E5410 (Fonseca 14 UMA) No 3.3/5V https://vlab.su/viewtopic.php?f=41&t=107858 |
R EZ A [ 11 окт 2020, 19:37 ] | |
Заголовок сообщения: | E5410 (Fonseca 14 UMA) No 3.3/5V |
hi guys this laptop came with water damage and no turn on problem i resold what i find now it still not turn on replacing 51125 wont help VREG3=3.3v VREG5=5V 51125_ENTRIP=0V 51125_ENTIP1=0.7v 51125_ENTIP2=1.4v +3D3V_PWR=0V +5V_PWR=0V I have another motherboard with same Enable voltages as above but 3.3-5V PWR is on mosfets are good what can stop it to make output voltage? |
montekristo [ 11 окт 2020, 19:51 ] | |
Заголовок сообщения: | Re: E5410 (Fonseca 14 UMA) No 3.3/5V |
Replace "tantals". |
pvlab [ 12 окт 2020, 05:56 ] | |
51125_ENTRIP=0V - check if not shorted to GND. Can be over-current protection? |
R EZ A [ 12 окт 2020, 14:11 ] | |
montekristo писал(а): Replace "tantals". i replaced and no change pvlab писал(а): 51125_ENTRIP = 0V - check if not shorted to GND. Can be over-current protection? yes 51125_ENTRIP = 0V is shorted to ground because PQ4602 Gate is 3.3V but pin 1 and 6 of 51125 isnt short to ground no output voltage even after cutting PG4608 and PG4610 |
montekristo [ 12 окт 2020, 14:15 ] | |
R EZ A писал(а): replacing 51125 wont help R EZ A писал(а): mosfets are good may be 51125 is bad... or mosfets not good. |
R EZ A [ 12 окт 2020, 18:37 ] | |
montekristo писал(а): may be 51125 is bad ... or mosfets not good. i replace 51125 aand mosfets but no change |
montekristo [ 13 окт 2020, 00:58 ] | |
Какое сопротивление между +3D3V_PWR (+5V_PWR) и GND? |
