k53SD (K53SD(Rev5.1)) Delay in boot https://vlab.su/viewtopic.php?f=40&t=21803 |
R EZ A [ 29 май 2014, 12:21 ] | |
Заголовок сообщения: | k53SD (K53SD(Rev5.1)) Delay in boot |
hi guys i have a board that when i press power button ,it turned on, restar 4time and not have display after 4 restart display turned on and boot up i update bios with easy flash ,but no change my board is Rev5.1 but i cant find bios file of this rev in site is file for rev 2.3&6 no problem to program them? what i should be do? tnx |
RsM [ 29 май 2014, 14:43 ] | |
Заголовок сообщения: | Re: k53SD (K53SD(Rev5.1)) Delay in boot |
USB 3.0 firmware.... search k54ly Or I can provide you by work fw for fee. |
R EZ A [ 29 май 2014, 15:51 ] | |
what?!?!?! can u explain more? i cant undrestan relation between and usb3 and turn on This should be interesting i want to learn more tnx |
R EZ A [ 31 май 2014, 12:55 ] | |
what i should be do?:( |
R EZ A [ 01 июн 2014, 15:46 ] | |
any help? how i should solve this problem??? i have still problem with bios programing K53SD rev2.3 not work k54ly not work |
unit1 [ 02 июн 2014, 00:30 ] | |
you must write two eproms RsM had written this for you |
R EZ A [ 02 июн 2014, 14:41 ] | |
Заголовок сообщения: | Re: k53SD (K53SD(Rev5.1)) Delay in boot [РЕШЕНО] |
ok thanks i program it viewtopic.php?f=252&t=13999&p=116399&hilit=%2Aasm1042%2A#p116399 work correct |
