smartctl 6.4 2014-10-07 r4002 [x86_64-linux-3.16.0-4-amd64] (local build)
2 Copyright (C) 2002-14, Bruce Allen, Christian Franke,
http://www.smartmontools.org3
4 === START OF INFORMATION SECTION ===
5 Device Model: INTEL SSDSC2BB240G7
6 Firmware Version: N2010101
7 User Capacity: 240.057.409.536 bytes [240 GB]
8 Sector Sizes: 512 bytes logical, 4096 bytes physical
9 Rotation Rate: Solid State Device
10 Form Factor: 2.5 inches
11 Device is: Not in smartctl database [for details use: -P showall]
12 ATA Version is: ACS-3 T13/2161-D revision 5
13 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
14 Local Time is: Sun Oct 16 01:07:56 2016 CEST
15 SMART support is: Available - device has SMART capability.
16 SMART support is: Enabled
17 AAM feature is: Unavailable
18 APM feature is: Unavailable
19 Rd look-ahead is: Enabled
20 Write cache is: Enabled
21 ATA Security is: Disabled, frozen [SEC2]22 Wt Cache Reorder: Enabled
23
24 === START OF READ SMART DATA SECTION ===
25 SMART overall-health self-assessment test result: PASSED
26
27 General SMART Values:
28 Offline data collection status: (0x02) Offline data collection activity
29 was completed without error.
30 Auto Offline Data Collection: Disabled.
31 Self-test execution status: ( 0) The previous self-test routine completed
32 without error or no self-test has ever
33 been run.
34 Total time to complete Offline
35 data collection: ( 2) seconds.
36 Offline data collection
37 capabilities: (0x79) SMART execute Offline immediate.
38 No Auto Offline data collection support.
39 Suspend Offline collection upon new
40 command.
41 Offline surface scan supported.
42 Self-test supported.
43 Conveyance Self-test supported.
44 Selective Self-test supported.
45 SMART capabilities: (0x0003) Saves SMART data before entering
46 power-saving mode.
47 Supports SMART auto save timer.
48 Error logging capability: (0x01) Error logging supported.
49 General Purpose Logging supported.
50 Short self-test routine
51 recommended polling time: ( 1) minutes.
52 Extended self-test routine
53 recommended polling time: ( 2) minutes.
54 Conveyance self-test routine
55 recommended polling time: ( 2) minutes.
56 SCT capabilities: (0x003d) SCT Status supported.
57 SCT Error Recovery Control supported.
58 SCT Feature Control supported.
59 SCT Data Table supported.
60
61 SMART Attributes Data Structure revision number: 1
62 Vendor Specific SMART Attributes with Thresholds:
63 ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
64 5 Reallocated_Sector_Ct -O--CK 100 100 000 - 0
65 9 Power_On_Hours -O--CK 100 100 000 - 35
66 12 Power_Cycle_Count -O--CK 100 100 000 - 15
67 170 Unknown_Attribute PO--CK 100 100 010 - 0
68 171 Unknown_Attribute -O--CK 100 100 000 - 0
69 172 Unknown_Attribute -O--CK 100 100 000 - 0
70 174 Unknown_Attribute -O--CK 100 100 000 - 5
71 175 Program_Fail_Count_Chip PO--CK 100 100 010 - 68727027906
72 183 Runtime_Bad_Block -O--CK 100 100 000 - 0
73 184 End-to-End_Error PO--CK 100 100 090 - 0
74 187 Reported_Uncorrect -O--CK 100 100 000 - 0
75 190 Airflow_Temperature_Cel -O---K 076 075 000 - 24 (Min/Max 21/25)
