Текущее время: 27 сен 2024, 15:30
westcoast
Заголовок сообщения: Micron M600 drive damaged Добавлено: 01 окт 2020, 02:34 |
Зарегистрирован: 01 окт 2020, 02:15 Наличности на руках: 157.19
Сообщения: 171 Откуда: europe
Hello Dropped a small screwdriver on the mainboard, it hit EC, on the bottom side was this drive. After that it no longer mounts or boot, but it was still detected in OS with full size - only unallocated. Then, during diagnose, made a short somewhere and also drive did not recognized anymore at all. After made a short I lost 1.8V on R10, does it mean the MSP430 is gone? For reference here is what I gathered: Вложение: 20200626_111118.jpg Вложение: RESISTORS.jpg
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 26 мар 2024, 01:18 |
with some help on hddguru a progress has been made M25P16 with only 13ohm on VCC was getting hot, but still detected and most of the data looked good 0 ?? CORRUPT 30000 Identify Device OK 40000 BOOT (marvell bootloader) OK 50000 ?? table OK 60000 zero marker OK B0000 DSSR table OK C0000 multi DSSR table OK E0000 MSP430 fw OK 110000 unknown table OK 130000 unknown table CORRUPT 140000 unknown table (ascii indicate thermal) OK 150000 unknown table CORRUPT 170000 unknown OK 1A0000 backup of unknown at 170000 OK 1F0000 signature? OK
now it was figured out first (most damaged) block is the same as BOOT block at 0x40000 (backup), the two coruppted tables have about 100 or less bytes of difference when compared multiple dumps. if someone have any kind of micron/crucial dump from disk with 88ss9189 cpu please share here (or in private message)
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 10 апр 2024, 10:16 |
flashed new BIOS with what was recovered, in short, drive starts it's detected but with same messages as before. as there have been attempts already to do secure erase, it is probably fooled now and 100% working BIOS would not help anyway. it can be fixed with JTAG, but need to map pins first somehow, and the question now is what voltage levels 88ss9189 is working at on JTAG port ? should i use level shifter or 3.3V is safe ? [ 3.941131] ata2.00: failed to enable AA (error_mask=0x1) [ 6.417442] ata2.00: READ LOG DMA EXT failed, trying unqueued [ 7.636949] ata2.00: failed to get Log Directory Emask 0x1 [ 7.636951] ata2.00: ATA-10: Micron_M600_MTFDDAV256MBF, MA01, max UDMA/133 [ 7.636952] ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 7.919911] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 12.543788] ata2.00: failed to enable AA (error_mask=0x1) [ 12.621373] ata2.00: failed to get Log Directory Emask 0x1 [ 13.117093] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 13.117097] ata2.00: configured for UDMA/133 (device error ignored) [ 13.117262] scsi 1:0:0:0: Direct-Access ATA Micron_M600_MTFD MA01 PQ: 0 ANSI: 5 [ 13.131222] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 13.131262] ata2.00: Enabling discard_zeroes_data [ 13.131287] sd 1:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB) [ 13.131289] sd 1:0:0:0: [sdb] 4096-byte physical blocks [ 13.131454] sd 1:0:0:0: [sdb] Write Protect is off [ 13.131457] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 13.131508] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 13.131763] ata2.00: Enabling discard_zeroes_data [ 18.927491] ata2: failed to read log page 10h (errno=-5) [ 18.927528] ata2.00: exception Emask 0x1 SAct 0x4 SErr 0x0 action 0x0 [ 18.927563] ata2.00: irq_stat 0x40000001 [ 18.927598] ata2.00: failed command: READ FPDMA QUEUED [ 18.927636] ata2.00: cmd 60/08:10:00:00:00/00:00:00:00:00/40 tag 2 ncq dma 4096 in [ 18.927636] res 41/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 18.927677] ata2.00: status: { DRDY ERR } [ 18.927710] ata2.00: error: { ABRT } [ 23.818734] ata2.00: failed to enable AA (error_mask=0x1) [ 26.865931] ata2.00: failed to get Log Directory Emask 0x1 [ 29.347253] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 37.619699] ata2.00: failed to enable AA (error_mask=0x1) [ 40.584111] ata2.00: failed to get Log Directory Emask 0x1 [ 43.191926] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 43.191929] ata2.00: configured for UDMA/133 (device error ignored) [ 43.191944] ata2: EH complete [ 43.205093] ata2.00: Enabling discard_zeroes_data [ 48.489537] ata2: failed to read log page 10h (errno=-5) [ 48.489573] ata2.00: NCQ disabled due to excessive errors [ 48.489575] ata2.00: exception Emask 0x1 SAct 0x10 SErr 0x0 action 0x0 [ 48.489610] ata2.00: irq_stat 0x40000001 [ 48.489644] ata2.00: failed command: READ FPDMA QUEUED [ 48.489681] ata2.00: cmd 60/08:20:00:00:00/00:00:00:00:00/40 tag 4 ncq dma 4096 in [ 48.489681] res 41/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 48.489722] ata2.00: status: { DRDY ERR } [ 48.489760] ata2.00: error: { ABRT } [ 52.841119] ata2.00: failed to enable AA (error_mask=0x1) [ 52.928427] ata2.00: failed to get Log Directory Emask 0x1 [ 53.232110] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 55.571414] ata2.00: failed to enable AA (error_mask=0x1) [ 56.398928] ata2.00: failed to get Log Directory Emask 0x1 [ 58.273812] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 58.273815] ata2.00: configured for UDMA/133 (device error ignored) [ 58.273828] ata2: EH complete [ 60.854110] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 60.854154] ata2.00: irq_stat 0x40000001 [ 60.854193] ata2.00: failed command: READ DMA [ 60.854234] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 22 dma 4096 in [ 60.854234] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 60.854289] ata2.00: status: { DRDY ERR } [ 60.854327] ata2.00: error: { ABRT } [ 63.249316] ata2.00: failed to enable AA (error_mask=0x1) [ 63.548272] ata2.00: failed to get Log Directory Emask 0x1 [ 63.711722] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 64.770564] ata2.00: failed to enable AA (error_mask=0x1) [ 64.839050] ata2.00: failed to get Log Directory Emask 0x1 [ 64.897732] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 64.897735] ata2.00: configured for UDMA/133 (device error ignored) [ 64.897748] ata2: EH complete [ 65.177107] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 65.177147] ata2.00: irq_stat 0x40000001 [ 65.177185] ata2.00: failed command: READ DMA [ 65.177225] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 23 dma 4096 in [ 65.177225] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 65.177279] ata2.00: status: { DRDY ERR } [ 65.177316] ata2.00: error: { ABRT } [ 66.108741] ata2.00: failed to enable AA (error_mask=0x1) [ 66.472860] ata2.00: failed to get Log Directory Emask 0x1 [ 68.587025] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 70.801023] ata2.00: failed to enable AA (error_mask=0x1) [ 72.331933] ata2.00: failed to get Log Directory Emask 0x1 [ 72.819403] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 72.819406] ata2.00: configured for UDMA/133 (device error ignored) [ 72.819419] ata2: EH complete [ 73.321106] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 73.321146] ata2.00: irq_stat 0x40000001 [ 73.321184] ata2.00: failed command: READ DMA [ 73.321224] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 24 dma 4096 in [ 73.321224] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 73.321279] ata2.00: status: { DRDY ERR } [ 73.321316] ata2.00: error: { ABRT } [ 74.158237] ata2.00: failed to enable AA (error_mask=0x1) [ 74.922513] ata2.00: failed to get Log Directory Emask 0x1 [ 75.474763] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 78.083653] ata2.00: failed to enable AA (error_mask=0x1) [ 78.586504] ata2.00: failed to get Log Directory Emask 0x1 [ 79.087432] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 79.087435] ata2.00: configured for UDMA/133 (device error ignored) [ 79.087448] ata2: EH complete [ 79.544105] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 79.544144] ata2.00: irq_stat 0x40000001 [ 79.544182] ata2.00: failed command: READ DMA [ 79.544222] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 25 dma 4096 in [ 79.544222] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 79.544277] ata2.00: status: { DRDY ERR } [ 79.544314] ata2.00: error: { ABRT } [ 83.234211] ata2.00: failed to enable AA (error_mask=0x1) [ 83.574308] ata2.00: failed to get Log Directory Emask 0x1 [ 83.878648] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 86.676831] ata2.00: failed to enable AA (error_mask=0x1) [ 87.269850] ata2.00: failed to get Log Directory Emask 0x1 [ 87.680971] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 