Текущее время: 27 апр 2024, 18:22
BMA
Заголовок сообщения: ZTE Blade L5 plus тест поинт . Добавлено: 27 мар 2022, 11:50 |
Зарегистрирован: 08 окт 2013, 00:56 Наличности на руках: 638.70
Сообщения: 1188 Откуда: Kohma
ZTE Blade L5 plus Кирпич . В диспетчере появляется и пропадает . Батарея заряжена . В терминале сыплет этим по кругу .
[WRAP] ERROR,line=657 _pwrTest of MT6350] pass,index=1 rdata=5AA5--- of MT6350] pass,index=2 rdata=5AA5 [Wpwrap_init_sistrobe [Read Test of MT63-AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=4 r
[PLF]Keep USB Mode [WRAP] pwrap_init_preloader [WRAP] pwrap_init [WRAP] ERROR,line=657 _pwrap_init_sistrobe [T rdata=5AA5 =is of MT6350] pass,index=2 rdata=5AA56350] pass,index=1 rdata=5AA5 [WRApwrap_init_sistrobe [Read Test of MT6350]AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=4 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=5 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=6 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=7 rdata=5AA5 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=8 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=9 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=10 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=11 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=12 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=13 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=14 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=15 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=16 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=17 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=18 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=19 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=20 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=21 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=22 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=23 rdata=6A97 [WRAP] _pwrap_init_reg_clock [PMIC_WRAP]wrap_init pass,the return value=0. [pmic6350_init] Preloader Start.................. [pmic6350_init] PMIC CHIP Code = 8272 [pmic_init] turn off usbdl wo battery just_rst = 0 pl pmic powerkey Release [pmic6350_init] powerKey = 0 [pmic6350_init] is USB in = 45059 [AUXADC] u4channel[7]=16129. [AUXADC] adc_result_temp=16129, adc_result=3543, r_val_temp=4. [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, start charging... [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, stop charging... [pmic6350_init] Done................... AP_PLL_CON1= 0x3C3C23C0 AP_PLL_CON2= 0x4 CLKSQ_STB_CON0= 0x25002100 PLL_ISO_CON0= 0x202020 ARMPLL_CON0= 0x11 ARMPLL_CON1= 0x8009A000 ARMPLL_PWR_CON0= 0x5 MPLL_CON0= 0x8000011 MPLL_CON1= 0x800E7000 MPLL_PWR_CON0= 0x5 UPLL_CON0= 0x38000001 UPLL_CON1= 0x1000060 UPLL_PWR_CON0= 0x5DISP_CG_CON0= 0xFFFFFFFC, DISP_CG_CON1= 0x0, [PLF]Init I2C: OK(0) [PLF]Init PWRAP: OK(0) [PLF]Init PMIC: OK(0) [PLF]chip_ver[0]
[BLDR] Build Time: 20160729-161919 [DDR Reserve] ddr reserve mode not be enabled yet RGU rgu_release_rg_dramc_conf_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_sref:MTK_WDT_DEBUG_CTL(590200F1) DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 ==== Dump RGU Reg ======== RGU MODE: 4D RGU LENGTH: FFE0 RGU STA: 0 RGU INTERVAL: FFF RGU SWSYSRST: 8000 ==== Dump RGU Reg End ==== RGU: g_rgu_satus:0 mtk_wdt_mode_config mode value=10, tmp:22000010 PL P ON WDT does not trigger reboot mtk_wdt_mode_config mode value=5D, tmp:2200005D RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3) Enter mtk_kpd_gpio_set! after set KP enable: KP_SEL = 0x1C70 ! [WDT][0x28A]=0x0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] RTC 32K mode setting wrong. Enter first boot/recovery. [RTC] bbpu = 0x1, con = 0x84A7, osc32con = 0x3, sec = 0x0, yea = 0x2 rtc_first_boot_init [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=3966 [RTC] EOSC_Cali: TOP_CKCON1=0xC0 [RTC] get_frequency_meter: input=0xF, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x17, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1B, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1D, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] get_frequency_meter: input=0x1F, ouput=0 [RTC] EOSC cali val = 0x1F [RTC] EOSC cali val = 0xFC9F [RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x80, spar1 = 0x800 [RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1 [RTC] bbpu = 0x1, con = 0x4A6, cali = 0x0 [WDT2][0x28A]=0x0 pl pmic powerkey Release [PLF]USB/charger boot [RTC] rtc_bbpu_power_on done [msdc_init]: msdc0 Host controller intialization start [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [SD0] Pins mode(1), none(0), down(1), up(2), keep(3) [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [info][msdc_config_clksrc] input clock is 208000kHz [SD0] Bus Width: 1 [info][msdc_config_clksrc] input clock is 208000kHz [SD0] SET_CLK(260kHz): SCLK(260kHz) MODE(0) DDR(0) DIV(200) DS(0) RS(0) [msdc_init]: msdc0 Host controller intialization done --------------------------------------------------------index=0 rdata=5AA5 [WRAP] ERROR,line=6be [Read Test of MT6350] pass,index=1 r-RROR,line=657 _pwrap_init_sistrobe [Reass,index=2 rdata=5AA5 [WRAP] ERROR,- MT6350] pass,index=3 rdata=5AA5 [WRAe: 0
[USBD] USB cable/ No Cable inserted!
[PLF]Keep USB Mode [WRAP] pwrap_init_preloader [WRAP] pwrap_init [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read eindex=0 rdata=5AA5 [WRAP] ERROR,line=657be [Read Test of MT6350] pass,index=1 rdatRROR,line=657 _pwrap_init_sistrobe [Readass,index=2 rdata=5AA5 [WRAP] ERROR,li_ MT6350] pass,index=3 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=4 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=5 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=6 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=7 rdata=5AA5 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=8 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=9 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=10 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=11 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=12 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=13 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=14 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=15 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=16 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=17 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=18 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=19 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=20 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=21 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=22 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=23 rdata=6A97 [WRAP] _pwrap_init_reg_clock [PMIC_WRAP]wrap_init pass,the return value=0. [pmic6350_init] Preloader Start.................. [pmic6350_init] PMIC CHIP Code = 8272 [pmic_init] turn off usbdl wo battery just_rst = 0 pl pmic powerkey Release [pmic6350_init] powerKey = 0 [pmic6350_init] is USB in = 45059 [AUXADC] u4channel[7]=16129. [AUXADC] adc_result_temp=16129, adc_result=3543, r_val_temp=4. [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, start charging... [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, stop charging... [pmic6350_init] Done................... AP_PLL_CON1= 0x3C3C23C0 AP_PLL_CON2= 0x4 CLKSQ_STB_CON0= 0x25002100 PLL_ISO_CON0= 0x202020 ARMPLL_CON0= 0x11 ARMPLL_CON1= 0x8009A000 ARMPLL_PWR_CON0= 0x5 MPLL_CON0= 0x8000011 MPLL_CON1= 0x800E7000 MPLL_PWR_CON0= 0x5 UPLL_CON0= 0x38000001 UPLL_CON1= 0x1000060 UPLL_PWR_CON0= 0x5DISP_CG_CON0= 0xFFFFFFFC, DISP_CG_CON1= 0x0, [PLF]Init I2C: OK(0) [PLF]Init PWRAP: OK(0) [PLF]Init PMIC: OK(0) [PLF]chip_ver[0]
