HP EliteBook 850G ProdiD 2FH32AV https://vlab.su/viewtopic.php?f=289&t=104965 |
Павел0496 [ 18 июл 2020, 11:54 ] | |
Заголовок сообщения: | Re: HP EliteBook 850G ProdiD 2FH32AV |
На этих устройствах только програматор поможет. Других вариантов нет |
macpanter [ 18 июл 2020, 14:31 ] | |
Здравствуйте , Друг мой, скажи мне, где найти монету на карте матери? Спасибо. |
RsM [ 19 июл 2020, 16:45 ] | |
macpanter Write English. Russian translation is not correct. There is no coin cell because battery inside. Password can be cleared only by reflash bios chip by the programmer. |
macpanter [ 20 июл 2020, 12:22 ] | |
Hello, How do we unlock the .bin file? Is there a procedure or a technique? I don't want my serial number changed. I want to keep the same serial number. thank you in advance |
RsM [ 20 июл 2020, 15:37 ] | |
You need to dump (read) your flash, download bios from hp site, unpack, decrypt and do some operations in Hex editor with this update and your ori dump and after flash this moded file back to flash. |
