Текущее время: 03 июн 2024, 08:10
 Заголовок сообщения: Asus F541UA (X541UVK rev 2.0) spilled coffee wont boot
СообщениеДобавлено: 13 окт 2020, 04:30
after a lot of ic replacements and good cleaning i have this results:
18.70 AC_BAT_SYS
5.00 3.00 +5VAO +3VAO
3.20 +3VA_EC
3.20 EC_RST#
3.25 3.25 +3VADSW_ON +5VSUS_ON
3.23 +3VA_DSW_PWRGD
3.24 DPWROK_EC
3.34 PM_SLP_SUS#
3.25 VSUS_ON
3.25 3SUS_PWRGD
3.34 SUSWARN
2.94 PM_RSMRST#_PCH
3.04 ME_PRESENT_PCH
3.25 PCH_SUSACK#
3.22 PM_PWRBTN# PWR_SW#
3.34 PM_SUSC#
3.34 PM_SUSB#
3.24 SUSC_EC# 1.2V_ON
3.24 SUSB_EC#
3.31 ALL_SYS_PWRGD
3.30 IMPVP8_PWRGD
3.25 PM_PWROK_PCH
3.24 PM_SYSPWROK_PCH
1.00 H_CPUPWRGD_R
3.34 PLT_RST#
12.51 P_CHG_LX_30
1.20 +1.2VO
5.05 +5VSUSO
3.34 +3VADSWO
0.98 +VCCCORE
0.00 +VCCGT
1.00 +1.0VSUSO
0.00 +NVDD
0.00 +FBVDDQO
with his original bios dump i had white light on power led and orange light on charger led all time, i disabled onboard ram and still the same, i changed bios dump and with version 308 i had white light on power led and charge led blinking white colour once. with version 307 (i have only black screen without backlight or anything else) without ram on slot i have power led white and charger led blinking 2 times white(it recognize that ram is missing). when i install ram on slot i have white led on power led and orange on charge led. i also replaced ncp cpu ic. any ideas?
 Заголовок сообщения: Re: Asus F541UA (X541UVK rev 2.0) spilled coffee wont boot
СообщениеДобавлено: 13 окт 2020, 13:35
How much does it consume from LPS? Before pressing the button and after.
Не всегда говори то что знаешь, но всегда знай что говоришь.
СообщениеДобавлено: 13 окт 2020, 15:40
It consumes aproximately 0.400A - 0.600A ,it also turns on automatically keyboard is dead and i cant use pbutton,i can use the jumper if you want
СообщениеДобавлено: 23 апр 2021, 17:00
a customer bring me a same laptop and the problem was a mosfet next to the dcjack, so i compared with my old motherboard and the only difference is that my motherboard doesnt do ec reset, the working motherboard also doesnt open vccgt coil but it works ok.
клиент принес мне тот же ноутбук, и проблема была в mosfet рядом с dcjack, поэтому я сравнил со своей старой материнской платой, и единственная разница в том, что моя материнская плата не выполняет сброс ec, рабочая материнская плата также не открывает катушку vccgt, но работает нормально .
СообщениеДобавлено: 23 апр 2021, 17:28
kosmo555 писал(а):
3.20 EC_RST#
So, does, or doesn't? Whatever, if EC don't pull down own reset, your board will not turn on. Look at POST codes.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus (X541uvk) Asus x541uvk rev.2 ищу биос с отключеной оперативкой
mukapotap
11 окт 2018, 10:59
mukapotap Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X541UVK (Asus X541UVK rev 2.0) Некорректно работает с жесткими дисками
chdim
06 фев 2020, 14:23
Alex.Bu Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus x541uvk (asus x541uvk rev2.0) При работе от батареи сбрасывается БИОС
Alyes
13
2938
10 ноя 2019, 16:25
Boglen Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 15-p210NE (DAY16EMB8C0 REV:C) Spilled milk And Wash It
farzad120
15 мар 2017, 19:25
farzad120 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Запуск Coffee Lake на z170
skorodumov18rus
15 ноя 2019, 12:50
skorodumov18rus Перейти к последнему сообщению
Сейчас этот форум просматривают: 787 и гости: 55