87.680974] ata2.00: configured for UDMA/133 (device error ignored) [ 87.680990] sd 1:0:0:0: [sdb] tag#25 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 87.680993] sd 1:0:0:0: [sdb] tag#25 Sense Key : Illegal Request [current] [ 87.680996] sd 1:0:0:0: [sdb] tag#25 Add. Sense: Unaligned write command [ 87.681000] sd 1:0:0:0: [sdb] tag#25 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 87.681014] blk_update_request: I/O error, dev sdb, sector 0 [ 87.681054] Buffer I/O error on dev sdb, logical block 0, async page read [ 87.681098] ata2: EH complete [ 88.247049] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 88.247089] ata2.00: irq_stat 0x40000001 [ 88.247126] ata2.00: failed command: READ DMA [ 88.247166] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 26 dma 4096 in [ 88.247166] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 88.247222] ata2.00: status: { DRDY ERR } [ 88.247258] ata2.00: error: { ABRT } [ 90.175382] ata2.00: failed to enable AA (error_mask=0x1) [ 90.556796] ata2.00: failed to get Log Directory Emask 0x1 [ 91.431298] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 94.895635] ata2.00: failed to enable AA (error_mask=0x1) [ 97.725086] ata2.00: failed to get Log Directory Emask 0x1 [ 99.748702] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 99.748705] ata2.00: configured for UDMA/133 (device error ignored) [ 99.748718] ata2: EH complete [ 102.443111] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 102.443151] ata2.00: irq_stat 0x40000001 [ 102.443189] ata2.00: failed command: READ DMA [ 102.443229] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 27 dma 4096 in [ 102.443229] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 102.443284] ata2.00: status: { DRDY ERR } [ 102.443321] ata2.00: error: { ABRT } [ 107.362437] ata2.00: failed to enable AA (error_mask=0x1) [ 110.155674] ata2.00: failed to get Log Directory Emask 0x1 [ 112.016021] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 114.195136] ata2.00: failed to enable AA (error_mask=0x1) [ 114.599967] ata2.00: failed to get Log Directory Emask 0x1 [ 115.056393] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 115.056396] ata2.00: configured for UDMA/133 (device error ignored) [ 115.056409] ata2: EH complete [ 115.167107] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 115.167147] ata2.00: irq_stat 0x40000001 [ 115.167184] ata2.00: failed command: READ DMA [ 115.167224] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 28 dma 4096 in [ 115.167224] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 115.167279] ata2.00: status: { DRDY ERR } [ 115.167316] ata2.00: error: { ABRT } [ 115.586820] ata2.00: failed to enable AA (error_mask=0x1) [ 115.777539] ata2.00: failed to get Log Directory Emask 0x1 [ 116.085981] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 121.464289] ata2.00: failed to enable AA (error_mask=0x1) [ 124.249129] ata2.00: failed to get Log Directory Emask 0x1 [ 127.208265] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 127.208268] ata2.00: configured for UDMA/133 (device error ignored) [ 127.208281] ata2: EH complete [ 129.368108] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 129.368149] ata2.00: irq_stat 0x40000001 [ 129.368187] ata2.00: failed command: READ DMA [ 129.368226] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 29 dma 4096 in [ 129.368226] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 129.368281] ata2.00: status: { DRDY ERR } [ 129.368318] ata2.00: error: { ABRT } [ 131.075137] ata2.00: failed to enable AA (error_mask=0x1) [ 136.160085] ata2.00: qc timeout (cmd 0x2f) [ 136.160096] ata2.00: failed to get Log Directory Emask 0x5 [ 136.160097] ata2.00: failed to get Identify Device Data, Emask 0x40 [ 136.160101] ata2.00: failed to set xfermode (err_mask=0x40) [ 136.160143] ata2: hard resetting link [ 136.470587] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 141.792060] ata2.00: qc timeout (cmd 0xec) [ 141.792071] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4) [ 141.792072] ata2.00: revalidation failed (errno=-5) [ 141.792112] ata2: limiting SATA link speed to 1.5 Gbps [ 141.792114] ata2: hard resetting link [ 142.102637] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 152.544078] ata2.00: