Acer a715 (compal) Gpu nvidia not detect https://vlab.su/viewtopic.php?f=4&t=117682 |
zvonko72 [ 29 июл 2021, 20:45 ] | ||||
Заголовок сообщения: | Acer a715 (compal) Gpu nvidia not detect | |||
I have a problem with the acer a715-71g,windows 10 Does not recognize gpu nvidia gtx 1050 Works only on intel hd 630 I flashed the bios but I still don't see the gpu I tried the drivers but it immediately reports an error i think it's up to the hardware Some help, where could I check if everything is OK?
Flagmans [ 29 июл 2021, 22:01 ] | |
Заголовок сообщения: | Re: Acer a715 (compal) Gpu nvidia not detect |
Somewhere in forum I have read, that helped to someone to update official BIOS to newest version. Try this. If won't help, then disassemble and check hardware. Then must check does GPU have power. And how this problem appeared? Just stopped recognizing, or it was switched to UMA by someone before? |
zvonko72 [ 30 июл 2021, 17:52 ] | |
Заголовок сообщения: | Re: Acer a715 (La-e911pl) Gpu nvidia not detect |
Bios is the latest Power supply comes to gpu inductor |
zvonko72 [ 31 июл 2021, 19:21 ] | |
Pl1502 Pl1503 Vga core voltage is coming |
