https://vlab.su/
Lenovo thinkpad T14 gen 1 Amd Ryzen Pro need EC dump
https://vlab.su/viewtopic.php?f=294&t=145281
Страница 1 из 1
mohkam3000 [ 02 ноя 2024, 17:09 ]
Заголовок сообщения:  Lenovo thinkpad T14 gen 1 Amd Ryzen Pro need EC dump
Platform GT 4A1-NM-C801
Please post clean EC Dump or help remove bios from attached backup.
Thanks.
Doc [ 02 ноя 2024, 18:09 ]
Заголовок сообщения:  Re: Lenovo thinkpad T14 gen 1 Amd Ryzen Pro need EC dump
use this
viewtopic.php?f=294&t=136639
mainvod [ 02 ноя 2024, 18:15 ]
Here you go. Try this file
EC.rar
mohkam3000 [ 03 ноя 2024, 14:51 ]
Thanks for your reply.
The original backup dump size is 128ko whereas the file you posted is 256ko (double).
Any new suggestion is welcome.
---------- Добавлено спустя 2 минуты 50 секунд: ----------
Doc писал(а):
use this
Thanks for the link. It's very instructive.
Doc [ 03 ноя 2024, 17:35 ]
it5261VG-256 = 256kb
it5261VG-512 = 512kb
it`s very simple
what`s yours? Make the right choice in my tool ECFinder from the link above and it`ll cut EC firmware automatically from a bios dump or update
mohkam3000 [ 04 ноя 2024, 01:45 ]
it`s very simple
Mine is it5261VG-512
I tried with ECFinder_0.5.1 and ECFinder_0.4.7 as well and cmd opens and closes immediately with the error message attached.
I also used Console Mode and got the error message, I attach.
Please help me to overcome this issue.
Also, I would appreciate if you could, from your side, try ECFinder with my above attached EC dump file and post the output file if any. Might be that some DLL files needed are failing in my system, though no specific error displayed.
Doc [ 04 ноя 2024, 02:22 ]
here you are
main + EC
from official Lenovo T14 Gen 1 (type 20UD, 20UE)
PS no need any additional dlls - working on bare windows7x64+
mohkam3000 [ 04 ноя 2024, 23:54 ]
I used ECFinder_0.4.7 and ECFinder_0.5.1 in windows 10 system and it succeeded but don't understand how to access the saved output file ? Could you please clarify the next steps, the url that opens is in russian language.
Doc писал(а):
here you are
main + EC
Many thanks for the file. I used it but unfortunately no change, superviser password is always requested. I find strange that my EC dump shows 128ko of size, before and after flashing the new dump ?
P.S As EC size is not clearly readable on the chip, I got 512ko from a schematic, I also wrote the 256ko dump posted by mainvod to no avail.
Doc [ 05 ноя 2024, 00:25 ]
output file in the same directory as it's source file
funny video from Indian guy )
https://youtu.be/cP1xIN8-FNY?t=313
I think that`s how you read it, not setting manually the correct size of the EC
mohkam3000 [ 09 ноя 2024, 00:58 ]
I revert. Now, I'am well doing with EcFinder after seeing the video. Thanks. It turned out that the correct size of the it5261VG chip in my case is 256kb. So I reworked out the R1BET81W.zip [7.78 MB] dump you posted on the base of 256kb and got a file of 256, whereas the original backup dump file is only 128kb how to explain that ? Is the EC chip failing, not reading the correct size of it's integrated bios ?
http://www.phpbb.com/