qc timeout (cmd 0xec) [ 152.544089] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4) [ 152.544090] ata2.00: revalidation failed (errno=-5) [ 152.544128] ata2.00: disabled [ 152.544138] ata2: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x6 frozen t4 [ 152.544183] ata2: SError: { HostInt } [ 152.544220] ata2: hard resetting link [ 152.854491] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 152.854499] ata2: EH complete [ 152.854508] sd 1:0:0:0: [sdb] tag#30 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854511] sd 1:0:0:0: [sdb] tag#30 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854512] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854551] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854628] sd 1:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854632] sd 1:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854634] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854674] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854728] ldm_validate_partition_table(): Disk read failed. [ 152.854756] sd 1:0:0:0: [sdb] tag#1 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854759] sd 1:0:0:0: [sdb] tag#1 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854760] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854799] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854852] sdb: unable to read partition table [ 152.855081] sd 1:0:0:0: [sdb] Read Capacity(16) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.855083] sd 1:0:0:0: [sdb] Sense not available. [ 152.855144] sd 1:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.855146] sd 1:0:0:0: [sdb] Sense not available. [ 152.855324] sd 1:0:0:0: [sdb] Attached SCSI disk [ 154.221502] sd 1:0:0:0: [sdb] tag#25 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 154.221508] sd 1:0:0:0: [sdb] tag#25 CDB: ATA command pass through(16) 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00 [ 162.361298] sd 1:0:0:0: [sdb] tag#29 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 162.361304] sd 1:0:0:0: [sdb] tag#29 CDB: ATA command pass through(16) 85 06 20 00 00 00 00 00 00 00 00 00 00 40 e6 00 [ 162.361321] sd 1:0:0:0: [sdb] tag#30 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 162.361323] sd 1:0:0:0: [sdb] tag#30 CDB: ATA command pass through(16) 85 06 20 00 00 00 00 00 00 00 00 00 00 40 99 00
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 13 май 2024, 18:59 |
this was last serial log, i thought it won't get to this point after restoring copy of initially flashed dump (which did not contain additions to bad block table that the drive automatically made on first boot attempt after repair), at least SATA did not work and wasn't visible in linux who can tell the cause of the line 11 garbled like this? RPehyeArdved ablem RPehyeArdved ablem InitFTLPhyAddrTable Done
<CusInfo Init> FeatureMacros=08F001FA
@@@@4235394C@@@4235394C
@NAND_RAW_CAPACITY:256
@USER_CAPACITY:256
@TOTAL_USER_LBA:500118192
WP_SB_BAD_BLOCK_THRESHOLD 68, wWP_DATA_BLK_CNT_WITH_OP 965, FREE_THRESHOLD_PERIODIC 11, WP_PGC_MARGIN 4
X300: Establish PHY Link TIMEOUT, sending COMRESET
# Boot Loader Configuration: SCRAMBLER_ON_ROM_TABLE
Check CRC fail: 0x000F0000!
Get temp 0000001A
<EL>NOR SIZE 2048K, SECTOR SIZE 64K, PAGE SIZE 256
<EL>EL ENTRY SIZE 64
<EL>Base Sec: CRITICAL 0x12, GENERIC 0x14
<EL>Class0: ACTIVE SEG 19, ACTIVE LAST ENTRY 701
<EL>Class1: ACTIVE SEG 20, ACTIVE LAST ENTRY 71
<EL>Max Entry Ver 0x00004706
<EL>EL Flash INIT OK
<BIT>Parity Check fail!
<BIT>Load Fail
L Sec : 00000000
U Sec : 00000000
S0 Wr : 00000000
S1 Wr : 00000000
Need erase: 00000001
<BIT>Erase : 00000000
Need erase: 00000000
<BPC> Init
<BPC> Enable
<BPC> Force All Lun to MLC
PreTH:4 NewTH:1
SEDERR: 00000208
SEDERR: 0000010C
SEDERR: 00000301
SEDERR: 0000010C
<INIT>Meta Info
ATA read nor
Err! InitMi media read err!
Warning! InitMi Id 001 data default to 0!
Warning! InitMi Id 003 data default to 0!
Warning! InitMi Id 004 data default to 0!
Warning! InitMi Id 006 data default to 0!
DCO flag 00000000
Warning! InitMi Id 00E data default to 0!
Warning! InitMi Id 011 data default to 0!
Warning! InitMi Id 012 data default to 0!
Warning! InitMi Id 013 data default to 0!
~~~~ATA Save 00000014
Err! SaveMi Wr Protected!
Security Feature ERR!
