Заголовок сообщения: asus r510dp (x750dp) it8528e problem
Добавлено: 06 янв 2016, 12:50
Зарегистрирован: 04 фев 2015, 12:59 Наличности на руках: 10.00 Сообщения: 5 Откуда: romania
hi all. i have an asus r510dp with mb: x750dp rev:2.0 with burned IT8528e, i replaced this ic with new one and now when i plug power cord laptop make a power cicle, one led lights out but no image, no cooler activity, when i press power button it doesn't make anyting. if i put battery on mb no led, no power cicle. on bios is on pin 1 i have nothing, only on pin 3 i have 3.3 v
anybody know what could be the problem? i read somewhere that it8528e must be programed but i do not have dump and i don't how how to do that, i have an ch342a usb programer but i don't reprogramed this king of ic by now.
swansic
Заголовок сообщения: Re: asus r510dp (x750dp) it8528e problem
Добавлено: 06 янв 2016, 15:00
Зарегистрирован: 29 мар 2011, 15:27 Наличности на руках: 5,403.54 Сообщения: 1853 Откуда: Кишинёв
You are wrong. IT8528E hasn"t Internal Flash Memory. It is not necessary to program.
andromedax
Добавлено: 06 янв 2016, 22:12
Зарегистрирован: 01 май 2015, 00:34 Наличности на руках: 3.60 Сообщения: 262 Откуда: Alicante, Spain
As you can see in the following link, flash memory is very close, but not inside.
Сейчас этот форум просматривают: Yandex [BOT] и гости: 48
