And_R писал(а):
Делитель на ACDET восстановил, вместо 127 кОм, сделал 120.
не корректно!
And_R писал(а):
6 acdet - 2,7
Adapter detection input. Program adapter valid input threshold by connecting a resistor divider from adapter
input to ACDET pin to GND pin. When ACDET pin is above 0.6 V and VCC is above UVLO, REGN LDO is
present, ACOK comparator, input current buffer (IADP), discharge current buffer (IDCHG), independent
comparator, and power monitor buffer (PMON) can be enabled with SMBus. When ACDET is above 2.4V, and
VCC is above SRN but below ACOV, ACOK goes HIGH.
Другими словами, на 6 пине должно быть 2,4в