SEDERR: 0000010C
DCO flag 00000000
init GPIO 11
# Initialize sata link... 1434267 #
wRandIndex = 0
WP_SB_BAD_BLOCK_THRESHOLD = 68
LPP is enabled
Load Turbo Boot
<INIT>BbTbl
<BB>Load BbTbl
wRandIndex = 0
CopyIdx:0 is good
<INIT>VerTbl
BPC: Enable
Block BPC mode:
000: 00 00 00 01 00 00 00 00
040: 40 10 00 00 00 00 00 00
080: 01 00 08 00 00 00 00 00
0C0: 01 00 02 00 00 00 00 00
100: 80 00 00 00 00 00 80 00
140: 00 00 00 00 00 00 00 80
180: 00 20 00 00 00 00 00 00
1C0: 00 00 80 00 00 00 00 01
200: 00 00 00 00 00 00 00 00
240: 00 00 00 00 02 00 00 00
280: 00 00 00 00 02 00 00 02
2C0: 00 00 08 00 00 00 00 00
300: 00 00 00 40 10 00 00 00
340: 00 40 00 00 00 00 00 00
380: 00 00 00 00 00 00 80 00
3C0: 00 00 01 00 00 02 00 00
400: 00 00 00
Lun BPC mode:
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
Nand SFBL(0x10)/FA91(0x08) mode:
0.0.0: 33/3F
1.0.0: 33/3F
2.0.0: 33/3F
3.0.0: 33/3F
4.0.0: 33/3F
5.0.0: 33/3F
6.0.0: 33/3F
7.0.0: 33/3F
0.0.1: 33/3F
1.0.1: 33/3F
2.0.1: 33/3F
3.0.1: 33/3F
4.0.1: 33/3F
5.0.1: 33/3F
6.0.1: 33/3F
7.0.1: 33/3F
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
<VER_ORI>Last Blk : 00000090, last version : 009EEEED
<TBINIT>3 : 717277 us
<INIT>LastBlkP2l
<P0BF,118120BF>
Scan:11555 us 10
<AT>LWI.Ptu:118120BF, Blk:00000090, Page:000000BF, Seg:00000018, Offset:00000001
mhSegIdx:00000019, ahGoodSeg[wIdx - 1]:00000018,ahGoodSeg[wIdx]:00000019
<P2L>Scan Blk:090, Lwpl:0BF, FPtu:118120BF
P2Lptu_EH!hP=00000000, eP=00000007
******EH...Good Luck******
BPC: Enable
Block BPC mode:
400: 00 00 00
Lun BPC mode:
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
0.0.0: 33/0A
1.0.0: 33/0A
2.0.0: 33/0A
3.0.0: 33/0A
4.0.0: 33/0A
5.0.0: 33/0A
6.0.0: 33/0A
7.0.0: 33/0A
0.0.1: 33/0A
1.0.1: 33/0A
2.0.1: 33/0A
3.0.1: 33/0A
4.0.1: 33/0A
5.0.1: 33/0A
6.0.1: 33/0A
7.0.1: 33/0A
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
E 0
C:2
L:FFFFFFFF,FFFFFFFF
P:01212000,11212000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:0
Get temp 0000001A
<DR>01212000
ATLVP0 ATLWP0
CH:2 CE:0 LUN:0 BLK:121 PAGE:000
IsSLC:0 Edg:1 Odd:1 Lo:0 Lvp:0 LpO:0 PG:0 EG:0 RG:0
Warning: Empty page!
Former nand trim: R10:53 R00:88 R01:75
<30s same temp 0000001A!
<Vp M0 blk121 page000>
Tg:0/F Vp:0/F
FD:1 BB:1
<QB>: Not Quick Boot this time
RDRcv:383,144,2,0,0,0,12120000
StrF:1
RainCnt:127
RAIN PTU 03712070 ErrCode 1. RLC.
