https://vlab.su/
ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
https://vlab.su/viewtopic.php?f=40&t=98817
Страница 1 из 1
prospa [ 23 янв 2020, 16:34 ]
Заголовок сообщения:  ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
Hello if someone can tell which chip is USB 2.0 controller-hub on asus x541uvk 2.0 board because laptop working perfect except not recognize anything in usb 2.0 port only usb 3.0 devices on USB 3.0 port.
please inform about chip so i can replace it.
battery13v [ 23 янв 2020, 17:11 ]
Заголовок сообщения:  Re: ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
Is 5Volt Present on all usb ports ?
Usb Data is connected directly to the PCH/Bridge ... for every port you will find an IC with 8 legs... its responsible of conducting 5Volt to USBs .... check them
prospa [ 23 янв 2020, 20:12 ]
Yes i have 5volt on both usb port (1 x usb 2.0 and 1 x usb 3.0)
On usb 3.0 port when connecting usb flash 3.0 working perfectly. But when i connect old flash usb 2.0 doesnt working.
So i m sure like other motherboards that a sub 2.0 hub-controller exist but i dont have schematic so i can find it , only boardview
battery13v [ 23 янв 2020, 22:16 ]
Check Data Pins Resistance To Ground on the USB 2 Port
prospa [ 25 янв 2020, 13:11 ]
On usb 2.0 port i have resistance PIN 3 (USB PP3 CON IO) and when i connect flash usb i have 0.20 volt on this pin.
i show on boardview that usb controller connected with cpu chip and i made rework.
Now usb 3.0 port works perfect on both usb 2.0 and usb 3.0 flash but the usb 2.0 port nothing.
battery13v [ 25 янв 2020, 18:58 ]
you have to change bridge ...
prospa [ 27 янв 2020, 11:21 ]
where is bridge on this cpu ...i see only cpu on boardview?
etoemel [ 27 янв 2020, 12:08 ]
USB-controller is in the SoC (CPU)
LETZ [ 31 янв 2020, 15:16 ]
change CPU if u have low resistance on USB data-line to the ground
http://www.phpbb.com/