[BLDR] Build Time: 20160729-161919 [DDR Reserve] ddr reserve mode not be enabled yet RGU rgu_release_rg_dramc_conf_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_sref:MTK_WDT_DEBUG_CTL(590200F1) DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 ==== Dump RGU Reg ======== RGU MODE: 4D RGU LENGTH: FFE0 RGU STA: 0 RGU INTERVAL: FFF RGU SWSYSRST: 8000 ==== Dump RGU Reg End ==== RGU: g_rgu_satus:0 mtk_wdt_mode_config mode value=10, tmp:22000010 PL P ON WDT does not trigger reboot mtk_wdt_mode_config mode value=5D, tmp:2200005D RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3) Enter mtk_kpd_gpio_set! after set KP enable: KP_SEL = 0x1C70 ! [WDT][0x28A]=0x0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=5878 [RTC] bbpu = 0x1, con = 0x4A7, osc32con = 0xFC3F, sec = 0x0, yea = 0x2 [RTC] powerkey1 = 0xA357, powerkey2 = 0x67D2 Writeif_unlock [RTC] EOSC_Cali: TOP_CKCON1=0xC0 [RTC] get_frequency_meter: input=0xF, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x17, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1B, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1D, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] get_frequency_meter: input=0x1F, ouput=0 [RTC] EOSC cali val = 0xFC9F [RTC] RTC_SPAR0=0x0 [RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x0, spar1 = 0x800 [RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1 [RTC] bbpu = 0x1, con = 0x84A6, cali = 0x0 [WDT2][0x28A]=0x0 pl pmic powerkey Release [PLF]USB/charger boot [RTC] rtc_bbpu_power_on done [msdc_init]: msdc0 Host controller intialization start [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [SD0] Pins mode(1), none(0), down(1), up(2), keep(3) [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [info][msdc_config_clksrc] input clock is 208000kHz [SD0] Bus Width: 1 [info][msdc_config_clksrc] input clock is 208000kHz [SD0] SET_CLK(260kHz): SCLK(260kHz) MODE(0) DDR(0) DIV(200) DS(0) RS(0) [msdc_init]: msdc0 Host controller intialization done ----------------------------------------------ead Test of MT6350] pass,index=0 rdata=5---------e=657 _pwrap_init_sistrobe [Read Test of ---] ERROR,line=657 _pwrap_init_sistrobe [ass,index=3 rdata=5AA5 [WRAP] ERROR,-_sistrobe [Read Test of MT6350] pass,ite: 0
[PLF]Keep USB Mode [WRAP] pwrap_init_preloader [WRAP] pwrap_init e=657 _pwrap_init_sistrobe [Read Test of MT6 r] ERROR,line=657 _pwrap_init_sistrobe [Reass,index=3 rdata=5AA5 [WRAP] ERROR,lin_sistrobe [Read Test of MT6350] pass,index=4 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=5 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=6 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=7 rdata=5AA5 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=8 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=9 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=10 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=11 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=12 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=13 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=14 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=15 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=16 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=17 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=18 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=19 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=20 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=21 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=22 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=23 rdata=6A97 [WRAP] _pwrap_init_reg_clock [PMIC_WRAP]wrap_init pass,the return value=0. [pmic6350_init] Preloader Start.................. [pmic6350_init] PMIC CHIP Code = 8272 [pmic_init] turn off usbdl wo battery just_rst = 0 pl pmic powerkey Release [pmic6350_init] powerKey = 0 [pmic6350_init] is USB in = 45059 [AUXADC] u4channel[7]=16129. [AUXADC] adc_result_temp=16129, adc_result=3543, r_val_temp=4. [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, start