Asus FX506LH (Quanta BKXD) does not turn on https://vlab.su/viewtopic.php?f=40&t=139777 |
pcexpert8 [ 21 янв 2024, 22:34 ] | |
Заголовок сообщения: | Asus FX506LH (Quanta BKXD) does not turn on |
hi, i have issue with laptop ,power button 2.6v on coil 3.3v alw 0,7v on 5 alw 0v ,LDO is present 3v and 5v en 3v, +3VPCU_KBC is present ..I change new multicontroller same ..I could not flash multicontroller by vertyannov programmer ,also old one and new one..Maybe multicontroller new is fault,or I miss something more?Pch is 0.20ohm ..Thanks in advance |
ds.80 [ 22 янв 2024, 00:41 ] | |
Заголовок сообщения: | Re: Asus FX506LH (Quanta BKXD) does not turn on |
pcexpert8 писал(а): Pch is 0.20ohm Очень низкое сопротивление на питании PCH. pcexpert8 писал(а): 3.3v alw 0,7v это не нормально, искать причинуpcexpert8 писал(а): on 5 alw 0v это не нормально искать причинуЧто-то должно греться... |
pcexpert8 [ 22 янв 2024, 02:36 ] | |
No,short at all,I inject voltage,on lab power supply 20v 0.1A |
pcexpert8 [ 22 янв 2024, 11:38 ] | |
on PCH is 0.60 ohm ,i dont have 3 alw and 5w no short i change RT6575D sp_on is present +3vpcu is present.. |
ds.80 [ 22 янв 2024, 20:49 ] | |
check Y2 32.768KHz. check all PL and write here Ω, check LDO3 & LDO5 |
pcexpert8 [ 22 янв 2024, 21:37 ] | |
pl9-5 kohm pl10-1.2 kohm pl26-40ohm pl8-318ohm pl11-50kohm pl25-60ohm pl1205-22ohm pl1228-2.7ohm pl1227-2.7ohm pl1226-2.7ohm pl1326-7.5ohm pl12,13,14-0.9ohm pl15-158 ohm ldo3-55kohm ldo5-1kohm I dont have oscilloscope i cant test frequency |
pcexpert8 [ 25 янв 2024, 23:51 ] | |
Very strange,I have on coil 3.3alw(0.7v) but on power button 2.6v +0.7v=3.3v ,like liking voltage ,I can't understand why,I change multiconntroler.. |
