Asus (X556UV REV:3.1) missing piece help ( hdd bord) https://vlab.su/viewtopic.php?f=40&t=106787 |
tarum2003 [ 11 сен 2020, 13:37 ] | |
Заголовок сообщения: | Asus (X556UV REV:3.1) missing piece help ( hdd bord) |
Hello friends.. Asus X556UV REV 3.1, Hdd no parts on the board I wonder what is the missing piece in the picture. Can you help with this |
Boglen [ 11 сен 2020, 14:21 ] | |
Заголовок сообщения: | Re: Asus (X556UV REV:3.1) missing piece help ( hdd bord) |
This is some kind of low resistor, probably installed on the DC input of the audio encoder. If there is no hard disk in the system, pay attention to the PFC connector. Connectors of this type are frequently damaged. |
tarum2003 [ 11 сен 2020, 20:38 ] | |
one side of the part has 5 volts, the other side has 0.26 volts |