charging... [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, stop charging... [pmic6350_init] Done................... AP_PLL_CON1= 0x3C3C23C0 AP_PLL_CON2= 0x4 CLKSQ_STB_CON0= 0x25002100 PLL_ISO_CON0= 0x202020 ARMPLL_CON0= 0x11 ARMPLL_CON1= 0x8009A000 ARMPLL_PWR_CON0= 0x5 MPLL_CON0= 0x8000011 MPLL_CON1= 0x800E7000 MPLL_PWR_CON0= 0x5 UPLL_CON0= 0x38000001 UPLL_CON1= 0x1000060 UPLL_PWR_CON0= 0x5DISP_CG_CON0= 0xFFFFFFFC, DISP_CG_CON1= 0x0, [PLF]Init I2C: OK(0) [PLF]Init PWRAP: OK(0) [PLF]Init PMIC: OK(0) [PLF]chip_ver[0]
[BLDR] Build Time: 20160729-161919 [DDR Reserve] ddr reserve mode not be enabled yet RGU rgu_release_rg_dramc_conf_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_sref:MTK_WDT_DEBUG_CTL(590200F1) DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 ==== Dump RGU Reg ======== RGU MODE: 4D RGU LENGTH: FFE0 RGU STA: 0 RGU INTERVAL: FFF RGU SWSYSRST: 8000 ==== Dump RGU Reg End ==== RGU: g_rgu_satus:0 mtk_wdt_mode_config mode value=10, tmp:22000010 PL P ON WDT does not trigger reboot mtk_wdt_mode_config mode value=5D, tmp:2200005D RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3) Enter mtk_kpd_gpio_set! after set KP enable: KP_SEL = 0x1C70 ! [WDT][0x28A]=0x0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=5877 [RTC] bbpu = 0x1, con = 0x84A7, osc32con = 0xFCBF, sec = 0x0, yea = 0x2 rtc_first_boot_init [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=3968 [RTC] EOSC_Cali: TOP_CKCON1=0xC0 [RTC] get_frequency_meter: input=0xF, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x17, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1B, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1D, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] get_frequency_meter: input=0x1F, ouput=0 [RTC] EOSC cali val = 0x1F [RTC] EOSC cali val = 0xFC9F [RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x80, spar1 = 0x800 [RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1 [RTC] bbpu = 0x1, con = 0x4A6, cali = 0x0 [WDT2][0x28A]=0x0 pl pmic powerkey Release [PLF]USB/charger boot [RTC] rtc_bbpu_power_on done [msdc_init]: msdc0 Host controller intialization start [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [SD0] Pins mode(1), none(0), down(1), up(2), keep(3) [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [info][msdc_config_clksrc] input clock is 208000kHz [SD0] Bus Width: 1 [info][msdc_config_clksrc] input clock is 208000kHz [SD0] SET_CLK(260kHz): SCLK(260kHz) MODE(0) DDR(0) DIV(200) DS(0) RS(0) [msdc_init]: msdc0 Host controller intialization done ----------------------------------------657 _pwrap_init_sistrobe [Read Test of MT6350] pass,inde ERROR,line=657 _pwrap_init_sistrobe [Read Test-ex=1 rdata=5AA5 [WRAP] ERROR,line=657 _Read Test of MT6350] pass,index=2 rdata---------robe [Read Test of MT6350] pass,index= PRB0 LineState: 0
[PLF]Keep USB Mode [WRAP] pwrap_init_preloader [WRAP] pwrap_init [W657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index= ERROR,line=657 _pwrap_init_sistrobe [Read Test ofex=1 rdata=5AA5 [WRAP] ERROR,line=657 _pwRead Test of MT6350] pass,index=2 rdata=5AA5 [W6robe [Read Test of MT6350] pass,index=3 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=4 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=5 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=6 rdata=5AA5 [WRAP] ERROR,line=657 _pwrap_init_sistrobe [Read Test of MT6350] pass,index=7 rdata=5AA5 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=8 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=9 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=10 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=11 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=12 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=13 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=14 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=15 