Abort RAIN:Empty page.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:01212000
<RdPre>Next P:0x01312000
<DR>11212000
ATLVP0 ATLWP0
Tg:0/F Vp:0/F
FD:1 BB:1
StrF:1
RainCnt:127
RAIN PTU 13712070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:11212000
<Rd>DRPTU:01212000-Sts:00000004
<Rd>DRPTU:11212000-Sts:00000004
E 1
C:2
L:FFFFFFFF,FFFFFFFF
P:01412000,11412000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:1
<DR>01412000
ATLVP0 ATLWP0
CH:4 CE:0 LUN:0 BLK:121 PAGE:000
Former nand trim: R10:4B R00:82 R01:6C
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:01412000
<RdPre>Next P:0x01512000
<DR>11412000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:11412000
<Rd>DRPTU:01412000-Sts:00000004
<Rd>DRPTU:11412000-Sts:00000004
E 2
C:2
L:FFFFFFFF,FFFFFFFF
P:01A12000,11A12000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:2
<DR>01A12000
ATLVP0 ATLWP0
Tg:0/F Vp:0/F
FD:1 BB:1
RDRcv:383,144,2,0,0,0,1A120000
StrF:1
RainCnt:127
RAIN PTU 03F12070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:01A12000
<RdPre>Next P:0x01B12000
<DR>11A12000
ATLVP0 ATLWP0
Tg:0/F Vp:0/F
FD:1 BB:1
StrF:1
RainCnt:127
RAIN PTU 13F12070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:11A12000
<Rd>DRPTU:01A12000-Sts:00000004
<Rd>DRPTU:11A12000-Sts:00000004
E 3
C:2
L:FFFFFFFF,FFFFFFFF
P:01C12000,11C12000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:3
<DR>01C12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:01C12000
<RdPre>Next P:0x01D12000
<DR>11C12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:11C12000
<Rd>DRPTU:01C12000-Sts:00000004
<Rd>DRPTU:11C12000-Sts:00000004
E 4
C:2
L:FFFFFFFF,FFFFFFFF
P:02012000,12012000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:4
<DR>02012000
ATLVP0 ATLWP0
CH:0 CE:0 LUN:1 BLK:120 PAGE:000
Former nand trim: R10:59 R00:8F R01:71
<Vp M0 blk00001120 page000>
Tg:0/F Vp:0/F
FD:1 BB:1
RDRcv:383,144,2,0,0,0,20120000
StrF:1
RainCnt:127
RAIN PTU 02712070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:02012000
<RdPre>Next P:0x02112000
<RdPre>Read Error! ECODE: 1
<DR>12112000
ATLVP0 ATLWP0
CH:1 CE:0 LUN:1 BLK:120 PAGE:000
Former nand trim: R10:74 R00:9D R01:74
Tg:0/F Vp:0/F
FD:1 BB:1
RDRcv:383,144,2,0,0,0,21120000
StrF:1
RainCnt:127
RAIN PTU 12712070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:12112000
<DR>12012000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12012000
<Rd>DRPTU:02012000-Sts:00000004
<Rd>DRPTU:12012000-Sts:00000004
E 5
C:2
L:FFFFFFFF,FFFFFFFF
P:02112000,12112000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:5
<DR>02112000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02112000
<RdPre>Next P:0x02212000
<DR>12212000
ATLVP0 ATLWP0
CH:2 CE:0 LUN:1 BLK:120 PAGE:000
Former nand trim: R10:43 R00:7D R01:70
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12212000
<DR>12112000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<Rd>DRPTU:02112000-Sts:00000004
<Rd>DRPTU:12112000-Sts:00000004
E 6
C:2
L:FFFFFFFF,FFFFFFFF
P:02212000,12212000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:6
<DR>02212000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02212000
<RdPre>Next P:0x02312000
<DR>12212000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<Rd>DRPTU:02212000-Sts:00000004
<Rd>DRPTU:12212000-Sts:00000004
E 7
C:2
L:FFFFFFFF,FFFFFFFF
P:02412000,12412000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:7
<DR>02412000
ATLVP0 ATLWP0
CH:4 CE:0 LUN:1 BLK:120 PAGE:000
Former nand trim: R10:53 R00:8B R01:6E
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02412000
<RdPre>Next P:0x02512000
<DR>12412000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12412000
<Rd>DRPTU:02412000-Sts:00000004
<Rd>DRPTU:12412000-Sts:00000004
<EH>Empty
<CleanET>Ptu:01212000, AuCnt:2
<CleanET>Ptu:01412000, AuCnt:2
<CleanET>Ptu:01A12000, AuCnt:2
<CleanET>Ptu:01C12000, AuCnt:2
<CleanET>Ptu:02012000, AuCnt:2
<CleanET>Ptu:02112000, AuCnt:2
<CleanET>Ptu:02212000, AuCnt:2
<CleanET>Ptu:02412000, AuCnt:2
<EH>EH:278635us.
