Hello to all dear engineers. I'm having trouble flashing some SSDs
Normally, this SSD is not recognized. When connecting as HotPlog, the system HDD light will only light up for a few seconds (without hearing the connection sound) and then nothing else happens. This SSD is recognized only in short jumper JP2 mode (ROM Mode).
Detected NAND In MpTool: Micron MT29F512G08EBLEE (B47R) (3DT)
rtl_flash_id-v0.15a Details: (In ROM Mode With SATA) v0.15a Drive: 3(ATA) OS: 6.1 build 7601 Service Pack 1 ATA: SmartEnable failed! Error: 0x51 ATA: Identify failed! Error: 0x51 Model: REALTEK_RL6643 Fw: 3.AAE Size: 1 MB [0.0 GB] FwStr: [REALTEK_RL6643] ATA: Get FWI failed! Error: 0x51 IOCtl: Get FID2 failed 0x48f! Flash CE Mask: [-------- --------]
Fabric Bad block list (bank0 only):
Later Bad block list (bank0 only): Bank0 BB (Fabric+Later): 0 (0+0)
rtl_flash_id-v0.15a Details: (In ROM Mode With SATA To USB Adapter) v0.15a Drive: 3 (USB) OS: 6.1 build 7601 Service Pack 1 Model: REALTEK_RL6643 Fw: 3.AAE Size: 1 MB [0.0 GB] FwStr: [REALTEK_RL6643] IOCtl: Get FID failed 0x79! IOCtl: Get FID2 failed 0x79! Flash CE Mask: [-------- --------] Banks: 0 Channel: 0 CE: 0 Die/CE: 0 Plane: 0 Block/Die: 0 Page/Block: 0 Sect/Page : 0 FullPageSize: 0 MaxCapacity: 0 MaxPECycle: 0 SharedPages: 0 GCFreeLimit : 0
Checked with MPTool: Realtek RTS5735DL SSDMP V2.48.0.1_20211222 [B47R-VD0R410D] And ssdmp 2.59.0.0_20220610_r_x64
I tried to flash this SSD but the program gets stuck in the LLF section and gives an error. Does anyone know where the problem is and have a solution to get past this step?
More about the error . What does mptool write ? At what step does the error appear? Have you done an RDT scan?