76 192 Power-Off_Retract_Count -O--CK 100 100 000 - 5
77 194 Temperature_Celsius -O---K 100 100 000 - 24
78 197 Current_Pending_Sector -O--C- 100 100 000 - 0
79 199 UDMA_CRC_Error_Count -OSRCK 100 100 000 - 0
80 225 Unknown_SSD_Attribute -O--CK 100 100 000 - 574
81 226 Unknown_SSD_Attribute -O--CK 100 100 000 - 0
82 227 Unknown_SSD_Attribute -O--CK 100 100 000 - 59
83 228 Power-off_Retract_Count -O--CK 100 100 000 - 2039
84 232 Available_Reservd_Space PO--CK 100 100 010 - 0
85 233 Media_Wearout_Indicator -O--CK 100 100 000 - 0
86 234 Unknown_Attribute -O--CK 100 100 000 - 0
87 241 Total_LBAs_Written -O--CK 100 100 000 - 574
88 242 Total_LBAs_Read -O--CK 100 100 000 - 833
89 243 Unknown_Attribute -O--CK 100 100 000 - 1023
90 ||||||_ K auto-keep
91 |||||__ C event count
92 ||||___ R error rate
93 |||____ S speed/performance
94 ||_____ O updated online
95 |______ P prefailure warning
96
97 General Purpose Log Directory Version 1
98 SMART Log Directory Version 1 [multi-sector log support]
99 Address Access R/W Size Description
100 0x00 GPL,SL R/O 1 Log Directory
101 0x01 GPL,SL R/O 1 Summary SMART error log
102 0x02 GPL,SL R/O 8 Comprehensive SMART error log
103 0x03 GPL,SL R/O 20 Ext. Comprehensive SMART error log
104 0x04 GPL,SL R/O 8 Device Statistics log
105 0x06 GPL,SL R/O 1 SMART self-test log
106 0x07 GPL,SL R/O 2 Extended self-test log
107 0x08 GPL,SL R/O 2 Power Conditions log
108 0x09 GPL,SL R/W 1 Selective self-test log
109 0x10 GPL,SL R/O 1 SATA NCQ Queued Error log
110 0x11 GPL,SL R/O 1 SATA Phy Event Counters log
111 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
112 0x80-0x9f GPL,SL R/W 16 Host vendor specific log
113 0xb0 GPL,SL VS 1 Device vendor specific log
114 0xb1 GPL,SL VS 33 Device vendor specific log
115 0xb8 GPL,SL VS 1 Device vendor specific log
116 0xb9 GPL VS 1704 Device vendor specific log
117 0xb9 SL VS 168 Device vendor specific log
118 0xba GPL VS 1280 Device vendor specific log
119 0xdf GPL,SL VS 1 Device vendor specific log
120 0xe0 GPL,SL R/W 1 SCT Command/Status
121 0xe1 GPL,SL R/W 8 SCT Data Transfer
122
123 SMART Extended Comprehensive Error Log Version: 1 (20 sectors)
124 No Errors Logged
125
126 SMART Extended Self-test Log Version: 1 (2 sectors)
127 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
128 # 1 Short offline Completed without error 00% 9 -
129 # 2 Short offline Completed without error 00% 4 -
130
131 SMART Selective self-test log data structure revision number 1
132 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
133 1 0 0 Not_testing
134 2 0 0 Not_testing
135 3 0 0 Not_testing
136 4 0 0 Not_testing
137 5 0 0 Not_testing
138 Selective self-test flags (0x0):
139 After scanning selected spans, do NOT read-scan remainder of disk.
140 If Selective self-test is pending on power-up, resume after 0 minute delay.
141
142 SCT Status Version: 3
143 SCT Version (vendor specific): 1 (0x0001)
144 SCT Support Level: 0
145 Device State: Active (0)
146 Current Temperature: 24 Celsius
147 Power Cycle Min/Max Temperature: 21/25 Celsius
148 Lifetime Min/Max Temperature: 21/29 Celsius
149 Under/Over Temperature Limit Count: 0/0
150 Vendor specific:
151 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00
152 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
153
154 SCT Temperature History Version: 2
155 Temperature Sampling Period: 1 minute
156 Temperature Logging Interval: 1 minute