******EH...Good Bye******
<StoreET>Ptu:01212000, AuCnt:2
<StoreET>Ptu:01412000, AuCnt:2
<StoreET>Ptu:01A12000, AuCnt:2
<StoreET>Ptu:01C12000, AuCnt:2
<StoreET>Ptu:02012000, AuCnt:2
<StoreET>Ptu:02112000, AuCnt:2
<StoreET>Ptu:02212000, AuCnt:2
<StoreET>Ptu:02412000, AuCnt:2
BPC: Enable
Block BPC mode:
400: 00 00 00
Lun BPC mode:
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
0.0.0: 33/0A
1.0.0: 33/0A
2.0.0: 33/0A
3.0.0: 33/0A
4.0.0: 33/0A
5.0.0: 33/0A
6.0.0: 33/0A
7.0.0: 33/0A
0.0.1: 33/0A
1.0.1: 33/0A
2.0.1: 33/0A
3.0.1: 33/0A
4.0.1: 33/0A
5.0.1: 33/0A
6.0.1: 33/0A
7.0.1: 33/0A
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
E 0
C:2
L:FFFFFFFF,FFFFFFFF
P:02812000,12812000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:0
<DR>02812000
ATLVP0 ATLWP0
Tg:0/F Vp:0/F
FD:1 BB:1
RDRcv:383,144,2,0,0,0,28120000
StrF:1
RainCnt:127
RAIN PTU 02F12070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:02812000
<RdPre>Next P:0x02912000
<DR>12912000
ATLVP0 ATLWP0
Tg:0/F Vp:0/F
FD:1 BB:1
RDRcv:383,144,2,0,0,0,29120000
StrF:1
RainCnt:127
RAIN PTU 12F12070 ErrCode 1. RLC.
<DR>TgC:0/F
<DR>FAIL
<InitTmpBB>Ptu:12912000
<DR>12812000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12812000
<Rd>DRPTU:02812000-Sts:00000004
<Rd>DRPTU:12812000-Sts:00000004
<EH>Empty
<CleanET>Ptu:02812000, AuCnt:2
<EH>EH:64387us.
<StoreET>Ptu:02812000, AuCnt:2
BPC: Enable
Block BPC mode:
400: 00 00 00
Lun BPC mode:
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
0.0.0: 33/0A
1.0.0: 33/0A
2.0.0: 33/0A
3.0.0: 33/0A
4.0.0: 33/0A
5.0.0: 33/0A
6.0.0: 33/0A
7.0.0: 33/0A
0.0.1: 33/0A
1.0.1: 33/0A
2.0.1: 33/0A
3.0.1: 33/0A
4.0.1: 33/0A
5.0.1: 33/0A
6.0.1: 33/0A
7.0.1: 33/0A
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
E 0
C:2
L:FFFFFFFF,FFFFFFFF
P:02912000,12912000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:0
<DR>02912000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02912000
<RdPre>Next P:0x02A12000
<DR>12A12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12A12000
<DR>12912000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<Rd>DRPTU:02912000-Sts:00000004
<Rd>DRPTU:12912000-Sts:00000004
<EH>Empty
<CleanET>Ptu:02912000, AuCnt:2
<EH>EH:40811us.
<StoreET>Ptu:02912000, AuCnt:2
BPC: Enable
Block BPC mode:
400: 00 00 00
Lun BPC mode:
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
0.0.0: 33/0A
1.0.0: 33/0A
2.0.0: 33/0A
3.0.0: 33/0A
4.0.0: 33/0A
5.0.0: 33/0A
6.0.0: 33/0A
7.0.0: 33/0A
0.0.1: 33/0A
1.0.1: 33/0A
2.0.1: 33/0A
3.0.1: 33/0A
4.0.1: 33/0A
5.0.1: 33/0A
6.0.1: 33/0A
7.0.1: 33/0A
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
E 0
C:2
L:FFFFFFFF,FFFFFFFF
P:02A12000,12A12000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:0
<DR>02A12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02A12000
<RdPre>Next P:0x02B12000
<DR>12A12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<Rd>DRPTU:02A12000-Sts:00000004
<Rd>DRPTU:12A12000-Sts:00000004
<EH>Empty
<CleanET>Ptu:02A12000, AuCnt:2
<EH>EH:30430us.
