It turned out the chip is good
on the EZP programmer with 1.8v adapter the chip is not detected, manually select W25Q128FW(1.8v), DO NOT USE AUTO FUNCTION !
Manually erase -> write -> disconnect and reconnect the programmer -> verify
and it will verify successfully
for how to check supported chips in AMD bios, it turned out to be easy... using UEFITool the supported chips will be found in SPIFlashProDXE or just search text "winbond" and check with hex view
closing..
