Текущее время: 09 май 2024, 17:56
westcoast
Заголовок сообщения: Micron M600 drive damaged Добавлено: 01 окт 2020, 02:34 |
Зарегистрирован: 01 окт 2020, 02:15 Наличности на руках: 113.19
Сообщения: 145 Откуда: europe
Hello Dropped a small screwdriver on the mainboard, it hit EC, on the bottom side was this drive. After that it no longer mounts or boot, but it was still detected in OS with full size - only unallocated. Then, during diagnose, made a short somewhere and also drive did not recognized anymore at all. After made a short I lost 1.8V on R10, does it mean the MSP430 is gone? For reference here is what I gathered: Вложение: 20200626_111118.jpg Вложение: RESISTORS.jpg
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 26 мар 2024, 01:18 |
with some help on hddguru a progress has been made M25P16 with only 13ohm on VCC was getting hot, but still detected and most of the data looked good 0 ?? CORRUPT 30000 Identify Device OK 40000 BOOT (marvell bootloader) OK 50000 ?? table OK 60000 zero marker OK B0000 DSSR table OK C0000 multi DSSR table OK E0000 MSP430 fw OK 110000 unknown table OK 130000 unknown table CORRUPT 140000 unknown table (ascii indicate thermal) OK 150000 unknown table CORRUPT 170000 unknown OK 1A0000 backup of unknown at 170000 OK 1F0000 signature? OK
now it was figured out first (most damaged) block is the same as BOOT block at 0x40000 (backup), the two coruppted tables have about 100 or less bytes of difference when compared multiple dumps. if someone have any kind of micron/crucial dump from disk with 88ss9189 cpu please share here (or in private message)
westcoast
Заголовок сообщения: Re: Micron M600 drive damaged Добавлено: 10 апр 2024, 10:16 |
flashed new BIOS with what was recovered, in short, drive starts it's detected but with same messages as before. as there have been attempts already to do secure erase, it is probably fooled now and 100% working BIOS would not help anyway. it can be fixed with JTAG, but need to map pins first somehow, and the question now is what voltage levels 88ss9189 is working at on JTAG port ? should i use level shifter or 3.3V is safe ? [ 3.941131] ata2.00: failed to enable AA (error_mask=0x1) [ 6.417442] ata2.00: READ LOG DMA EXT failed, trying unqueued [ 7.636949] ata2.00: failed to get Log Directory Emask 0x1 [ 7.636951] ata2.00: ATA-10: Micron_M600_MTFDDAV256MBF, MA01, max UDMA/133 [ 7.636952] ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 7.919911] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 12.543788] ata2.00: failed to enable AA (error_mask=0x1) [ 12.621373] ata2.00: failed to get Log Directory Emask 0x1 [ 13.117093] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 13.117097] ata2.00: configured for UDMA/133 (device error ignored) [ 13.117262] scsi 1:0:0:0: Direct-Access ATA Micron_M600_MTFD MA01 PQ: 0 ANSI: 5 [ 13.131222] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 13.131262] ata2.00: Enabling discard_zeroes_data [ 13.131287] sd 1:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB) [ 13.131289] sd 1:0:0:0: [sdb] 4096-byte physical blocks [ 13.131454] sd 1:0:0:0: [sdb] Write Protect is off [ 13.131457] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 13.131508] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 13.131763] ata2.00: Enabling discard_zeroes_data [ 18.927491] ata2: failed to read log page 10h (errno=-5) [ 18.927528] ata2.00: exception Emask 0x1 SAct 0x4 SErr 0x0 action 0x0 [ 18.927563] ata2.00: irq_stat 0x40000001 [ 18.927598] ata2.00: failed command: READ FPDMA QUEUED [ 18.927636] ata2.00: cmd 60/08:10:00:00:00/00:00:00:00:00/40 tag 2 ncq dma 4096 in [ 18.927636] res 41/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 18.927677] ata2.00: status: { DRDY ERR } [ 18.927710] ata2.00: error: { ABRT } [ 23.818734] ata2.00: failed to enable AA (error_mask=0x1) [ 26.865931] ata2.00: failed to get Log Directory Emask 0x1 [ 29.347253] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 37.619699] ata2.00: failed to enable AA (error_mask=0x1) [ 40.584111] ata2.00: failed to get Log Directory Emask 0x1 [ 43.191926] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 43.191929] ata2.00: configured for UDMA/133 (device error ignored) [ 43.191944] ata2: EH complete [ 43.205093] ata2.00: Enabling discard_zeroes_data [ 48.489537] ata2: failed to read log page 10h (errno=-5) [ 48.489573] ata2.00: NCQ disabled due to excessive errors [ 48.489575] ata2.00: exception Emask 0x1 SAct 0x10 SErr 0x0 action 0x0 [ 48.489610] ata2.00: irq_stat 0x40000001 [ 48.489644] ata2.00: failed command: READ FPDMA QUEUED [ 48.489681] ata2.00: cmd 60/08:20:00:00:00/00:00:00:00:00/40 tag 4 ncq dma 4096 in [ 48.489681] res 41/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 48.489722] ata2.00: status: { DRDY ERR } [ 48.489760] ata2.00: error: { ABRT } [ 52.841119] ata2.00: failed to enable AA (error_mask=0x1) [ 52.928427] ata2.00: failed to get Log Directory Emask 0x1 [ 53.232110] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 55.571414] ata2.00: failed to enable AA (error_mask=0x1) [ 56.398928] ata2.00: failed to get Log Directory Emask 0x1 [ 58.273812] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 58.273815] ata2.00: configured for UDMA/133 (device error ignored) [ 58.273828] ata2: EH complete [ 60.854110] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 60.854154] ata2.00: irq_stat 0x40000001 [ 60.854193] ata2.00: failed command: READ DMA [ 60.854234] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 22 dma 4096 in [ 60.854234] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 60.854289] ata2.00: status: { DRDY ERR } [ 60.854327] ata2.00: error: { ABRT } [ 63.249316] ata2.00: failed to enable AA (error_mask=0x1) [ 63.548272] ata2.00: failed to get Log Directory Emask 0x1 [ 63.711722] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 64.770564] ata2.00: failed to enable AA (error_mask=0x1) [ 64.839050] ata2.00: failed to get Log Directory Emask 0x1 [ 64.897732] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 64.897735] ata2.00: configured for UDMA/133 (device error ignored) [ 64.897748] ata2: EH complete [ 65.177107] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 65.177147] ata2.00: irq_stat 0x40000001 [ 65.177185] ata2.00: failed command: READ DMA [ 65.177225] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 23 dma 4096 in [ 65.177225] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 65.177279] ata2.00: status: { DRDY ERR } [ 65.177316] ata2.00: error: { ABRT } [ 66.108741] ata2.00: failed to enable AA (error_mask=0x1) [ 66.472860] ata2.00: failed to get Log Directory Emask 0x1 [ 68.587025] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 70.801023] ata2.00: failed to enable AA (error_mask=0x1) [ 72.331933] ata2.00: failed to get Log Directory Emask 0x1 [ 72.819403] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 72.819406] ata2.00: configured for UDMA/133 (device error ignored) [ 72.819419] ata2: EH complete [ 73.321106] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 73.321146] ata2.00: irq_stat 0x40000001 [ 73.321184] ata2.00: failed command: READ DMA [ 73.321224] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 24 dma 4096 in [ 73.321224] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 73.321279] ata2.00: status: { DRDY ERR } [ 73.321316] ata2.00: error: { ABRT } [ 74.158237] ata2.00: failed to enable AA (error_mask=0x1) [ 74.922513] ata2.00: failed to get Log Directory Emask 0x1 [ 75.474763] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 78.083653] ata2.00: failed to enable AA (error_mask=0x1) [ 78.586504] ata2.00: failed to get Log Directory Emask 0x1 [ 79.087432] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 79.087435] ata2.00: configured for UDMA/133 (device error ignored) [ 79.087448] ata2: EH complete [ 79.544105] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 79.544144] ata2.00: irq_stat 0x40000001 [ 79.544182] ata2.00: failed command: READ DMA [ 79.544222] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 25 dma 4096 in [ 79.544222] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 79.544277] ata2.00: status: { DRDY ERR } [ 79.544314] ata2.00: error: { ABRT } [ 83.234211] ata2.00: failed to enable AA (error_mask=0x1) [ 83.574308] ata2.00: failed to get Log Directory Emask 0x1 [ 83.878648] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 86.676831] ata2.00: failed to enable AA (error_mask=0x1) [ 87.269850] ata2.00: failed to get Log Directory Emask 0x1 [ 87.680971] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 87.680974] ata2.00: configured for UDMA/133 (device error ignored) [ 87.680990] sd 1:0:0:0: [sdb] tag#25 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 87.680993] sd 1:0:0:0: [sdb] tag#25 Sense Key : Illegal Request [current] [ 87.680996] sd 1:0:0:0: [sdb] tag#25 Add. Sense: Unaligned write command [ 87.681000] sd 1:0:0:0: [sdb] tag#25 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 87.681014] blk_update_request: I/O error, dev sdb, sector 0 [ 87.681054] Buffer I/O error on dev sdb, logical block 0, async page read [ 87.681098] ata2: EH complete [ 88.247049] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 88.247089] ata2.00: irq_stat 0x40000001 [ 88.247126] ata2.00: failed command: READ DMA [ 88.247166] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 26 dma 4096 in [ 88.247166] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 88.247222] ata2.00: status: { DRDY ERR } [ 88.247258] ata2.00: error: { ABRT } [ 90.175382] ata2.00: failed to enable AA (error_mask=0x1) [ 90.556796] ata2.00: failed to get Log Directory Emask 0x1 [ 91.431298] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 94.895635] ata2.00: failed to enable AA (error_mask=0x1) [ 97.725086] ata2.00: failed to get Log Directory Emask 0x1 [ 99.748702] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 99.748705] ata2.00: configured for UDMA/133 (device error ignored) [ 99.748718] ata2: EH complete [ 102.443111] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 102.443151] ata2.00: irq_stat 0x40000001 [ 102.443189] ata2.00: failed command: READ DMA [ 