BATPRB SMBIOS Viewer
Displays all data fields for the following SMBIOS tables:
· Entry point
· BIOS Information
· System Information
· Baseboard/Module Information
· System Enclosure/Chassis
· Processor Information
· Cache Information
· Port Connector Information
· System Slots
· OEM Strings
· System Configuration Options
· BIOS Language Information
· Physical Memory Array
· Memory device
· Portable Battery
· Voltage Probe
· Cooling Device
· Temperature Probe
· Electrical Current Probe
· System Boot Information
· Management Device
· Management Device Component
· Management Device Threshold Data
· System Power Supply
· Displays all data using official specification field names and values in UTF-16 ANSI
· Import and export SMBIOS data in binary or UTF-16 format
· User-interface support for 35 different selectable languages with tooltips
· Requires no additional software or O/S modifications other than Shell 4.71 or higher
· Does not require Windows Management Intrumentation
· Highly detailed 3D 32-bit color icons