157 Min/Max recommended Temperature: 0/70 Celsius
158 Min/Max Temperature Limit: 0/70 Celsius
159 Temperature History Size (Index): 478 (210)
160
161 Index Estimated Time Temperature Celsius
162 211 2016-10-15 17:10 27 ********
163 ... ..(121 skipped). .. ********
164 333 2016-10-15 19:12 27 ********
165 334 2016-10-15 19:13 28 *********
166 ... ..(141 skipped). .. *********
167 476 2016-10-15 21:35 28 *********
168 477 2016-10-15 21:36 27 ********
169 ... ..( 26 skipped). .. ********
170 26 2016-10-15 22:03 27 ********
171 27 2016-10-15 22:04 26 *******
172 ... ..( 39 skipped). .. *******
173 67 2016-10-15 22:44 26 *******
174 68 2016-10-15 22:45 ? -
175 69 2016-10-15 22:46 26 *******
176 ... ..( 15 skipped). .. *******
177 85 2016-10-15 23:02 26 *******
178 86 2016-10-15 23:03 25 ******
179 ... ..( 7 skipped). .. ******
180 94 2016-10-15 23:11 25 ******
181 95 2016-10-15 23:12 ? -
182 96 2016-10-15 23:13 22 ***
183 97 2016-10-15 23:14 22 ***
184 98 2016-10-15 23:15 23 ****
185 99 2016-10-15 23:16 23 ****
186 100 2016-10-15 23:17 24 *****
187 ... ..( 7 skipped). .. *****
188 108 2016-10-15 23:25 24 *****
189 109 2016-10-15 23:26 25 ******
190 ... ..( 65 skipped). .. ******
191 175 2016-10-16 00:32 25 ******
192 176 2016-10-16 00:33 24 *****
193 ... ..( 33 skipped). .. *****
194 210 2016-10-16 01:07 24 *****
195
196 SCT Error Recovery Control:
197 Read: Disabled
198 Write: Disabled
199
200 Device Statistics (GP Log 0x04)
201 Page Offset Size Value Description
202 1 ===== = = == General Statistics (rev 2) ==
203 1 0x008 4 15 Lifetime Power-On Resets
204 1 0x018 6 37620022 Logical Sectors Written
205 1 0x020 6 2048153 Number of Write Commands
206 1 0x028 6 54608634 Logical Sectors Read
207 1 0x030 6 2258048 Number of Read Commands
208 4 ===== = = == General Errors Statistics (rev 1) ==
209 4 0x008 4 0 Number of Reported Uncorrectable Errors
210 4 0x010 4 0 Resets Between Cmd Acceptance and Completion
211 5 ===== = = == Temperature Statistics (rev 1) ==
212 5 0x008 1 24 Current Temperature
213 5 0x010 1 26 Average Short Term Temperature
214 5 0x018 1 - Average Long Term Temperature
215 5 0x020 1 28 Highest Temperature
216 5 0x028 1 24 Lowest Temperature
217 5 0x030 1 27 Highest Average Short Term Temperature
218 5 0x038 1 26 Lowest Average Short Term Temperature
219 5 0x040 1 - Highest Average Long Term Temperature
220 5 0x048 1 - Lowest Average Long Term Temperature
221 5 0x050 4 0 Time in Over-Temperature
222 5 0x058 1 70 Specified Maximum Operating Temperature
223 5 0x060 4 0 Time in Under-Temperature
224 5 0x068 1 0 Specified Minimum Operating Temperature
225 6 ===== = = == Transport Statistics (rev 1) ==
226 6 0x008 4 298 Number of Hardware Resets
227 6 0x010 4 128 Number of ASR Events
228 6 0x018 4 0 Number of Interface CRC Errors
229 7 ===== = = == Solid State Device Statistics (rev 1) ==
230 7 0x008 1 0 Percentage Used Endurance Indicator
231
232 SATA Phy Event Counters (GP Log 0x11)
233 ID Size Value Description
234 0x0001 4 0 Command failed due to ICRC error
235 0x0003 4 0 R_ERR response for device-to-host data FIS
236 0x0004 4 0 R_ERR response for host-to-device data FIS
237 0x0006 4 0 R_ERR response for device-to-host non-data FIS
238 0x000a 4 4 Device-to-host register FISes sent due to a COMRESET
239 0x000b 4 0 CRC errors within host-to-device FIS
240 0x000d 4 0 Non-CRC errors within host-to-device FIS
