Текущее время: 16 июн 2024, 21:16
 Заголовок сообщения: ASUS (LA-8224P) NOT CHARGING
СообщениеДобавлено: 01 фев 2016, 02:37
Заблокирован
Hi every one
I have ASUS K45VD LA-8224p rev1.0
This laptop have charging issue
The laptop show me " plugged in charging " but not charge and the amount of present not go up only on 31%
The battery with ac adapter is discharging fine but not charge
This work I tried
1-change adapter with new one
2-change battery whit new one
3-bios update
4-the SMCA,SMDA is ok(3.3v) but a pin on battery connector named TS A ( I don't know this signal)have 0.26 v but when I disconnect the battery give 3.3 v fine
5-resolder SIO
6-the charger ic have (LODRV , REGN) high (3.3v)
7-i use method that uninstall the battery driver on OS and the restart …….
But not help
Please help me in advance please
 Заголовок сообщения: Re: ASUS (LA-8224P) NOT CHARGING
СообщениеДобавлено: 01 фев 2016, 11:56
Check up BQ24725 (PU101). And all that round it. Scheme page 44.
download/file.php?id=30947
СообщениеДобавлено: 01 фев 2016, 13:17
Заблокирован
hi
i change bq24725 but not help ... all round this ic seem ok
СообщениеДобавлено: 01 фев 2016, 15:21
Check with oscilloscope data exchange between battery and multicontroller. Then if impulse is present check where lost your charging dc voltage. 2-3 times this malfunction is from malfunction capacitor in circuit output mosfet wich charging battery and few times malfunction is multicontroller.
СообщениеДобавлено: 01 фев 2016, 16:37
Заблокирован
thanks for your fast reply
i have oscilloscope 50MHZ
but what do you mean from multi controller ?? and what is the signal name you told me to check ?
can you help me from shematic ? this is shematic
Posted after 3 hours 39 minutes 35 seconds:
hi i check the bq24725 again cefully i mistake that voltage in older post
this new test are (REGN=6) is ok now but the HIDRV=0
is that good or missing voltage ??
СообщениеДобавлено: 02 фев 2016, 00:22
You use an original battery, or Chinese (fake)?
СообщениеДобавлено: 02 фев 2016, 01:25
Заблокирован
i think battery not orginal but i test this battery with another laptop and working fine
a thing
when i plug battery and then connect 19.5v DC from source DC supply i see the laptop for 3 second use about 5.3A current
like laptop board shorted .... and then current go fine about 0.78 '
i think this may help you to help me solve this problem
thanks
В этой теме нет новых непрочитанных сообщений. E5-571 (LA-B161P) not charging not switch with battery
erdi34
06 окт 2018, 20:25
t.tashbaev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo legion y540 (nm-c371) Not charging not switch on..
pcexpert8
29 дек 2022, 20:12
Yariy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus K45VD (Compal LA-8224P) ищу dump EC
radiolab
20 мар 2015, 14:38
radiolab Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus k45vd (LA-8224P) не включается
Ivanches
11 дек 2019, 12:08
Ivanches Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 15 Gaming (LA-E992P) not charging
в форуме Dell
BalkanBoy
23 авг 2019, 21:52
BalkanBoy Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 35
