Текущее время: 30 ноя 2026, 13:32
 Заголовок сообщения: Alienware 17 R3 (LA-C912P) Orginal Bios Deleted
СообщениеДобавлено: 19 янв 2021, 23:37
Hi
I just do the worst thing ever, i have delete original bios dump from LA-C912P motherboard, i don't have original ME section and bootguard doesn't let me start laptop. When i press power button i have 7 beeps of death. Is there any chance to revive this laptop?
I will be grateful for any help.
 Заголовок сообщения: Re: Alienware 17 R3 (LA-C912P) Orginal Bios Deleted
СообщениеДобавлено: 20 янв 2021, 00:24
search.php?keywords=La-c912p&t=7412&sf=msgonly
СообщениеДобавлено: 20 янв 2021, 00:38
I try to program bios chip with clear me region file but it doesn't wok, i try 3 different bios files and nothing work, someone in other forum tried 15 different bios files and all ends with 7 beep of death.
СообщениеДобавлено: 20 янв 2021, 01:34
Be afraid that the problem is not in the BIOS.
СообщениеДобавлено: 20 янв 2021, 01:48
100% in bios cause it was working computer and i dumped original infected uefi bios, i try to program with another bios clear_me and 2 others with the same 7 beeps of death then a was read that boot guard blocks boot so i want to revert to original, and there is the main problem i accidentally delete folder with original dump, i have ssd with trim enabled, so i can't undelete, or maybe anyone know is there any temp folder for RT809F firmware programming tool.
СообщениеДобавлено: 25 янв 2021, 06:27
Are you flashing two chips? You need to flash UE2 along with the main one.
СообщениеДобавлено: 26 янв 2021, 00:07
No i only flash UH4 16M chip and this dump i have accidently deleted.
СообщениеДобавлено: 26 янв 2021, 00:48
You need to flash 2 microcircuits. So that their contents fit together.
Try this.
СообщениеДобавлено: 03 дек 2021, 12:05
evil696
подозреваю что не помогло?
зашил обе микросхемки UH4 и UE2 вышеуказанными дампами на рабочем ноуте и получил кирпич (блокировку чтения биос)
СообщениеДобавлено: 11 янв 2022, 11:44
khvkdv
Спешу исправиться - попалась глючная флэшка. Действительно ноут ожил после прошивки обязательно 2-х микросхем UH4 и UE2
В этой теме нет новых непрочитанных сообщений. Probook PRBT920 Orginal Firmware Stock Rom Pls
1deliye2rapor
12 дек 2017, 13:29
1deliye2rapor Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Alienware 17 R3 (AAP21 LA-C912P Rev:2.0(A01)) bios 7 коротких гудков
в форуме Dell
mmn3md
08 июн 2018, 19:43
PlayFX Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell alienware 15 r2 (R2 LA-C912P AAP21 rev 2.0 (A01)) Прошивка bios
в форуме Dell
ximera34
13
6643
06 дек 2018, 15:49
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL Alienware 17 R3 (AAP21 LA-C912P rev. 2.0(A01)) Ищу BIOS с чистым ME
в форуме Dell
AhiLL
06 дек 2018, 19:38
code9523 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Alienware 17 R3 (la-c912p rev 2.0) восстановление BIOS
в форуме Dell
konstantin61
29 дек 2018, 15:10
konstantin61 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 25
