Заголовок сообщения: Laptop goes off approximately 30 mins
Добавлено: 22 авг 2014, 23:58
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 28.00 Сообщения: 199 Откуда: Ghana
Hi everyone, I've been having some laptops coming in [Toshiba , Hp , Lenovo] with a peculiar problem of power cutting off approximately 30mins, whether the laptop is booted into windows or without an hdd installed or whether on battery or adapter or both. There are no signs of heating and the motherboards are clean. I wonder if anyone has experienced this issue.
RsM
Заголовок сообщения: Re: Laptop goes off approximately 30 mins
Добавлено: 23 авг 2014, 13:19
Модератор
Зарегистрирован: 12 окт 2012, 21:53 Наличности на руках: 5,126.83 Сообщения: 8292 Откуда: Сыктывкар
If these laptops on Intel - than you should know which PCH (chipset) is installed - HM55/65 Also you should write models of laptops.
