Serguz05 писал(а):
you can close the leg to the ground with tweezers on the multicontroller. and to look .
what multicontroller. MEC1404 ?
I was removed PL5101, which is supply 1.2v for DIMMs and PCH, and when the adapter plugged in SIO_SLP_S3# 3.3v present.
Secondary level power rails become active 3D3V_S0 and 5V_S0 also active. The 3-Amber and 5-White error code is also blinking.
I have also checked resistance between the ground and PL5101 DIMM/PCH side, which is 377Ω (when PL5101 is removed).
After removing PL5101 the RT8231AGQW side 360kΩ
RT8231AGQW PU5101 (PL5101 removed)
PGOOD-20mV
TON-0.75v
S5-3.3v
S3-0v
VLDOIN- 192mV
VTT & VTTSNS - 0V
VID- 5.12v
VDD- 5.12v
3-Amber and 5-White LED error code is also blinking
To make sure again PL5101 soldered and the adapter plugged in again SIO_SLP_S3# just come and go like a blink.
RT8231AGQW PU5101 (PL5101 solder back)
PGOOD-5mV
S5-7mV
S3-0v
VLDOIN- 10mV
VTT & VTTSNS - 0V
(All these above values change into actual values for instance when the adapter is plugged in and back to these values)
TON-17v
VID- 5.12v
VDD- 5.12v
