Asus N551JW (windows) does not start https://vlab.su/viewtopic.php?f=40&t=82952 |
vasagob [ 15 ноя 2018, 21:26 ] | |
Заголовок сообщения: | Asus N551JW (windows) does not start [РЕШЕНО] |
Hi guys, I need your help please, I got this equipment when turning on, turn on the LEDs and the fan sounds, but it does not deliver any image on the screen and does it show any sign that it is the graphic card, I proceeded to disarm it and I find with a naked eye a burnt component where it is seen that they had already worked on the component and that is badly welded I can not access to the boardview for having few messages and please help me know what component is |
gofer [ 15 ноя 2018, 22:05 ] | |
Заголовок сообщения: | Re: Asus N551JW (windows) does not start |
PQ8801-P0903BEA |
vasagob [ 16 ноя 2018, 00:41 ] | |
very thanks Posted after 1 hour 1 minute 8 seconds: restore the zone because it was completely damaged but looking at a chinese forum in that they had a picture of the board I realized that this plate is missing 4 resistors and two capacitors i ask you please if you can tell me the values of these resistances Mark them with some red lines |
gofer [ 16 ноя 2018, 03:07 ] | |
Up to down: R4524 and R4523-0 ohm PC8805-1000p PR8801-1M ohm PR8818-4,7M ohm |
vasagob [ 16 ноя 2018, 04:04 ] | |
thanks bro, the laptop is repaired |