<StoreET>Ptu:02A12000, AuCnt:2
BPC: Enable
Block BPC mode:
400: 00 00 00
Lun BPC mode:
Nand BPC mode:
0 0.0.0:00000102
0 1.0.0:00000102
0 2.0.0:00000102
0 3.0.0:00000102
0 4.0.0:00000102
0 5.0.0:00000102
0 6.0.0:00000102
0 7.0.0:00000102
0 0.0.1:00000102
0 1.0.1:00000102
0 2.0.1:00000102
0 3.0.1:00000102
0 4.0.1:00000102
0 5.0.1:00000102
0 6.0.1:00000102
0 7.0.1:00000102
0.0.0: 33/0A
1.0.0: 33/0A
2.0.0: 33/0A
3.0.0: 33/0A
4.0.0: 33/0A
5.0.0: 33/0A
6.0.0: 33/0A
7.0.0: 33/0A
0.0.1: 33/0A
1.0.1: 33/0A
2.0.1: 33/0A
3.0.1: 33/0A
4.0.1: 33/0A
5.0.1: 33/0A
6.0.1: 33/0A
7.0.1: 33/0A
BlkPgCnt: 00000100
LP:000000FF
TuCnt:00008000
P2lPC:00000010
P2lTuC:00000020
XorPC:00000080
XorTuC:00000100
E 0
C:2
L:FFFFFFFF,FFFFFFFF
P:02C12000,12C12000
ECC:FF,FF
U:30,O:0,Err:1
BlkVer:009EEEED
wBufIdx:0
<DR>02C12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:02C12000
<RdPre>Next P:0x02D12000
<DR>12C12000
ATLVP0 ATLWP0
Bad Stripe!
Tg:0/F Vp:0/F
FD:1 BB:1
<DR>FAIL
<InitTmpBB>Ptu:12C12000
<Rd>DRPTU:02C12000-Sts:00000004
<Rd>DRPTU:12C12000-Sts:00000004
<EH>Empty
<CleanET>Ptu:02C12000, AuCnt:2
<EH>EH:30703us.
Err!Ptu:13F12000, Ltu:074AF2AF, LastLtu:03BD0705, DummyLtu:03BC1750
DBG_ASSERT: ../Operation/FlsOp_P2LOp.c, line 1227
Save Serial Log in Nor
Len:28047, Start:28047
Len:28071, Start:28071
NOR Space Size:131064
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 20 май 2024, 16:29 |
during BIOS changing, something went dead, 0.92V test point became 0.64V (exact pin on controller has 83Kohm/0.97V on working drive 87Kohm on this one), several pins on MSP430 left unpowered
i had to make a basic schematic so you can understand better what is going on
after each soldering attempt i do always check main power resistances and one thing caught my attention here, a 3.3VOUT kinda following 1.8VOUT resistance, while hot they were identical, and when device cooled down they were identical. the reason i did not pay much attention to this in the beginning was that on 2.5" drive 3.3VOUT was also around 70Kohm.
you would thought it is a short, but direct measurement between the two paths gave over 100Kohm (did not remember the value)
another way to confirm it is to measure drive before and after connecting to host (or in this case m2 to 2.5" adapter) because of a way it is designed, 3.3VIN will no longer 'charge' but it settles at static value (depending on host, on this adapter it is 0.9K directly in laptop is 3K)
so 3.3VIN goes to 0.9Kohm and both 3.3VOUT and 1.8VOUT go to around 70Kohm
all chips have been taken down and reballed, i know NAND sit properly because i dialed all lines from NAND on CPU before soldering CPU, and then dialed DRAM pins of the CPU before soldering DRAM so i knew CPU sit well too, so the first thing to check is take off DRAM
3.3VOUT went to 25-30Kohm and stayed like that, i did not think this is correct and expected the device to either burn or not start, but everything was still the same, except one thing - 3.3VOUT voltage - it was no longer in the insane 3.38-3.4V range, went down to 3.3-3.32V
what really happened here? was there a short under DRAM ? 3.3VOUT had 3.4V when drive failed first time 4y ago and i did not solder anything yet. i bought it as refurbished from USA on ebay they did not want to say much about it but it looks like it was repaired before (OEM sticker looked original, [цензура] the sticker everyone can make it)
now i have 4 cases here in diagram 1. drive not connected to anything 2. drive connected to m2/2.5" adapter 3. drive not connected to anything after DRAM reball 4. drive connected to m2/2.5" adapter after DRAM reball
now it seems to me the same type of issue still exist on 1.8VOUT, as the resistance decreases when inserted into some kind of slot, while all other power paths remain at the same values as out of slot
can anyone explain this?
