Текущее время: 18 июн 2024, 15:09
 Заголовок сообщения: How to read/edit flash descriptor/vscc table in AMD platform bios ?
СообщениеДобавлено: 24 май 2024, 18:01
Hi..
Could someone please tell me how to edit or read the vscc table in AMD bios ?
I have a bad 74m12jwsiq chip on nm-d521 board, it's a rpmc chip and I want to check the table in the dump for all rpmc supported chips
is it possible to disable rpmc to support regular non-rpmc chips ?
edit: the original 74m12jwsiq throws errors while verifying but still the board starts with it, while a fresh dump with a regular 25q128 chip won't give a start at all..
 Заголовок сообщения: Re: How to read/edit flash descriptor/vscc table in AMD platform bios ?
СообщениеДобавлено: 25 май 2024, 01:20
what w25q128 ?
1.8v only - w25q128fwsq jwsq needed
СообщениеДобавлено: 25 май 2024, 02:22
jocker писал(а):
what w25q128 ?
of course it should be 1.8v (fw..jw..), the point is there is no start at all with non-rpmc chips... is it possible to disable it and how to edit amd bios and check vscc table ?
I'm very familiar with intel bios but not with amd's :ne_ne_ne:
СообщениеДобавлено: 26 май 2024, 01:44
Try exact W25Q128JW SPI. Or just buy a new RPMC SPI - W74M12JW or W25R128JW
СообщениеДобавлено: 30 май 2024, 19:28
It turned out the chip is good :ups:
on the EZP programmer with 1.8v adapter the chip is not detected, manually select W25Q128FW(1.8v), DO NOT USE AUTO FUNCTION !
Manually erase -> write -> disconnect and reconnect the programmer -> verify
and it will verify successfully :co_ol:
for how to check supported chips in AMD bios, it turned out to be easy... using UEFITool the supported chips will be found in SPIFlashProDXE or just search text "winbond" and check with hex view :co_ol:
closing..
В этой теме нет новых непрочитанных сообщений. bios laptop (Asus) edit
dodo1
13 апр 2016, 14:51
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. toshiba l500d -00x (la-5332p rev:1.0 AMD platform) bios needed
в форуме Toshiba
alifakhrniya
08 апр 2015, 11:30
elf22 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Ищу Edit матрицы LM238WF2(SS)(K1)
в форуме LG
volshebnik
16 май 2019, 09:40
volshebnik Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Help, how to read the password file bin bios dell?
maseraati
01 дек 2017, 05:09
maseraati Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba C55-A DB10BM how read/change Windows Key from damaged dump BIOS
cov
22 фев 2017, 18:10
kmk Перейти к последнему сообщению
Сейчас этот форум просматривают: harfun, saber, Uicholi и гости: 12
