Текущее время: 29 ноя 2026, 06:10
 Заголовок сообщения: INSPIRON 3568 AMD (Vegas/Turis SKL/KBL 15341-1 ) missing SIO_SLP_S3#
СообщениеДобавлено: 01 ноя 2021, 15:36
Hey,
Recently I have got this
Dell Inspiron 3568 i5 7th Gen
Vegas/Turis SKL/KBL 15341-1 91N85
*Battery is charging and LED is lighting when it's charging
*5V_S5 and 3D3V_S5 are up
*No short circuit in main power rails
*No short circuit in any coils
*When the adapter/power connected U4001 getting SIO_SLP_S3# and getting down to 0V immediately.
*Power button switch getting 3.3v
*When the power button is pressed SIO_PWRBTN# signal is not lowered to exactly 0V. ( This cause due to the immediate effect maybe)
*X1802 Crystal is working
*When the Adapter is plugged in SPI BIOS 7th pin transmits the data and also when the power button is pressed it's trasmitting.
*I have tried flashing many compatible BIOS but didn't help.
*Check smaller caps and diodes, couldn't find any short circuit.
 Заголовок сообщения: Re: INSPIRON 3568 AMD (Vegas/Turis SKL/KBL 15341-1 ) missing SIO_SLP_S3#
СообщениеДобавлено: 01 ноя 2021, 17:36
you can close the leg to the ground with tweezers on the multicontroller. and to look .
what multicontroller. MEC1404 ?
СообщениеДобавлено: 02 ноя 2021, 10:26
I was removed PL5101, which is supply 1.2v for DIMMs and PCH, and when the adapter plugged in SIO_SLP_S3# 3.3v present.
Secondary level power rails become active 3D3V_S0 and 5V_S0 also active. The 3-Amber and 5-White error code is also blinking.
I have also checked resistance between the ground and PL5101 DIMM/PCH side, which is 377Ω (when PL5101 is removed).
After removing PL5101 the RT8231AGQW side 360kΩ
RT8231AGQW PU5101 (PL5101 removed)
PGOOD-20mV
TON-0.75v
S5-3.3v
S3-0v
VLDOIN- 192mV
VTT & VTTSNS - 0V
VID- 5.12v
VDD- 5.12v
3-Amber and 5-White LED error code is also blinking
To make sure again PL5101 soldered and the adapter plugged in again SIO_SLP_S3# just come and go like a blink.
RT8231AGQW PU5101 (PL5101 solder back)
PGOOD-5mV
S5-7mV
S3-0v
VLDOIN- 10mV
VTT & VTTSNS - 0V
(All these above values change into actual values for instance when the adapter is plugged in and back to these values)
TON-17v
VID- 5.12v
VDD- 5.12v
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп
в форуме Dell
_SkyDreamer_
16
8042
09 авг 2019, 13:07
_SkyDreamer_ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell 15-3568 Vostro UMA (Vegas/Turis SKL/KBL 15341-1 91N85) странное поведение с клавиатурой
в форуме Dell
apollo
28 фев 2020, 12:43
RedSun35 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Vostro 15 3568 (vegas/turis skl/kbl 15341-1) не заряжает батарейку
в форуме Dell
DeZQ
27 апр 2021, 21:05
DeZQ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Vostro 15-3568 (Vegas/Turis SKL/KBL 15341-1 91N85) Не включается вентилятор
в форуме Dell
kbdan52
10 дек 2024, 15:56
kbdan52 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Vostro 15 3568 (Vegas/Turis SLK/KBL 15341-1) Висит на логотипе|Помогите с прошивкой BIOS
в форуме Dell
legrand158
03 июл 2019, 16:33
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 23
