Текущее время: 01 июл 2024, 05:31
andromedax
Заголовок сообщения: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 апр 2020, 21:23 |
![Начинающий Начинающий](./images/ranks/gemstone_ranks/grey/grey3.gif) |
Зарегистрирован: 01 май 2015, 00:34 Наличности на руках: 3.60 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 262 Откуда: Alicante, Spain
hi, have an ASUS ZenBook UX330UAK, none usb working, even usb-c.
If an usb keyboard or mouse is connected they are not recognized.
It can`t boot from any usb device, only with internal ssd.
On bios setup screen doesn't show any usb device connected.
There are 5 volts present in all connectors, and D+ have voltage too, but not in D-.
Diode mode readings in D+ and D- are .465
There are no protector chip, so cpu could be damaged.
Bios have been reprogrammed with a good dump, but cant reprogram kbc IT8995VG-128/DX.
What should i test now?
Thanks.
![](images/spacer.gif) |
Котеус
Заголовок сообщения: Re: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 03 апр 2020, 08:13 |
![Пользователь Пользователь](./images/ranks/gemstone_ranks/grey/grey4.gif) |
![Аватара пользователя](./download/file.php?avatar=49706_1465229520.jpg) |
Зарегистрирован: 19 янв 2016, 10:24 Наличности на руках: 754.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 638 Откуда: Eversong
andromedax писал(а): Diode mode readings in D+ and D- are .465 it actual for all ports? And data pins of usb 3.0? What about camera? It connected to usb line.
andromedax
Заголовок сообщения: Re: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 04 апр 2020, 15:19 |
Цитата: it actual for all ports? And data pins of usb 3.0? Yes, all usb2 have the same value, but usb3 and usb-c lines are a bit lower. (.346) Цитата: What about camera? It connected to usb line. Camera does not work either. As all those pins goes directly to cpu, seems that cpu are damaged, I think.
Котеус
Заголовок сообщения: Re: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 04 апр 2020, 20:15 |
System cant install/initialise driver for usb hub (maybe error of device)? Try to change CPU.
andromedax
Заголовок сообщения: Re: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 04 апр 2020, 20:29 |
Котеус писал(а): System cant install/initialise driver for usb hub (maybe error of device)? Try to change CPU. It is not a windows problem, can not boot from usb. (linux or any os) Also sd-card it is not recognized. Asus ezflash only "sees" ssd, so can't update bios from usb devices in bios set-up menu.
Котеус
Заголовок сообщения: Re: ASUS ZenBook (UX330UAK) usb not working ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 04 апр 2020, 21:33 |
You haven't Vertyanov JIG or another EC Programmer? What kind of ssd installed on this laptop? Can you connect it to working PC via sata/usb? Install windows on it and update bios under windows...
