2021 ROG Zephyrus G15 GA503 ( GA503QS) no +3VSUS https://vlab.su/viewtopic.php?f=40&t=143007 |
pcexpert8 [ 01 июл 2024, 22:01 ] | |
Заголовок сообщения: | 2021 ROG Zephyrus G15 GA503 ( GA503QS) no +3VSUS |
Hi ,i have issue with board,does not present +3VSUS,should be after plug adapter ,+5vsus is present..I change new multicontroller ,also flash bios ..No short on the board ,cpu is fine..I folow power sequence but no result |
diavo2 [ 03 авг 2024, 16:07 ] | |
Заголовок сообщения: | Re: 2021 ROG Zephyrus G15 GA503 ( GA503QS) no +3VSUS |
just change the 3v controller and you will be happy |
code9523 [ 21 авг 2024, 14:57 ] | |
pcexpert8 писал(а): Hi ,i have issue with board,does not present +3VSUS,should be after plug adapter ,+5vsus is present..I change new multicontroller ,also flash bios ..No short on the board ,cpu is fine..I folow power sequence but no result зачем шить биос если нет дежурки? Для начала надо понять почему ее нет. |
pcexpert8 [ 11 сен 2024, 10:41 ] | |
Заголовок сообщения: | Re: 2021 ROG Zephyrus G15 GA503 ( GA503QS) no +3VSUS [РЕШЕНО] |
Multi controller I have change ,now is fine, working..Thanks. |
