0000 0x0000000000010000 0x00000000 0x00000000 0x00000000 partition 0 0x00000000000d0000 0x0000000000010000 0x00000000 0x00000001 0x00000001 Kernel 0 0x00000000000e0000 0x00000000001a0000 0x00000000 0x00000000 0x00000000 web 0 0x0000000000280000 0x00000000004d0000 0x00000000 0x00000001 0x00000002 romfs 0 0x0000000000750000 0x00000000007a0000 0x00000000 0x00000001 0x00000002 config 0 0x0000000000ef0000 0x0000000000060000 0x00000000 0x00000003 0x00000004 backup 0 0x0000000000f50000 0x0000000000050000 0x00000000 0x00000003 0x00000004 dgs 0 0x0000000000fa0000 0x0000000000050000 0x00000000 0x00000003 0x00000000 updateflag 0 0x0000000000ff0000 0x0000000000010000 0x00000000 0x00000003 0x00000000 mini-Boot mountcmd: U-Boot mountcmd: hwid mountcmd: partition mountcmd: Kernel mountcmd: web mountcmd:mount -t squashfs -r /dev/mtdblock5 /mnt/web/ romfs mountcmd: config mountcmd:mnt_jffs2 /dev/mtdblock7 /mnt/mtd jffs2 backup mountcmd:mnt_jffs2 /dev/mtdblock8 /mnt/backup jffs2 dgs mountcmd: updateflag mountcmd: >
fobos писал(а): если есть желание поэкспериментировать, то вот заводской дамп... можете вложенные файлы пульнуть на почту из профиля? - у меня, как у новичка нет прав даже свои вложения смотреть/скачивать... fobos писал(а): а для сброса в help есть команда erasepart уже после того, как сюда запостил вывод help и ещё раз посмотрел его подумал, что это оно!) но нужножешь её с какимито аргументами запускать - подскажите с какими? зы: программатором разживусь в лучшем случае в субботу...
Последний раз редактировалось Marozoff 16 фев 2024, 01:15, всего редактировалось 1 раз.
Marozoff
Заголовок сообщения: Re: дамп для камеры dahua IPC-HFW1431S1P-A-S4 в поиске Добавлено: 16 фев 2024, 11:50 |
fobos писал(а): попробуйте через тфтп и уарт залить этот img командой run up а кроме этого img что должно быть с ним в одной папке - все распакованные файлы прошивки или только check.img (без него выдаёт ошибку и ничего не происходит) - я его (ваш файл) скопировал в папку с распакованной прошивкой (с которой до этого вокруг камеры прыгал) и процесс пошёл, после сделал команды сброса... результат вам известен. но сброс таки произошёл - до прошивки с вашим файлом камера пинговалась по адресу домашней подсети, настроенному мной, а после прошивки и сброса адрес стал дефолтный ...1.108 повторный сброс командами и сброс замыканием контактов на плате (который вродекак таки заработал) результатов тоже не принёс...
