Текущее время: 21 ноя 2026, 04:27
 Заголовок сообщения: Windows 11 Disk no boot - error 87 DISM check health
СообщениеДобавлено: 18 окт 2025, 08:31
I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11.
I use a bootable USB flash drive and I boot in Windows repair mode and I run the below command in cmd:
DISM.exe /Online /Cleanup-image /Restorehealth
After run the DISM.... command shows me the error 87 at the attached picture. I run also the sfc /scannow command and chkdsk but the problem not solved. Any ideas how to repair my disk and avoid the format?
Последний раз редактировалось Spongebob89 18 окт 2025, 09:35, всего редактировалось 1 раз.
 Заголовок сообщения: Re: error 87 DISM check health in Windows 11
СообщениеДобавлено: 18 окт 2025, 08:40
Boot from the installation disk.
Run the following commands
bootrec /FixBoot
bootrec /ScanOs
bootrec /RebuildBcd (if mbr)
СообщениеДобавлено: 18 окт 2025, 09:11
Thanks for your reply.
I boot from the installation USB stick and I run the commands you told me in cmd but the problem didn't solved... Again I saw the message (Reboot and select a proper Boot device).
For some reason it writes(Total identified installations 0) like there no windows in the nvme disk.
What else I can try?
 Заголовок сообщения: Re: Windows 11 Disk no boot - error 87 DISM check health
СообщениеДобавлено: 18 окт 2025, 18:18
Boot from Windows PE.
What's on the Windows partition?
Are the files accessible?
СообщениеДобавлено: 18 окт 2025, 19:03
I am not an expert but the problem maybe is the missing of the windows boot folder? My disk have only two volumes as you can see at the attached pictures. One is the main partition where have the windows and my files and the other volume is the recovery partition. I don't see the system partition with the boot files? Am I correct and if yes how can I create the system partition with the boot files?
СообщениеДобавлено: 19 окт 2025, 00:58
Finally I solved the problem by creating the system partition with the boot files.
Windows Can't Boot | Missing EFI Partition
https://www.youtube.com/watch?v=Mzloza_2g_c
В этой теме нет новых непрочитанных сообщений. Где скачать Live Disk WinPE 10-8 Sergei Strelec с прогаммой Dism++
в форуме Программное обеспечение | Software
lomess
25 мар 2023, 05:03
lomess Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 12Tb WDC WD120EMFZ-11A6JA0 Data error (cyclic redundancy check)
izhyrnyy
10
2197
11 сен 2024, 13:12
В этой теме нет новых непрочитанных сообщений. SMART Hard Disk Error !!
battery13v
02 фев 2020, 10:07
slava-yun Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. SSD MyMedia 256GB SM2258XT 0% health после восстановления прошивки
в форуме Ремонт SSD | SSD repair and data recovery
miant
25 фев 2024, 17:20
miant Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. hp 4535s (6050A2436501-MB-A03) need bios or check dump
notemaster
12 дек 2016, 22:11
hardhaker Перейти к последнему сообщению