102.443229] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 27 dma 4096 in [ 102.443229] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 102.443284] ata2.00: status: { DRDY ERR } [ 102.443321] ata2.00: error: { ABRT } [ 107.362437] ata2.00: failed to enable AA (error_mask=0x1) [ 110.155674] ata2.00: failed to get Log Directory Emask 0x1 [ 112.016021] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 114.195136] ata2.00: failed to enable AA (error_mask=0x1) [ 114.599967] ata2.00: failed to get Log Directory Emask 0x1 [ 115.056393] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 115.056396] ata2.00: configured for UDMA/133 (device error ignored) [ 115.056409] ata2: EH complete [ 115.167107] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 115.167147] ata2.00: irq_stat 0x40000001 [ 115.167184] ata2.00: failed command: READ DMA [ 115.167224] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 28 dma 4096 in [ 115.167224] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 115.167279] ata2.00: status: { DRDY ERR } [ 115.167316] ata2.00: error: { ABRT } [ 115.586820] ata2.00: failed to enable AA (error_mask=0x1) [ 115.777539] ata2.00: failed to get Log Directory Emask 0x1 [ 116.085981] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 121.464289] ata2.00: failed to enable AA (error_mask=0x1) [ 124.249129] ata2.00: failed to get Log Directory Emask 0x1 [ 127.208265] ata2.00: failed to get Identify Device Data, Emask 0x1 [ 127.208268] ata2.00: configured for UDMA/133 (device error ignored) [ 127.208281] ata2: EH complete [ 129.368108] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 [ 129.368149] ata2.00: irq_stat 0x40000001 [ 129.368187] ata2.00: failed command: READ DMA [ 129.368226] ata2.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 29 dma 4096 in [ 129.368226] res 51/04:00:00:00:00/00:00:00:00:00/60 Emask 0x1 (device error) [ 129.368281] ata2.00: status: { DRDY ERR } [ 129.368318] ata2.00: error: { ABRT } [ 131.075137] ata2.00: failed to enable AA (error_mask=0x1) [ 136.160085] ata2.00: qc timeout (cmd 0x2f) [ 136.160096] ata2.00: failed to get Log Directory Emask 0x5 [ 136.160097] ata2.00: failed to get Identify Device Data, Emask 0x40 [ 136.160101] ata2.00: failed to set xfermode (err_mask=0x40) [ 136.160143] ata2: hard resetting link [ 136.470587] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 141.792060] ata2.00: qc timeout (cmd 0xec) [ 141.792071] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4) [ 141.792072] ata2.00: revalidation failed (errno=-5) [ 141.792112] ata2: limiting SATA link speed to 1.5 Gbps [ 141.792114] ata2: hard resetting link [ 142.102637] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 152.544078] ata2.00: qc timeout (cmd 0xec) [ 152.544089] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4) [ 152.544090] ata2.00: revalidation failed (errno=-5) [ 152.544128] ata2.00: disabled [ 152.544138] ata2: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x6 frozen t4 [ 152.544183] ata2: SError: { HostInt } [ 152.544220] ata2: hard resetting link [ 152.854491] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 152.854499] ata2: EH complete [ 152.854508] sd 1:0:0:0: [sdb] tag#30 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854511] sd 1:0:0:0: [sdb] tag#30 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854512] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854551] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854628] sd 1:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854632] sd 1:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854634] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854674] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854728] ldm_validate_partition_table(): Disk read failed. [ 152.854756] sd 1:0:0:0: [sdb] tag#1 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.854759] sd 1:0:0:0: [sdb] tag#1 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00 [ 152.854760] blk_update_request: I/O error, dev sdb, sector 0 [ 152.854799] Buffer I/O error on dev sdb, logical block 0, async page read [ 152.854852] sdb: unable to read partition table [ 152.855081] sd 1:0:0:0: [sdb] Read Capacity(16) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.855083] sd 1:0:0:0: [sdb] Sense not available. [ 152.855144] sd 1:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 152.855146] sd 1:0:0:0: [sdb] Sense not available. [ 152.855324] sd 1:0:0:0: [sdb] Attached SCSI disk [ 154.221502] sd 1:0:0:0: [sdb] tag#25 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 154.221508] sd 1:0:0:0: [sdb] tag#25 CDB: ATA command pass through(16) 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00 [ 162.361298] sd 1:0:0:0: [sdb] tag#29 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 162.361304] sd 1:0:0:0: [sdb] tag#29 CDB: ATA command pass through(16) 85 06 20 00 00 00 00 00 00 00 00 00 00 40 e6 00 [ 162.361321] sd 1:0:0:0: [sdb] tag#30 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 162.361323] sd 1:0:0:0: [sdb] tag#30 CDB: ATA command pass through(16) 85 06 20 00 00 00 00 00 00 00 00 00 00 40 99 00
