Текущее время: 21 ноя 2024, 12:51
 Заголовок сообщения: SSD Realtek RL6643 (RTS5735DLQ)
СообщениеДобавлено: 06 авг 2024, 13:51
Hello to all dear engineers.
I'm having trouble flashing some SSDs
Normally, this SSD is not recognized. When connecting as HotPlog, the system HDD light will only light up for a few seconds (without hearing the connection sound) and then nothing else happens.
This SSD is recognized only in short jumper JP2 mode (ROM Mode).
My product specifications are as follows
Model And Brand:
SSD SP A55 256GB
Controller's Laser Print:
RealTek
RTS5735DLQ
L621CP2 GL26AA
NAND's Laser Print:
06T1TA9G200
22000732
3805012
Nand QTY:
1/4 (1 from 4)
Board Name:
15K20760_V1_20210302_RTS5735DL_4B
Detected NAND In MpTool:
Micron
MT29F512G08EBLEE (B47R) (3DT)
rtl_flash_id-v0.15a Details: (In ROM Mode With SATA)
v0.15a
Drive: 3(ATA)
OS: 6.1 build 7601 Service Pack 1
ATA: SmartEnable failed! Error: 0x51
ATA: Identify failed! Error: 0x51
Model: REALTEK_RL6643
Fw: 3.AAE
Size: 1 MB [0.0 GB]
FwStr: [REALTEK_RL6643]
ATA: Get FWI failed! Error: 0x51
IOCtl: Get FID2 failed 0x48f!
Flash CE Mask: [-------- --------]
Fabric Bad block list (bank0 only):
Later Bad block list (bank0 only):
Bank0 BB (Fabric+Later): 0 (0+0)
rtl_flash_id-v0.15a Details: (In ROM Mode With SATA To USB Adapter)
v0.15a
Drive: 3 (USB)
Fw: 3.AAE
Size: 1 MB [0.0 GB]
IOCtl: Get FID failed 0x79!
IOCtl: Get FID2 failed 0x79!
Banks: 0
Channel: 0
CE: 0
Die/CE: 0
Plane: 0
Block/Die: 0
Page/Block: 0
Sect/Page : 0
FullPageSize: 0
MaxCapacity: 0
MaxPECycle: 0
SharedPages: 0
GCFreeLimit : 0
Checked with MPTool:
Realtek RTS5735DL SSDMP V2.48.0.1_20211222 [B47R-VD0R410D]
And
ssdmp 2.59.0.0_20220610_r_x64
I tried to flash this SSD but the program gets stuck in the LLF section and gives an error.
Does anyone know where the problem is and have a solution to get past this step?
 Заголовок сообщения: Re: SSD Realtek RL6643 (RTS5735DLQ)
СообщениеДобавлено: 15 авг 2024, 03:24
http://vlo.name:3000/tmph/rtl_flash_id.rar
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 17 авг 2024, 12:56
I have already used the program you suggested
The information extracted from it is in the first post
I will write it again for you
v0.15a
Drive: 3(ATA)
Fw : 3.AAE
Size : 1 MB [0.0 GB]
Flash CE Mask : [-------- --------]
СообщениеДобавлено: 18 авг 2024, 15:51
More about the error .
What does mptool write ?
At what step does the error appear?
Have you done an RDT scan?
СообщениеДобавлено: 24 авг 2024, 16:58
Hi
Do LLF -> Fail Flash fail(BLOCK_MAPPING). ErrorCode: 0xff41 CH0 CE4 FAIL
Step 13
Yes
СообщениеДобавлено: 26 авг 2024, 16:58
Hi
https://mega.nz/file/vd0FmAoD#uRWvgPKxG ... kd6_1-2NBE
Step 13
Yes
https://mega.nz/file/KN1TiY6Y#rM3ENBKfH ... o6kwamhUxw
СообщениеДобавлено: 10 сен 2024, 18:21
Is there no one to help me?
СообщениеДобавлено: 13 окт 2024, 16:42
Should I close this post since no one knows the answer to my problem?
В этой теме нет новых непрочитанных сообщений. RL6643 (RM1135) + B37R Прошу помощи с прошивкой
в форуме Ремонт SSD | SSD repair and data recovery
Desobi31
2009
18 янв 2024, 19:19
jonpim Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RL6643/RM1135/RTS5735DL + Toshiba BiCS5
absh
26 янв 2024, 22:49
absh Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. SSD REALTEK RL6468 не могу понять
ник65
16
4573
24 дек 2023, 21:26
Energistore Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Помогите восстановить SSD EXRAM / KINGSPEC / CeaMere (Realtek RM1135+Hynix 3dv6)
sazdmitrij
18
4023
10 авг 2023, 00:33
sazdmitrij Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. SSD 1TB Realtek RTS5733
sergey.kochetkoff
14 ноя 2024, 14:05
sergey.kochetkoff Перейти к последнему сообщению