rdata=B54B [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=16 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=17 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=18 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=19 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=20 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=21 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=22 rdata=6A97 [WRAP] ERROR,line=660 _pwrap_init_sistrobe [Read Test of MT6350] tuning,index=23 rdata=6A97 [WRAP] _pwrap_init_reg_clock [PMIC_WRAP]wrap_init pass,the return value=0. [pmic6350_init] Preloader Start.................. [pmic6350_init] PMIC CHIP Code = 8272 [pmic_init] turn off usbdl wo battery just_rst = 0 pl pmic powerkey Release [pmic6350_init] powerKey = 0 [pmic6350_init] is USB in = 45059 [AUXADC] u4channel[7]=16129. [AUXADC] adc_result_temp=16129, adc_result=3543, r_val_temp=4. [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, start charging... [pl_check_bat_protect_status]: check VBAT=3543 mV with 3000 mV, stop charging... [pmic6350_init] Done................... AP_PLL_CON1= 0x3C3C23C0 AP_PLL_CON2= 0x4 CLKSQ_STB_CON0= 0x25002100 PLL_ISO_CON0= 0x202020 ARMPLL_CON0= 0x11 ARMPLL_CON1= 0x8009A000 ARMPLL_PWR_CON0= 0x5 MPLL_CON0= 0x8000011 MPLL_CON1= 0x800E7000 MPLL_PWR_CON0= 0x5 UPLL_CON0= 0x38000001 UPLL_CON1= 0x1000060 UPLL_PWR_CON0= 0x5DISP_CG_CON0= 0xFFFFFFFC, DISP_CG_CON1= 0x0, [PLF]Init I2C: OK(0) [PLF]Init PWRAP: OK(0) [PLF]Init PMIC: OK(0) [PLF]chip_ver[0]
[BLDR] Build Time: 20160729-161919 [DDR Reserve] ddr reserve mode not be enabled yet RGU rgu_release_rg_dramc_conf_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_iso:MTK_WDT_DEBUG_CTL(590200F1) RGU rgu_release_rg_dramc_sref:MTK_WDT_DEBUG_CTL(590200F1) DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 DDR is in self-refresh. 200F1 ==== Dump RGU Reg ======== RGU MODE: 4D RGU LENGTH: FFE0 RGU STA: 0 RGU INTERVAL: FFF RGU SWSYSRST: 8000 ==== Dump RGU Reg End ==== RGU: g_rgu_satus:0 mtk_wdt_mode_config mode value=10, tmp:22000010 PL P ON WDT does not trigger reboot mtk_wdt_mode_config mode value=5D, tmp:2200005D RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3) Enter mtk_kpd_gpio_set! after set KP enable: KP_SEL = 0x1C70 ! [WDT][0x28A]=0x0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=0 [RTC] get_frequency_meter: input=0x0, ouput=5 [RTC] get_frequency_meter: input=0x0, ouput=5873 [RTC] bbpu = 0x1, con = 0x4A7, osc32con = 0xFC3F, sec = 0x0, yea = 0x2 [RTC] powerkey1 = 0xA357, powerkey2 = 0x67D2 Writeif_unlock [RTC] EOSC_Cali: TOP_CKCON1=0xC0 [RTC] get_frequency_meter: input=0xF, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x17, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1B, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1D, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] EOSC_Cali: val=0x0 [RTC] get_frequency_meter: input=0x1E, ouput=0 [RTC] get_frequency_meter: input=0x1F, ouput=0 [RTC] EOSC cali val = 0xFC9F [RTC] RTC_SPAR0=0x0 [RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x0, spar1 = 0x800 [RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1 [RTC] bbpu = 0x1, con = 0x84A6, cali = 0x0 [WDT2][0x28A]=0x0 pl pmic powerkey Release [PLF]USB/charger boot [RTC] rtc_bbpu_power_on done [msdc_init]: msdc0 Host controller intialization start [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [SD0] Pins mode(1), none(0), down(1), up(2), keep(3) [SD0] Pins mode(2), none(0), down(1), up(2), keep(3) [info][msdc_config_clksrc] input clock is 208000kHz [SD0] Bus Width: 1 [info][msdc_config_clksrc] input clock is 208000kHz [SD0] SET_CLK(260kHz): SCLK(260kHz) MODE(0) DDR(0) DIV(200) DS(0) RS(0) [msdc_init]: msdc0 Host controller intialization done
Видать прелоадер кончили . Тест поинт подскажите .
_________________ "Анархия -мать порядка " - вольная трактовка "Теории хаоса "
